查看: 1695|回复: 0
[RTE运行引擎] NI RFmx Demod/Analog Modulation/Digital Modulation 20.0 Runtime Win32Eng RFmx解调/模拟调制/数字调制20.0运行版
    昨天 08:38
  • 签到天数: 3691 天
    发表于 2022-1-6 16:57:20 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx模拟调制
    RFmx模拟调制为测试应用提供模拟调制信号的生成和分析。
    RFmx Analog Modulation是运行在RFmx解调器内的应用软件,它与RFmx Analog Modulation一起安装。该软件可扩展NI RF仪器对于模拟调制信号生成和分析的能力。您可以使用该软件,通过对频率/相位偏移、模拟调制深度、频率/相位偏差等的测量,分析AM、FM、PM和FM的立体声信号。此外,您可以通过应用去加重和音频滤波器来分析解调后的信号波形、频谱和失真。您可以通过交互式软件前面板进行和调试测量,利用随附的RFmx Waveform Creator创建和回放开放的、未锁定的波形,并利用性能优化的API加快自动测试。
    20.0RTEx86
    文件大小: 553955328 字节 (528.29 MB)
    修改日期: 2020-06-09 15:49
    MD5: 95b4e48acdcfc9ca9b5ac7fedb8fe2bb
    SHA1: b79bc1aebc625c9610c89487d1d323320badd1ab
    SHA256: 72c57b99980e64a0714f1bde4793a9ad01001361fa9ca53b3edc9110aaffd229
    CRC32: 96f3feab
    NI官方下载和百度网盘下载地址:
    RFMXdemod20.0RTEx86.txt (604 Bytes, 下载次数: 0, 售价: 5 圆)
    RFmx Demod 20.0 Readme
    June 2020
    This file contains important information about the RFmx Demod, including system requirements, and installation instructions.
    RFmx Demod Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021
    RFmx Demod provides a highly optimized RF measurement experience. Use RFmx Demod to perform demodulation measurements on analog and digital modulation signal formats, including QAM and ASK.
    RFmx Demod 20.0 includes the following new features:
    RFmx Demod 19.1 includes the following new features:
    • Support for PXIe-5841, PXIe-5831, and PXIe-5830
    RFmx Demod 19.0 includes the following new features:
    • Support for PXIe-5830 and PXIe-5831
    Vector Signal Analyzers
    • PXIe-5663
    • PXIe-5663E
    • PXIe-5665
    • PXIe-5668
    • PXIe-5668 with PXIe-5698
    Vector Signal Transceivers
    • PXIe-5644
    • PXIe-5645
    • PXIe-5646
    • PXIe-5841
    • PXIe-5840
    • PXIe-5820
    • PXIe-5830
    • PXIe-5831
    • PXIe-5841 with PXIe-5655
    RFmx Demod has the following requirements:
    RFmx Demod 20.0 supports the following 64-bit operating systems:
    • Windows 10/8.1 1 /7 SP1 2
    • Windows Server 2012 R2 1
    Note   In 2019, RFmx Demod dropped support for all 32-bit Windows operating systems. RFmx Demod will not install or run on an unsupported OS. Refer to RFmx Demod Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021 for information about future OS support.
    Note   In 2016, RFmx Demod dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. You cannot deploy or distribute applications that use RFmx Demod 20.0 to an unsupported OS. Additionally, after installing RFmx Demod 20.0, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    RFmx Demod supports the following application software versions, including service packs. You should install application software, such as LabVIEW, LabWindows/CVI or Microsoft Visual Studio®, before installing RFmx Demod. To add support for application software installed after installing RFmx Demod modify your RFmx Demod installation or launch the RFmx Demod installer again. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Application SoftwareVersions Supported by RFmx Demod
    LabVIEW2017, 2018 SP1 f4 patch, 2019 SP1 f3 patch, 2020
    LabWindows™/CVI™2015 or later
    • NI-RFSG 14.0.1 or later
    If you are using the RFmx Demod .NET Class Library, .NET Framework 4.0 (minimum) is required. The RFmx Demod .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0.
    NI installs RFmx Demod using NI Package Manager. If you do not already have NI software installed, RFmx Demod installs NI Package Manager to handle the installation of your NI software. Visit ni.com/info and enter the Info Code NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    ItemInstalled Location
    Import Library files (64-bit)
    Assemblies\DotNET\Assemblies\Current\NationalInstruments.RFmx.DemodMx.Fx40.dll
    Select Start » All Programs » National Instruments» RFmx Demod»RFmx Demod Measurement Interactive Panel to launch the RFmx Demod Measurement Interactive Panel.
    RFmx Demod palette VIs are available from the Functions » Measurement I/O » NI-RFmx » Demod palette.
    Documentation for RFmx Demod is located at Start » All Programs » National Instruments » RFmx Demod » RFmx Demod Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    RFmx Demod HelpHTML/Windows HelpContains primary help content for RFmx Demod. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to RFmx Demod
    • A complete reference for all RFmx Demod programming functions and VIs
    RFmx Demod 20.0 ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    You can access all the installed RFmx Demod examples at Start » All Programs » National Instruments » RFmx Demod » RFmx Demod Examples.
    The following items are behavior changes in RFmx Demod 19.1 from RFmx Demod 19.0.
    • Dropped support for Cleaner Spectrum property on PXIe-5830 and PXIe-5831 devices
    • Obsoleted RFmxDemod Analyze (IQ) API. Use RFmxDemod Analyze (IQ, 1 Wfm) API instead
    The following items are the behavior changes in RFmx Demod 19.0 from RFmx Demod 3.0.
    You can access the RFmx Demod known issues list online at RFmx Demod 20.0 Known Issues.
    You can access the RFmx Demod bug fix list online at RFmx Demod 20.0 Bug Fixes. This list describes a subset of issues fixed in the RFmx Demod. If you have a Bug ID, you can search this list to validate that the issue has been fixed.
    RFmx Demod will drop support for Windows 7 (64-bit) and Windows Server 2008 R2 starting in 2021. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    © 2014–2020 National Instruments. All rights reserved.
    374855N-01
    GMT+8, 2025-10-25 05:50
