查看: 3466|回复: 0
[LV工具模块] LabVIEW 2021 OPC UA Toolkit Win64ENG LabVIEW OPC UA工具包OPCUA64位英文版OPCUA21.3
    昨天 16:03
    发表于 2021-12-2 15:53:30 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    LabVIEW OPC UA工具包支持在LabVIEW中创建OPC UA客户端和服务器。
    LabVIEW OPC UA工具包是LabVIEW的一个软件附件。它包含OPC UA API,集成了安全可靠的通信。您可以使用此工具包创建OPC UA客户端,服务器和安全性管理。除OPC UA规范的数据访问方面外,LabVIEW OPC UA工具包还提供对历史访问和警报和条件方面的支持。该工具包适用于Windows和NI Linux实时操作系统。注册商标Linux的使用获得了Linus Torvalds专属授权商LMI的再授权,Linus Torvalds拥有Linux注册商标在全球范围内的所有权。
    OPCUA2021 64ENG
    文件大小: 875843584 字节 (835.27 MB)
    修改日期: 2021-10-23 05:46
    MD5: 9327b9073cf683671aa873d1b2f6e52a
    SHA1: a1561e1b3bc8efc4271fb6c0e5c0da96e01bdd70
    SHA256: 3a4ec2855adabb59cb65a6c1c6377f42ca3deaafbedcc82f636a5c202ade4746
    CRC32: 6bb1fd12
    OPCUA2021ENG64.txt (627 Bytes, 下载次数: 1, 售价: 10 圆)
    LabVIEW 2021 OPC UA Toolkit Readme
    October 2021
    This file contains installation instructions and compatibility information for the LabVIEW OPC UA Toolkit.
    • LabVIEW OPC UA Toolkit Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • LabVIEW OPC UA Toolkit Manuals: New features, behavior changes, and other documentation
    The OPC UA toolkit contains the OPC UA API that was formerly part of the LabVIEW Datalogging and Supervisory Control (DSC) Module and the LabVIEW Real-Time Module. From the 2017 release, the OPC UA Toolkit becomes a standalone product. The DSC Module and the Real-Time Module no longer contain the OPC UA API. The OPC UA toolkit integrates secure and reliable communications in your LabVIEW applications. The OPC UA toolkit incorporates a series of features for the creation of OPC UA clients, servers, and security management. In addition to the Data Access (DA) facet of the OPC UA Specifications, the OPC UA Toolkit also adds support for the Historical Access (HA) and Alarms & Conditions (AC) facets. The OPC UA Toolkit is compatible with both Windows and NI Linux Real-Time operating systems.
    NoteTo deploy standalone applications, you must use the OPC UA Runtime and activate the OPC UA Toolkit deployment license.
    In addition to the system requirements for the LabVIEW Development System, the LabVIEW 2021 OPC UA Toolkit has the following requirements:
    • LabVIEW 2021 (32-bit or 64-bit)
    • LabVIEW 2021 Real-Time Module (required only if you use NI Linux Real-Time targets with the OPC UA Toolkit)
    • NI CompactRIO Device Drivers October 2021 (required only if you use CompactRIO devices with the OPC UA Toolkit)
    Refer to the LabVIEW Readme for additional system requirements and supported operating systems for LabVIEW 2021.
    The OPC UA Toolkit supports the following operating systems:
    Note  The OPC UA Toolkit no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. The OPC UA Toolkit will not install or run on an unsupported OS. You cannot deploy or distribute applications that use the OPC UA Toolkit to an unsupported OS. Additionally, after installing the OPC UA Toolkit, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    Download the OPC UA Toolkit installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    The OPC UA Toolkit supports all NI Linux Real-Time targets.
    Refer to the LabVIEW Help, accessible from Help»LabVIEW Help in LabVIEW, for information about the OPC UA Toolkit.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. Navigate to the Toolkits and Modules»OPC UA folder to access the examples.
    You also can find the examples for the OPC UA Toolkit in the labview\examples\Data Communication\OPCUA directory.
    The OPC UA Toolkit no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport.
    NI Software Drops Support for Phar Lap ETS Real-Time Operating System in 2022.
    NI Software will drop support for Phar Lap ETS Real-Time Operating System starting in 2022. Versions of this product that ship after May 1, 2022, may not install or execute correctly on this operating system. For high-level information on the support roadmap for Phar Lap and its replacement, NI Linux Real-Time, visit ni.com/r/xf35k1. To find out what hardware is supported on PXI controllers running NI Linux Real-Time, visit ni.com/r/b7g5wi.
    © 2017–2021 National Instruments Corporation. All rights reserved.
    376233E-01
    GMT+8, 2026-2-24 19:02
