查看: 2099|回复: 0
[RTE运行引擎] NI RFmx 20.7.1 Runtime Win32Eng NI Wireless Test Standard Software运行版ni-rfmx-runtime-suite-x86_20.7.1
    昨天 08:03
  • 签到天数: 3841 天
    连续签到: 34 天
    发表于 2022-1-11 09:54:25 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx
    20.7.1RTEx86
    文件大小: 991463424 字节 (945.53 MB)
    修改日期: 2021-07-22 01:51
    MD5: 294fa7ebafe0cd31d5b63e3f44468f98
    SHA1: 2b0eaa9deaf9c19a7a56ccebf6d30a78b98d7f6c
    SHA256: 8f174862daa484c072c4a57a51d9718e370901d953e5fd3849d992d2f3b62ec7
    CRC32: 352f1fa9
    RFMX20.7.1RTEx86.txt (623 Bytes, 下载次数: 0, 售价: 5 圆)
    RFmx 20.7.1 Readme
    July 2021
    The following products are included in the RFmx media. Refer to the readme of each product for information including installation, activation, new features, known issues, and bug fixes.
    • RFmx Waveform Creator
    • RFmx SpecAn
    • RFmx Demod
    • RFmx WLAN
    • RFmx Bluetooth
    • RFmx NR
    • RFmx LTE
    • RFmx WCDMA
    • RFmx TD-SCDMA
    • RFmx EV-DO
    • RFmx CDMA2k
    • RFmx GSM
    Drivers
    • NI-RFSG Playback Library
    RFmx 20.7.1 supports the following 64-bit operating systems:
    Note RFmx no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx 20.7.1 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx 20.7.1 to an unsupported OS. Additionally, after installing RFmx 20.7.1, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    For more information about the changes to our OS support, visit http://www.ni.com/r/win32bitsupport.
    RFmx 20.7.1 supports the following application software versions, including service packs.
    Application SoftwareVersions Supported by RFmx
    LabVIEW2017, 2018 SP1 f4 patch, 2019 SP1 f3 patch, 2020 SP1
    LabWindows™/CVI™2015 or later
    RFmx Test Software is available for download from NI Software Product Downloads.
    © 2019–2021 National Instruments Corporation. All rights reserved.
    377996F-01
    GMT+8, 2026-3-31 04:39
