查看: 1879|回复: 0
[RTE运行引擎] NI RFmx 20.6 Runtime Win64Eng NI Wireless Test Standard Software运行版ni-rfmx-runtime-suite_20.6.0
    昨天 08:38
  • 签到天数: 3691 天
    发表于 2022-1-11 09:44:21 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx
    20.6RTEx64
    文件大小: 795275264 字节 (758.43 MB)
    修改日期: 2021-01-20 14:49
    MD5: 4b9d80c19dcef71470bcc2aadb66fde8
    SHA1: 528ef845288a61633013fbc45d494944b8643474
    SHA256: 44cdea7eba9a8c1abd50f5f9ade9947e67c3395fdff118012157853b4c186f2c
    CRC32: 8004319f
    RFMX20.6RTEx64.txt (609 Bytes, 下载次数: 0, 售价: 5 圆)
    RFmx 20.6 Readme
    January 2021
    RFmx Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021
    The following products are included in the RFmx media. Refer to the readme of each product for information including installation, activation, new features, known issues, and bug fixes.
    • RFmx Waveform Creator
    • RFmx SpecAn
    • RFmx Demod
    • RFmx Noise Figure
    • RFmx Phase Noise
    • RFmx WLAN
    • RFmx Bluetooth
    • RFmx NR
    • RFmx LTE
    • RFmx WCDMA
    • RFmx TD-SCDMA
    • RFmx EV-DO
    • RFmx CDMA2k
    • RFmx GSM
    Drivers
    • NI-RFSG Playback Library
    RFmx 20.6 supports the following 64-bit operating systems:
    • Windows 10/8.1 1 /7 SP1 2
    • Windows Server 2012 R2 1
    Note In 2019, RFmx dropped support for all 32-bit Windows operating systems. RFmx will not install or run on an unsupported OS. Refer to RFmx Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021 for information about future OS support.
    RFmx 20.6 supports the following application software versions, including service packs.
    Application SoftwareVersions Supported by RFmx
    LabVIEW2017, 2018 SP1 f4 patch, 2019 SP1 f3 patch, 2020
    LabWindows™/CVI™2015 or later
    RFmx Test Software is available for download from NI Software Product Downloads.
    RFmx will drop support for Windows 7 (64-bit) and Windows Server 2008 R2 starting in 2021. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    © 2019–2021 National Instruments. All rights reserved.
    377996D-01
    GMT+8, 2025-10-25 05:51
