查看: 2078|回复: 0
[RTE运行引擎] NI RFmx 21.3 Runtime Win32Eng NI Wireless Test Standard Software运行版ni-rfmx-runtime-suite-x86_21.3.0
    昨天 09:46
  • 签到天数: 3643 天
    连续签到: 5 天
    发表于 2022-1-11 09:58:08 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx
    21.3RTEx86
    文件大小: 787388416 字节 (750.91 MB)
    修改日期: 2021-10-22 16:53
    MD5: 8dd11181336e476abe270823f82c4355
    SHA1: d98ffaa2837efb36d9dfef7fb5a3789c17b87161
    SHA256: 41cebd8f6143932e3a4863e273ca6815c911a6822773bd695a2d3f478778fd87
    CRC32: c5ef1cc8
    RFMX21.3RTEx86.txt (621 Bytes, 下载次数: 0, 售价: 5 圆)
    RFmx 21.3 Readme
    October 2021
    The following products are included in the RFmx media. Refer to the readme of each product for information including installation, activation, new features, known issues, and bug fixes.
    • RFmx Waveform Creator
    • RFmx SpecAn
    • RFmx Demod
    • RFmx WLAN
    • RFmx Bluetooth
    • RFmx NR
    • RFmx LTE
    • RFmx WCDMA
    • RFmx TD-SCDMA
    • RFmx EV-DO
    • RFmx CDMA2k
    • RFmx GSM
    Drivers
    • NI-RFSG Playback Library
    RFmx 21.3 supports the following 64-bit operating systems:
    Note RFmx no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx 21.3 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx 21.3 to an unsupported OS. Additionally, after installing RFmx 21.3, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    For more information about the changes to our OS support, visit http://www.ni.com/r/win32bitsupport.
    RFmx 21.3 supports the following application software versions, including service packs.
    Application SoftwareVersions Supported by RFmx
    LabWindows™/CVI™2015 or later
    RFmx Test Software is available for download from NI Software Product Downloads.
    © 2019–2021 National Instruments Corporation. All rights reserved.
    377996G-01
    GMT+8, 2025-9-6 03:06
