查看: 1958|回复: 0
[RTE运行引擎] NI RFmx Demod/Analog Modulation/Digital Modulation 21.3 Runtime x64Win10 64bitEng RFmx解调/模拟调制/数字调制21.3运行版
  • 签到天数: 3764 天
    连续签到: 15 天
    发表于 2022-1-6 17:12:02 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx模拟调制
    RFmx模拟调制为测试应用提供模拟调制信号的生成和分析。
    RFmx Analog Modulation是运行在RFmx解调器内的应用软件,它与RFmx Analog Modulation一起安装。该软件可扩展NI RF仪器对于模拟调制信号生成和分析的能力。您可以使用该软件,通过对频率/相位偏移、模拟调制深度、频率/相位偏差等的测量,分析AM、FM、PM和FM的立体声信号。此外,您可以通过应用去加重和音频滤波器来分析解调后的信号波形、频谱和失真。您可以通过交互式软件前面板进行和调试测量,利用随附的RFmx Waveform Creator创建和回放开放的、未锁定的波形,并利用性能优化的API加快自动测试。
    21.3x64RTE
    文件大小: 593444864 字节 (565.95 MB)
    修改日期: 2021-10-22 17:17
    MD5: c7af2c90fa8ff2e58e92a0ef65ae5b72
    SHA1: 6c2c0aceb5fdc80351a41c88dfd3a923a2d46e62
    SHA256: e7ac122725e59b8ab34d80ba024fc71d80d606a0d68ef6c1b1646b1d26a5d16a
    CRC32: 75e40d2c
    NI官方下载和百度网盘下载地址:
    RFMXdemod21.3RTEx64.txt (592 Bytes, 下载次数: 0, 售价: 5 圆)
    RFmx Demod 21.3 Readme
    October 2021
    This file contains important information about the RFmx Demod, including system requirements, and installation instructions.
    • RFmx Analog Modulation Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • RFmx Digital Modulation Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • RFmx Analog Modulation Manuals: New features, behavior changes, and other documentation
    • RFmx Digital Modulation Manuals: New features, behavior changes, and other documentation
    RFmx Demod provides a highly optimized RF measurement experience. Use RFmx Demod to perform demodulation measurements on analog and digital modulation signal formats, including QAM and ASK.
    RFmx Demod 21.3 includes the following new features:
    RFmx Demod 20.6 includes the following new features:
    • Support for PXIe-5832
    RFmx Demod 20.0 includes the following new features:
    Vector Signal Analyzers
    • PXIe-5663
    • PXIe-5663E
    • PXIe-5665
    • PXIe-5668
    • PXIe-5668 with PXIe-5698
    Vector Signal Transceivers
    • PXIe-5644
    • PXIe-5645
    • PXIe-5646
    • PXIe-5820
    • PXIe-5830
    • PXIe-5831
    • PXIe-5832
    • PXIe-5841
    • PXIe-5840
    • PXIe-5841 with PXIe-5655
    RFmx Demod has the following requirements:
    RFmx Demod 21.3 supports the following 64-bit operating systems:
    Note    RFmx Demod no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx Demod 21.3 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx Demod 21.3 to an unsupported OS. Additionally, after installing RFmx Demod 21.3, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    RFmx Demod supports the following application software versions, including service packs. You should install application software, such as LabVIEW, LabWindows/CVI or Microsoft Visual Studio®, before installing RFmx Demod. To add support for application software installed after installing RFmx Demod modify your RFmx Demod installation or launch the RFmx Demod installer again. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Application SoftwareVersions Supported by RFmx Demod
    LabWindows™/CVI™2017 or later
    • NI-RFSG 14.0.1 or later
    If you are using the RFmx Demod .NET Class Library, .NET Framework 4.0 (minimum) is required. The RFmx Demod .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0.
    NI installs RFmx Demod using NI Package Manager. If you do not already have NI software installed, RFmx Demod installs NI Package Manager to handle the installation of your NI software. Visit ni.com/info and enter the Info Code NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • RFmx Demod installs the following licensed products
      • Analog Modulation: This will enable demodulation support of Analog Modulation (AM), Frequency Modulation (FM), and Phase Modulation (PM).
      • Digital Modulation: This will enable demodulation support of Amplitude-Shift Keying (ASK), Frequency-Shift Keying (FSK), Minimum-Shift Keying (MSK), Phase-Shift Keying (PSK), and Quadrature Amplitude Modulation (QAM).
    • Use the serial number that is included with your software to activate RFmx Demod. For more information on RFmx Demod activation, refer to National Instruments Software Activation.
    ItemInstalled Location
    Import Library files (64-bit)
    Assemblies\DotNET\Assemblies\Current\NationalInstruments.RFmx.DemodMx.Fx40.dll
    Select Start » All Programs » National Instruments» RFmx Demod»RFmx Demod Measurement Interactive Panel to launch the RFmx Demod Measurement Interactive Panel.
    RFmx Demod palette VIs are available from the Functions » Measurement I/O » NI-RFmx » Demod palette.
    Documentation for RFmx Demod is located at Start » National Instruments » RFmx Demod » RFmx Demod Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    RFmx Demod HelpHTML/Windows HelpContains primary help content for RFmx Demod. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to RFmx Demod
    • A complete reference for all RFmx Demod programming functions and VIs
    RFmx Demod 21.3 ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    You can access all the installed RFmx Demod examples at Start » National Instruments » RFmx Demod » RFmx Demod Examples.
    The following items are behavior changes in RFmx Demod 20.7 from RFmx Demod 20.6.
    The following items are behavior changes in RFmx Demod 19.1 from RFmx Demod 19.0.
    • Dropped support for Cleaner Spectrum property on PXIe-5830 and PXIe-5831 devices
    • Obsoleted RFmxDemod Analyze (IQ) API. Use RFmxDemod Analyze (IQ, 1 Wfm) API instead
    The following items are the behavior changes in RFmx Demod 19.0 from RFmx Demod 3.0.
    © 2014–2021 National Instruments Corporation. All rights reserved.
    374855U-01
    GMT+8, 2026-1-6 14:31
