查看: 1773|回复: 0
[NI驱动程序] NI-845x Driver Software 1.1 Win32Eng NI-845x驱动软件1.1
    昨天 10:12
  • 签到天数: 3791 天
    连续签到: 42 天
    发表于 2022-1-11 15:54:43 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI-845x支持I2C/SPI接口设备。
    NI-845x是一个驱动程序软件,用于对消费电子产品和集成电路的内部集成电路(I2C)、SCSI并行接口(SPI)或SMBus通信进行配置、编程和故障排除。NI-845x还提供一个通用数字I/O API,适用于各种应用,比如I2C设备的地址配置、LED切换或选通转换以及模拟转换器芯片常见的数据收发线等。
    1.1
    文件大小: 125121824 字节 (119.33 MB)
    修改日期: 2022-01-11 15:49
    MD5: 8b71ca3a881a5a1657eededdeaff175c
    SHA1: 6f706c61f4a453989689a0011a58b00aa653c332
    SHA256: 5c3bd23da2460814ff7e4c7f0b42aa78e1a67162d6af5687bbeb194107674658
    CRC32: 815d2c15
    845x1.1.txt (498 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-845x Readme
    February 2007
    ni.com/support
    This file contains information on the NI-845x software for Windows. Information in this file is organized in the following sections:
    • Installation
    • Documentation
    • Supported Operating Systems
    • Supported Hardware
    • Supported Development Environments
    • Changes from Previous Releases
    • Release Notes
    Installation
    Before installing the NI-845x software, log on as Administrator or as a user with Administrator privileges. The NI-845x software setup program must have Administrator privileges because the program modifies the configuration registry of your system. Complete the following steps to install the NI-845x software.
    • Insert the NI-845x software CD into your CD-ROM drive. The installer launches if your CD-ROM drive plays data CDs automatically. If the installer does not launch automatically, navigate to the CD using Windows Explorer and launch the autorun.exe file from your NI-845x Software CD.
    • The installation wizard guides you through the necessary steps to install the NI-845x software. You can go back and change values where appropriate by clicking the Back button. You can exit the setup where appropriate by clicking Cancel.
    Back to Top
    The NI-845x Software User Manual is the primary document. The manual includes an overview of the I2C and SPI buses as well as detailed information on the API.
    The NI-845x Software User Manual is in Adobe Acrobat Portable Document Format (PDF). You can download the Acrobat Reader for free at: www.adobe.com.
    Open the manual from your Start menu in:
      Start » All Programs » National Instruments » NI-845x
    Back to Top
    The NI-845x software must be installed and run on the following Microsoft operating systems:
    • Windows 2000 service pack 3 (or higher)
    • Windows XP
      For more information on using National Instruments hardware and software products with Windows Vista, visit ni.com/vista.
    Back to Top
    The NI-845x software supports the following National Instruments hardware products:
    • National Instruments USB-8451 I2C/SPI Interface
    Back to Top
    The NI-845x software supports the following development environments:
    • LabVIEW 7.1, 8.0, and 8.2
    • LabWindows/CVI 7.1 (or newer)
    • Microsoft Visual C/C++ 6.0
    Back to Top
    The following changes were made to the NI-845x software in this release:
    • Added support for LabWindows/CVI 7.1 (or newer)
    • Added support for Microsoft Visual C/C++ 6.0.
    • Added support for the Microsoft Windows Vista operating systems.
    • The API VIs and examples for the LabVIEW 8.2 development environment are mass compiled to LabVIEW 8.2.1.
    Back to Top
    Release Notes
    • On Windows Vista, access to the NI USB-8451 I2C/SPI Interface is limited to a single process. This means you cannot control a single NI USB-8451 I2C/SPI Interface from multiple executables at the same time.
    Back to Top
    © 2005-2007 National Instruments Corporation. All rights reserved.
    GMT+8, 2026-2-3 02:04
