查看: 2963|回复: 0
[NI软件产品] Semiconductor Device Control Add-On 2021 for InstrumentStudio x64Win10 64bitEng 用于NI InstrumentStudio的半导体设备控制附加软件2021下载ni-semi-device-control_21.0.0
    10 小时前
  • 签到天数: 3731 天
    发表于 2021-10-29 23:07:10 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    InstrumentStudio的半导体设备控制附加软件提供了交互式的设备控制功能,可通过快速缩放来实现自动验证。
    InstrumentStudio半导体设备控制附加软件是一个软件附加软件,可帮助您使用I2C、SPI或RFFE等标准数字协议或自定义协议来执行交互式寄存器读/写操作。您可以保存InstrumentStudio项目或导出设置,以便在LabVIEW、Python、.NET或TestStand中进行自动验证。InstrumentStudio可以与自动化应用程序并行使用,来实时监测和调试设备控制任务。InstrumentStudio的半导体设备控制附加软件也可与I2C/ SPI接口设备和PXI数字码型仪器配合使用,帮助您在执行交互式和自动化半导体验证时轻松完成常见的任务。
    用于InstrumentStudio的半导体设备控制附加软件2021
    发布日期
    2021/10/21
    包含的版本
    2021
    受支持的操作系统
    语言
    English
    校验和
    文件大小: 349503488 字节 (333.31 MB)
    修改日期: 2021-10-22 08:00
    MD5: 26879e6158823c38f22526b91fe7958e
    SHA1: a16632999a435a3aced1cb3b994021e794c69cfd
    SHA256: 9766a2708618ae845e0159b9cfd5e799af4ea33d20ce02aaff34597a3839e91c
    CRC32: 54dd23d2
    ni-semi-device-control_21.0.0.txt (602 Bytes, 下载次数: 0, 售价: 10 圆)
    Semiconductor Device Control Add-On 2021 for InstrumentStudio Readme
    October 2021
    This file contains installation instructions and compatibility information for the Semiconductor Device Control Add-On 2021 for InstrumentStudio.
    • Semiconductor Device Control Add-On for InstrumentStudio Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • Semiconductor Device Control Add-On for InstrumentStudio Manuals: New features, behavior changes, and other documentation
    Supported Hardware and Functions
    The Semiconductor Device Control Add-On for InstrumentStudio is a software add-on that helps you perform interactive register read/write operations using common or custom digital protocols. This InstrumentStudio add-on supports general hardware control tasks using static I/O and can be used in parallel with automated applications to monitor and debug device control tasks in real time.
    The Semiconductor Device Control Add-On 2021 for InstrumentStudio has the following requirements:
    • Pentium 4 G1 equivalent or later (Intel i5 equivalent or later recommended)
    • At least 10 GB of disk space
    • 4 GB RAM
    • 1024 x 768 screen resolution (1366 x 768 or higher recommended)
    Refer to the LabVIEW Readme for additional system requirements and supported operating systems for LabVIEW 2018 SP 1 or later.
    The Semiconductor Device Control Add-On 2021 for InstrumentStudio supports the following operating systems:
    Note  The Semiconductor Device Control Add-On for InstrumentStudio no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. The Semiconductor Device Control Add-On 2021 for InstrumentStudio will not install or run on an unsupported OS. You cannot deploy or distribute applications that use the Semiconductor Device Control Add-On 2021 for InstrumentStudio to an unsupported OS. Additionally, after installing the Semiconductor Device Control Add-On 2021 for InstrumentStudio, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    The Semiconductor Device Control Add-On 2021 for InstrumentStudio supports the following application software versions, including service packs. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by the Semiconductor Device Control Add-On 2021 for InstrumentStudio
    InstrumentStudio2021 (64-bit only)
    LabVIEW2018 SP1, 2018 SP1 Patch, 2019, 2019 SP1, 2020, 2021 (all 64-bit only)
    TestStand2020, 2021 (all 64-bit only)
    Python3.6 to 3.8 (all 64-bit only)
    .NET framework4.6.2 or later (all 64-bit only)
    Device Drivers
    Minimum Versions Supported by the Semiconductor Device Control Add-On 2021 for InstrumentStudio
    NI-Digital Pattern Driver20.6.2 (64-bit only)
    NI-845x Driver Support20.0 (64-bit only)
    If you are using the Semiconductor Device Control Add-On for InstrumentStudio .NET Class Library, .NET Framework 4.0 (minimum) is required. The Semiconductor Device Control Add-On 2021 for InstrumentStudio .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5.
    Download the Semiconductor Device Control Add-On for InstrumentStudio installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using Package Manager.
    Note  Use the serial number that is included with your software to activate the Semiconductor Device Control Add-On for InstrumentStudio. For more information on Semiconductor Device Control Add-On for InstrumentStudio activation, refer to NI Software Activation.
    The following table details the hardware models and functions supported in the Semiconductor Device Control Add-On 2021 for InstrumentStudio.
    Hardware Models
    Protocols
    Channels
    Custom Timings
    PXIe-6570, PXIe-6571I2C, I3C®, 3-wire SPI, 4-wire SPI, MIPI® RFFEDIO, PPMUdEVM MIPI® RFFE, dEVM SPI
    USB-8451, USB-8452I2C, 4-wire SPI, DIODIO
    Refer to the Semiconductor Device Control Add-On for InstrumentStudio Manual, accessible from ni.com/manuals, for information about the Semiconductor Device Control Add-On for InstrumentStudio.
    The Semiconductor Device Control Add-On for InstrumentStudio includes several example projects that you can use to learn key concepts or use as a starting point for applications you create.
    Navigate to %Public%\Documents\National Instruments\Semi Device Control (64-bit)\Examples in File Explorer to view the example projects that are installed with the Semiconductor Device Control Add-On for InstrumentStudio.
    LabVIEW API Examples
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for the Semiconductor Device Control Add-On are located in the labview\examples\Semi Device Control directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    The Semiconductor Device Control Add-On for InstrumentStudio no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport.
    © 2020–2021 National Instruments Corporation. All rights reserved.
    377565C-01
    GMT+8, 2025-12-3 18:59
