查看: 1656|回复: 0
[RTE运行引擎] NI RFmx 21.3 Runtime Win64Eng NI Wireless Test Standard Software运行版ni-rfmx-runtime-suite_21.3.0
    昨天 09:46
  • 签到天数: 3643 天
    连续签到: 5 天
    发表于 2022-1-11 09:57:16 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx
    21.3RTEx64
    文件大小: 804069376 字节 (766.82 MB)
    修改日期: 2021-10-22 16:53
    MD5: 67a0dc1cd23809cc6621d012eeb5534f
    SHA1: b708fffa9d8b8a84835d23caa5e15ab92877df84
    SHA256: bda2cb75514a99fcd15c4dfdc9958e8d5d8c98058413b030e95ad7295775a067
    CRC32: 2216a538
    RFMX21.3RTEx64.txt (609 Bytes, 下载次数: 0, 售价: 5 圆)
    RFmx 21.3 Readme
    October 2021
    The following products are included in the RFmx media. Refer to the readme of each product for information including installation, activation, new features, known issues, and bug fixes.
    • RFmx Waveform Creator
    • RFmx SpecAn
    • RFmx Demod
    • RFmx WLAN
    • RFmx Bluetooth
    • RFmx NR
    • RFmx LTE
    • RFmx WCDMA
    • RFmx TD-SCDMA
    • RFmx EV-DO
    • RFmx CDMA2k
    • RFmx GSM
    Drivers
    • NI-RFSG Playback Library
    RFmx 21.3 supports the following 64-bit operating systems:
    Note RFmx no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx 21.3 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx 21.3 to an unsupported OS. Additionally, after installing RFmx 21.3, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    For more information about the changes to our OS support, visit http://www.ni.com/r/win32bitsupport.
    RFmx 21.3 supports the following application software versions, including service packs.
    Application SoftwareVersions Supported by RFmx
    LabWindows™/CVI™2015 or later
    RFmx Test Software is available for download from NI Software Product Downloads.
    © 2019–2021 National Instruments Corporation. All rights reserved.
    377996G-01
    GMT+8, 2025-9-6 03:12
