查看: 1899|回复: 0
[NI驱动程序] NI-845x Driver Software 1.0 Win32Eng NI-845x驱动软件1.0
    昨天 10:12
  • 签到天数: 3791 天
    连续签到: 42 天
    发表于 2022-1-11 15:53:25 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI-845x支持I2C/SPI接口设备。
    NI-845x是一个驱动程序软件,用于对消费电子产品和集成电路的内部集成电路(I2C)、SCSI并行接口(SPI)或SMBus通信进行配置、编程和故障排除。NI-845x还提供一个通用数字I/O API,适用于各种应用,比如I2C设备的地址配置、LED切换或选通转换以及模拟转换器芯片常见的数据收发线等。
    1.0
    文件大小: 104598976 字节 (99.75 MB)
    修改日期: 2010-04-25 04:23
    MD5: c14f2ddda1043c5691693188ebcb5f56
    SHA1: 11235d215412dcce88e7931b605f43e1abf2ee6c
    SHA256: cce229002752e0a027f944828a7978dbe8cdf6e47dbc4f832f1a0ec87c8d16fc
    CRC32: 36c095da
    845x1.0.txt (499 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-845x Software
    Version 1.0
    © 2005 National Instruments Corporation, All Rights Reserved.
    Thank you for using National Instruments products.
    Information in this file is organized in the following sections:
    • Installation
    • Documentation
    • Supported Hardware
    • Supported Development Environments
    Installation
    Before installing the NI-845x Software, log on as Administrator or as a user with Administrator privileges. The NI-845x software setup program must have Administrator privileges because the program modifies the configuration registry of your system. Complete the following steps to install the NI-845x software.
    • Insert the NI-845x Software CD into your CD-ROM drive. The installer launches if your CD-ROM drive plays data CDs automatically. If the installer does not launch automatically, navigate to the CD using Windows Explorer and launch the autorun.exe file from your NI-845x Software CD.
    • The installation wizard guides you through the necessary steps to install the NI-845x software. You can go back and change values where appropriate by clicking the Back button. You can exit the setup where appropriate by clicking Cancel.
    • When installation is complete, click Finish.
    The NI-845x Software User Manual is the primary document. The manual includes an overview of the I2C and SPI buses as well as detailed information on the API.
    The NI-845x Software User Manual is provided in Adobe Acrobat Portable Document Format (PDF). You can download the Acrobat Reader for free at: www.adobe.com.
    Open the manual from your Start menu in:
    Start » Programs » National Instruments » NI-845x
    • National Instruments USB-8451 I2C, SPI Interface
    Additional documentation for your NI-845x interface is on your CD or in the NI-845x\Documentation folder on your hard drive.
    The NI-845x software supports the following development environments:
    ·        LabVIEW 7.0, 7.1, and 8.0
    GMT+8, 2026-2-3 02:05
