查看: 2820|回复: 0
[NI软件产品] NI InstrumentStudio 2021Q4 x64Win10 64bitEng NI仪器套件2021第四季度 InstrumentStudio21.4.0
  • 签到天数: 3733 天
    连续签到: 60 天
    发表于 2021-10-29 23:00:36 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    InstrumentStudio
    InstrumentStudio是一款免费的应用程序软件,提供了集成的交互式PXI测量方法。
    InstrumentStudio可帮助您统一显示数据,将仪器配置导出到代码,并监测和调试您的自动测试系统。 您可以使用大型高分辨率显示器在统一显示界面上查看数据,然后捕获多仪器屏幕截图和测量结果。 您还可保存项目级配置,以便针对特定的待测设备更轻松地重复进行测试,或将仪器配置导出到编程环境,以简化代码并保证测量相关性。您还可以同时使用代码和InstrumentStudio来监测和调试正在运行的测试应用程序。
    InstrumentStudio 2021 第四季度
    发布日期
    2021/10/25
    包含的版本
    2021 Q4
    受支持的操作系统
    语言
    English
    校验和
    文件大小: 809699328 字节 (772.19 MB)
    修改日期: 2021-10-23 03:00
    MD5: 1735ea1f0a319ad75492e85c6f979978
    SHA1: bafe3d775dcfbb686cdcdcc16f432c94e860be9d
    SHA256: a21f76219e65f3b0c4a1e89c5af4e58e59e074d1745e1b98734bfa3373be1a98
    CRC32: e93fd4d0
    InstrumentStudio21.4.0.txt (594 Bytes, 下载次数: 0, 售价: 10 圆)
    NI InstrumentStudio 2021 Q4 Readme
    October 2021
    This file contains important information about InstrumentStudio 2021 Q4, including supported hardware and operating systems, a partial list of bugs fixed, and known issues.
    InstrumentStudio allows you to generate and acquire measurements from multiple devices within a single application. You can also use InstrumentStudio to monitor and control devices being used in external applications, capture data files, export device configuration to other applications, and more.
    InstrumentStudio 2021 Q4 has the following requirements:
    • 4 GB RAM
    • 10 GB disk space
    • 1024 x 768 screen resolution (1366 x 768 or higher recommended)
    InstrumentStudio 2021 Q4 supports the following operating systems:
    • Windows 10 64-bit
    • Windows Server 2016 64-bit
    InstrumentStudio 2021 Q4 supports the creation of soft front panels with the following device drivers:
    Device Driver
    Minimum Version Supported by InstrumentStudio 2021 Q4
    NI-SCOPE20.7
    NI-FGEN19.1
    NI-DMM18.1
    NI-DCPOWER21.3
    NI-RFSG20.7
    Installing Instructions
    Download the Instrument Studio 2021 Q4 installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    New FeaturesInstrumentStudio 2021 Q4
    • Added new LCR panel supporting interactive use with the PXIe-4190 module.
    The following hardware models are supported in InstrumentStudio 2021 Q4:
    NI-DCPOWER Devices
    • PXIe-4112
    • PXIe-4113
    • PXIe-4135
    • PXIe-4135(35W)
    • PXIe-4136
    • PXIe-4137
    • PXIe-4137(35W)
    • PXIe-4138
    • PXIe-4139
    • PXIe-4139(40W)
    • PXIe-4140
    • PXIe-4141
    • PXIe-4142
    • PXIe-4143
    • PXIe-4144
    • PXIe-4145
    • PXIe-4147
    • PXIe-4154
    • PXIe-4162
    • PXIe-4163
    • PXIe-4190
    • PXI-4110
    • PXI-4130
    • PXI-4132
    NI-DMM Devices
    • PXIe-4080
    • PXIe-4081
    • PXIe-4082
    • PXI-4065
    • PXI-4070
    • PXI-4071
    • PXI-4072
    • PCI-4065
    • PCIe-4065
    • USB-4065
    • PCI-4070
    NI-FGEN Devices
    • PXIe-5413 (1-channel)
    • PXIe-5413 (2-channel)
    • PXIe-5423 (1-channel)
    • PXIe-5423 (2-channel)
    • PXIe-5433 (1-channel)
    • PXIe-5433 (2-channel)
    • PXIe-5442
    • PXIe-5450
    • PXIe-5451
    • PXI-5402
    • PXI-5404
    • PXI-5406
    • PXI-5412
    • PXI-5421
    • PXI-5422
    • PXI-5441
    • PCI-5402
    • PCI-5406
    • PCI-5412
    • PCI-5421
    NI-SCOPE Devices
    • PXIe-5105
    • PXIe-5110
    • PXIe-5111
    • PXIe-5113
    • PXIe-5114
    • PXIe-5122
    • PXIe-5160 (2-channel)
    • PXIe-5160 (4-channel)
    • PXIe-5162 (2-channel)
    • PXIe-5162 (4-channel)
    • PXIe-5163
    • PXIe-5164
    • PXIe-5170 (4-channel)
    • PXIe-5170 (8-channel)
    • PXIe-5171 (8-channel)
    • PXIe-5172 (4-channel)
    • PXIe-5172 (8-channel, 325T)
    • PXIe-5172 (8-channel, 410T)
    • PXIe-5185
    • PXIe-5185 (1MΩ)
    • PXIe-5186
    • PXIe-5186 (1MΩ)
    • PXIe-5622
    • PXIe-5622 (DD)
    • PXI-5105
    • PXI-5114
    • PXI-5122
    • PXI-5124
    • PXI-5142
    • PXI-5152
    • PXI-5153
    • PXI-5154
    • PXI-5922
    • PCI-5105
    • PCI-5114
    • PCI-5122
    • PCI-5124
    • PCI-5142
    • PCI-5152
    • PCI-5153
    • PCI-5154
    • PCI-5922
    • PCIe-5155
    • USB-5132
    • USB-5133
    NI-RFSG Devices
    • PXIe-5820
    • PXIe-5830
    • PXIe-5831
    • PXIe-5832
    • PXIe-5840
    • PXIe-5841
    You can access the software and documentation known issues list online. Refer to InstrumentStudio 2021 Q4 Known Issues on ni.com for an up-to-date list of known issues in InstrumentStudio.
    You can access a list of issues fixed in InstrumentStudio 2021 Q4 online. Visit InstrumentStudio 2021 Q4 Bug Fixes for an up-to-date list of fixed issues. This is not an exhaustive list of issues fixed in the current version of InstrumentStudio. If you have a Bug ID, you can search this list to validate that the issue has been fixed. .
    InstrumentStudio 2021 Q4 no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport.
    © 2018-2021 National Instruments. All rights reserved.
    377562H-01
    GMT+8, 2025-12-5 13:51
