查看: 2171|回复: 0
[NI驱动程序] NI-Sync 15.0 Driver Win32/64Eng NI PXI同步模块及实时控制器驱动程序下载2015.8.1
    10 小时前
    发表于 2021-12-2 17:39:13 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI-Sync用于支持用户使用PXI同步模块或任何运行实时操作系统的NI控制器。
    NI-Sync是一个NI仪器驱动程序,用于配置系统定时和同步,包括基于信号的同步和直接使用时钟。您还可以使用时间协议(如IEEE 1588标准,IEEE 802.1AS标准,IRIG或GPS)执行基于时间的同步,作为时间戳的时间参考或执行同步时钟和触发生成。NI-Sync支持PXI同步模块和实时PXI、CompactDAQ和CompactRIO控制器以及紧凑视觉系统和工业控制器。NI-Sync中还包括高级实用程序及范例,可帮助用户更轻松地创建应用程序。
    15.0
    文件大小: 1283535672 字节 (1.20 GB)
    修改日期: 2015-08-01 04:22
    MD5: 4c11ecc1ca7b34b44464f233af1771c7
    SHA1: 6aa42c464d03a6c5c6e451112627178ab98316ac
    SHA256: c993afc01779355804463f5e961df4f5ec31b82f7962530718d122a26b223d0f
    CRC32: a0d0a91c
    请注册视觉论坛会员,登录购买附件查看,充值请联系在线客服
    SYNC15.0.txt (506 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-Sync 15.0 Readme
    This file includes important information about NI-Sync, including new features, supported platforms and devices, and information about NI-Sync examples.
    Contents
    Supported Devices
    Known Issues and Bug Fixes
    System RequirementsSupported Platforms
    NI-Sync 15.0 supports the following platforms:
    • Windows XP Service Pack 3
    • Windows Vista x86, x64
    • Windows 7 x86, x64
    • Windows 8.0 x86, x64
    • Windows 8.1 x86, x64
    • Windows Server 2003 R2 (x86) 1,2
    • Windows Server 2008 R2 (x64)
    • Windows Server 2012 R2 (x64)
    • NI Real-Time Phar Lap ETS
    1 Support for Windows Server 2003 R2 may require disabling physical address extensions (PAE). To learn how this might affect your use of Windows Server 2003 and what actions you might have to take, visit ni.com/info and enter the Info Code PAESupport.
    2 The provided ethernet drivers for the PXI-6682H and PCI-1588 are not compatible with Windows Server 2003. You will need to download updated drivers from AMD. Refer to KnowledgeBase article 54EE344Q for more information.
    The following table lists the application software versions, including service packs, supported by NI-Sync.
    Application SoftwareVersions Supported by NI-Sync
    LabVIEW2012, 2013, 2014, 2015
    LabVIEW Real-Time Module2012, 2013, 2014, 2015
    LabWindows™/CVI™2012, 2013, 2015
    Supported Devices
    NI-Sync 15.0 supports the following devices:
    Signal-Based Modules
    • NI PXI-6651
    • NI PXI-6652
    • NI PXI-6653
    • NI PXIe-6672
    • NI PXIe-6674
    • NI PXIe-6674T
    Time-Based Modules
    • NI PCI-1588
    • NI PXI-6682
    • NI PXI-6682H
    • NI PXI-6683
    • NI PXI-6683H
    For a list of Known Issues of NI-Sync 15.0, visit ni.com/info and enter the Info Code NISync150KnownIssues.
    For a list of Bug Fixes for NI-Sync, visit ni.com/info and enter the Info Code NISyncFixList.
    You can access NI-Sync examples using the Example Finder.
    • For signal-based examples that use clocks and triggers directly, navigate to Hardware Input and Output»Timing and Synchronization»Signal-Based.
    • For examples that use time protocols such as IEEE 1588 or GPS as a basis for synchronization, navigate to Hardware Input and Output»Timing and Synchronization»Time-Based.
    When you install NI software on Microsoft Windows 8.x, you will notice a few additional tiles in the Apps view, including shortcuts to NI application software products such as LabVIEW, Measurement & Automation Explorer (MAX), and NI Launcher.
    Using NI Launcher
    Note  MAX does not appear as a desktop shortcut when installed on Microsoft Windows 8.x. You can launch MAX either from the Apps view or from within NI Launcher.
    Finding All Programs
    NI-Sync Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    NI-Sync will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of NISync that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    LabWindows™/CVI™cvi_lifecycle
    ©2003-2015 National Instruments. All rights reserved.
    375085B-01
    GMT+8, 2025-12-8 19:34
