查看: 2422|回复: 0
[NI软件产品] NI-Industrial Communications for Ethernet/IP 21.0 x64Win10 32/64bitEng NI以太网/IP工业通信软件21.0下载
    昨天 14:24
  • 签到天数: 3584 天
    发表于 2021-12-3 10:22:47 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI-Industrial Communications for Ethernet/IP使LabVIEW系统能够作为以太网/IP网络上的以太网/IP Class 1适配器设备进行通信。
    NI-Industrial Communications for Ethernet/IP是一款应用软件,为您使用CompactRIO控制器、CompactRIO单板控制器、PXI控制器、紧凑型视觉系统、智能相机、工业控制器或独立CompactDAQ系统提供了所需的支持。它包含丰富的LabVIEW VI和属性库,助您快速为兼容的以太网/IP硬件设备创建自定义的以太网/IP应用程序。该软件具有显式消息传递和I/O数据通信机制。这些机制提供与各种可编程逻辑控制器(PLC)和以太网/IP I/O设备的通信和数据共享。
    21.0
    文件大小: 825530368 字节 (787.29 MB)
    修改日期: 2021-10-23 05:46
    MD5: d984c58ee3aaca6cd9b0f7ab15044aee
    SHA1: ca0050f15f2bc69bb744990b23b4c0a0c17e297f
    SHA256: f30df80d727c0aed966f48a725275b564fc6f0b612086ddefa48552d4004150e
    CRC32: ddfc79e2
    IndComEIP21.0.txt (596 Bytes, 下载次数: 1, 售价: 10 元)
    NI-Industrial Communications for EtherNet/IP 21.0 Readme
    November 2021
    This file contains important information about NI-Industrial Communications for EtherNet/IP, including supported application software and hardware, installation instructions, and new features.
    Hardware Support
    NI-Industrial Communications for EtherNet/IP contains an extensive library of VIs and properties in LabVIEW to program your customized EtherNet/IP applications for your devices.
    In addition to the system requirements for the LabVIEW Development System, NI-Industrial Communications for EtherNet/IP has the following requirements:
    • LabVIEW Base Development System
    • LabVIEW Real-Time Module (required only if you run NI-Industrial Communications for EtherNet/IP on RT targets)
    Refer to the LabVIEW Readme for additional system requirements and supported operating systems for the version of LabVIEW that you run NI-Industrial Communications for EtherNet/IP on.
    NI-Industrial Communications for EtherNet/IP supports the following operating systems:
    Note   NI-Industrial Communications for EtherNet/IP no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. NI-Industrial Communications for EtherNet/IP 21.0 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-Industrial Communications for EtherNet/IP 21.0 to an unsupported OS. Additionally, after installing NI-Industrial Communications for EtherNet/IP 21.0, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    The following table lists the application software versions, including service packs, supported by NI-Industrial Communications for EtherNet/IP. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by NI-Industrial Communications for EtherNet/IP
    LabVIEW2018, 2019, 2020, 2021
    LabVIEW Real-Time Module2018, 2019, 2020, 2021
    Hardware Support
    NI-Industrial Communications for EtherNet/IP supports the following NI hardware products:
    • CompactRIO
    • Compact Vision System
    • Embedded Vision System
    • Industrial Controllers
    • PXI
    • PXIe
    • Single-Board RIO
    • Smart Cameras
    • Stand-Alone CompactDAQ
    Download the NI-Industrial Communications for EtherNet/IP installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    Use NI Measurement & Automation Explorer (MAX) to install NI-Industrial Communications for EtherNet/IP on RT targets.
    New FeaturesEtherNet/IP 21.0
    • Added support for LabVIEW 2021.
    • Added support for PXI and PXIe controllers with NI Linux Real-Time through .ipk file installation.
    EtherNet/IP 20.0
    • Added support for LabVIEW 2020.
    EtherNet/IP 19.0
    • Added support for LabVIEW 2019.
    • Added support for cRIO-9055/9058.
    EtherNet/IP 18.0
    • Added support for LabVIEW 2018.
    Refer to the NI-Industrial Communications for EtherNet/IP Help, accessible from Help»NI-Industrial Communications for EtherNet/IP in LabVIEW, for information about NI-Industrial Communications for EtherNet/IP.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. Navigate to the Hardware Input and Output»NI-Industrial Communications»EtherNet/IP folder to access the examples. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    You also can find the examples for NI-Industrial Communications for EtherNet/IP in the labview\examples\ethernetip directory.
    © 2010–2021 National Instruments Corporation. All rights reserved.
    374775J-01
    GMT+8, 2025-7-5 00:58
