查看: 2152|回复: 0
[NI软件产品] LabVIEW 2015 FPGA Module Xilinx Compilation Tools Linux32Eng LV2015 FPGA编译工具(ISE 14.7)
    昨天 11:03
  • 签到天数: 3581 天
    发表于 2022-1-13 10:56:21 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    发布日期
    15-8-8
    受支持的操作系统
    Red Hat Enterprise Linux 6.4 (32-bit)
    Red Hat Enterprise Linux 6.5 (32-bit)
    语言
    English
    校验和
    文件大小: 4076795904 字节 (3.80 GB)
    修改日期: 2015-08-08 02:21
    MD5: 11497e63cc9c927eb98427986138686c
    SHA1: 808bba014c69ec6a89012949ec5490c3def299af
    SHA256: e7bc8a3844143c9c997d7d1909db41754e1472ae23d3b8b15d4bff6587d159f1
    CRC32: 9ecc2bc5
    百度网盘下载和NI官方下载地址:
    请注册视觉论坛会员,登录购买附件查看,充值请联系在线客服
    FPGACT-Linux-ISE14.7-LV2015.txt (621 Bytes, 下载次数: 1, 售价: 10 元)
    LabVIEW 2015 FPGA Module Xilinx Compilation Tools for Linux DVD Readme
    June 2015
    This file contains important information about the LabVIEW FPGA Module Xilinx Compilation Tools for Linux DVD, including system requirements and installation instructions.
    With the LabVIEW 2015 FPGA Module Xilinx Compilation Tools for Linux DVD, one installation gives you access to Xilinx Compilation Tools for Vivado 2014.4 and ISE 14.7, which are supported by the LabVIEW FPGA Module. Install these compilation tools if you want to compile your FPGA VIs on a Linux computer.
    The LabVIEW FPGA Module Xilinx Compilation Tools for Linux have the following requirements:
    • Red Hat Enterprise Linux 6.4 or 6.5
    • 11 GB of disk space
    Note NI recommends a 64-bit OS for the computer on which you install the Xilinx compilation tools.
    The following sections contain the NI hardware supported by the LabVIEW FPGA Module Xilinx Compilation Tools on Linux:
    Use the Xilinx Compilation Tools for Vivado 2014.4 to compile FPGA VIs for the following devices:
    • IC-317x
    • NI 914x
    • NI cRIO-903x, NI cRIO-906x
    • NI PXIe-517xR, NI PXIe-5624R, NI PXIe-5820R, NI PXIe-5840R, NI PXIe-659xR, NI PXIe-782xR, NI PXIe-793xR, NI PXIe-797xR, NI PXIe-7902R
    • NI sbRIO-9651, NI sbRIO-9607, NI sbRIO-9627, NI sbRIO-9637
    • NI USB-785xR
    • NI USRP-RIO 294x, NI USRP-RIO 295x
    Xilinx Compilation Tools for ISE 14.7
    Use the Xilinx Compilation Tools for ISE 14.7 to compile FPGA VIs for the following devices:
    • NI PXI-784xR, NI PXI-785xR, NI PXI-795xR
    • NI PCIe-784xR, NI PCIe-785xR
    • NI PXIe-796xR, NI PXIe-564xR
    • NI cRIO-907x, NI cRIO-908x, NI cRIO-911x
    • NI sbRIO-960x, NI sbRIO-961x, NI sbRIO-962x, NI sbRIO-963x, NI sbRIO-964x
    • NI 9144, NI 9146, NI 9148, NI 915x
    Complete the following steps to install the LabVIEW FPGA Module Xilinx Compilation Tools for Linux:
    • Insert the LabVIEW 2015 FPGA Module Xilinx Compilation Tools for Linux installation media. Use mount /mnt/cdrom to mount the media. On some Linux systems, the media mounts automatically.
    • To change the current directory to the mounted media, enter cd /mnt/cdrom/CWXILINX14 or cd /mnt/cdrom/CWVIVADO2014.
    • To run the installation script, enter sh ./INSTALL.
    © 2012–2015 National Instruments. All rights reserved.
    Third-Party Copyright Notices
    \LabVIEW 2015\FPGA\Legal
    The Python_2.5_notice.pdf file contains a third-party copyright notice for third-party components used by certain FPGA Module features. The following directory is the default installation location for the file, but the location might vary depending on the configuration of the local computer:
    374740C-01
    GMT+8, 2025-7-2 03:54
