查看: 1891|回复: 0
[NI驱动程序] LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes 15.0.0 Win32/64Eng LabVIEW可重配置示波器仪器设计库NIREOSCIDL2015
    昨天 08:18
  • 签到天数: 3733 天
    连续签到: 60 天
    发表于 2022-1-14 16:45:12 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    LabVIEW可重配置示波器仪器设计库
    LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes可帮助您使用用户可编程的FPGA为PXI示波器开发所需的应用程序。
    NIREOSCIDL2015
    文件大小: 852575008 字节 (813.08 MB)
    修改日期: 2015-11-02 23:40
    MD5: c7d16396bd88d4b229cc3f00ae9fbac8
    SHA1: 6d4b3d1ec49adfc86b4a65b4bc87055c36ff00d1
    SHA256: a2562a39a65c9ed9181499ba9dd8d4fe1c9c94fa8a89721057edde4fd0505c56
    CRC32: ebf616c4
    NIREOSCIDL15.0.txt (653 Bytes, 下载次数: 0, 售价: 10 圆)
    NI LabVIEW 2015 Instrument Design Libraries for Reconfigurable Oscilloscopes 15.0 Readme
    October 2015
    Thank you for using NI LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes (instrument design libraries). This file contains important information about LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes and is organized into the following sections:
    Accessing VIs and Functions
    Accessing LabVIEW Sample Projects
    Driver Version Naming Changes
    Uninstalling/Modifying LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes
    LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes 15.0 includes the following new features:
    • Support for LabVIEW 2015 (32-bit)
    LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes 14.0 includes the following new features:
    • Support for LabVIEW 2014 (32-bit)
    • Support for the NI PXIe-5170R and NI PXIe-5171R reconfigurable oscilloscopes
    • NI PXIe-5171R
    • NI PXIe-5170R (4 CH)
    • NI PXIe-5170R (8 CH)
    Device-specific information about these modules is included in the NI Reconfigurable Oscilloscopes Help.
    LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes 15.0 and later supports the following operating systems:
    Note  FPGA VIs cannot be compiled on a computer running Windows 8 or Windows 8.1. Refer to Cannot Compile FPGA VIs on a Windows 8 Computer for more information.
    Note  To compile LabVIEW FPGA VIs, your computer must be running a 64-bit operating system.
    LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes does not support LabVIEW Real-Time Module or LabWindows™/CVI™ Real-Time Module.
    Minimum System Requirements
    • RAM—2 GB
    • Windows 8/7/Vista/XP SP3, with all available critical updates and service packs
    Note  To compile LabVIEW FPGA VIs, your computer must be running a 64-bit operating system. To compile VIs for reconfigurable oscilloscope FPGA targets, your computer must have at least 4 GB of RAM. The minimum system requirements support only the reconfigurable oscilloscopes runtime and compiled projects.
    Recommended System
    • Processor—Intel i7 or equivalent
    • RAM—8 GB
    • Windows 7 (64-bit), with all available critical updates and service packs
    Note  NI recommends that you have 8 GB or more of system memory for compiling LabVIEW FPGA VIs. Memory requirements vary according to both the FPGA target and the FPGA VI you create for that target. Refer to the LabVIEW FPGA Module Readme for more information on determining your memory needs for FPGA VI compilation.
    Note  You should install ADEs, such as NI LabVIEW, before installing the instrument design libraries. To add support for ADEs installed after installing the instrument design libraries, modify your instrument design libraries installation or launch the instrument design libraries installer again.
    • NI LabVIEW 2015 (32-bit only)
    • LabVIEW 2015 FPGA Module (recommended)
    Support for LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes was first available in LabVIEW 2014 (32-bit).
      • Windows 8/7/Vista: Users\Public\Documents\National Instruments
    ItemInstalled Location on Windows 8.1 (32-bit)/8 (32-bit)/7 (32-bit)/Vista (32-bit)/XP
    LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes\Program Files\National Instruments\LabVIEW 2015\instr.lib\HSAI-RIO\
    Common instrument design libraries\Program Files\National Instruments\LabVIEW 2015\instr.lib\_niInstr
    Calibration support for LabVIEW\Program Files\National Instruments\LabVIEW 2015\instr.lib\ HSAI-RIO\Calibration\
    ItemInstalled Location on Windows 8.1 (64-bit)/8 (64-bit)/7 (64-bit)/Vista (64-bit)
    LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes\Program Files (x86)\National Instruments\LabVIEW 2015\instr.lib\HSAI-RIO\
    Common instrument design libraries\Program Files (x86)\National Instruments\LabVIEW 2015\instr.lib\_niInstr
    Calibration support for LabVIEW\Program Files (x86)\National Instruments\LabVIEW 2015\instr.lib\ HSAI-RIO\Calibration\
    Documentation for LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes is located at Start»All Programs»National Instruments»Reconfigurable Oscilloscopes»Reconfigurable Oscilloscope Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    NI Reconfigurable Oscilloscopes HelpHTML/Windows HelpContains primary help content for NI Reconfigurable Oscilloscope products. The help is an HTML version of a traditional user manual that includes the following information:
    • An introduction to reconfigurable oscilloscopes
    • Hardware device information
    • Programming overviews and VI references for instrument design libraries
    LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    Instrument design library palette VIs are available on the host from the Functions»FPGA Interface»Software-Designed Instruments»Oscilloscopes palette. For FPGA VIs, palettes specific to the FPGA target are available from the Functions palette.
    To access the LabVIEW sample projects and templates from the New Project dialog box, select Sample Projects»Oscilloscopes in the left pane and navigate to the project that best matches your application requirements.
    LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes versions are aligned with the versions of major NI application software products. This alignment gives you information about the year the driver was released and the most recent software version the driver was designed to work with. Driver versions now start with a two-digit year indicator: <;ProductName>. For example, LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes 14.0 is the version released with LabVIEW 2014.
    • Click Change/Remove.
    • Select NI LabVIEW 2015 Instrument Design Libraries for Reconfigurable Oscilloscopes 15.0 from the dialog box that appears.
    • Select Driver Runtime.
    • Click Remove to uninstall the product(s); click Modify to change the components that are installed.
    For Windows 8, complete the following steps:
    • Click the Uninstall button.
    As part of the instrument design libraries installation, the following software is installed. To completely remove the instrument design libraries installation from your system, you must also remove all of the following packages:
    • NI PXI Platform Services 15.0.0
    • NI System Configuration Runtime 15.0.0
    • NI-RIO 15.0
    • NI Measurement & Automation Explorer 15.0
    You can access the software and documentation known issues list online. Refer to the NI LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes 15.0 Known Issues at ni.com for an up-to-date list of known issues in LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes.
    This is the first release of LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes. In future releases, refer to the readme for bug fix details.
    Using NI Launcher
    For convenience, you can pin your most-used NI applications, such as MAX, to either the Start screen or the Taskbar on the desktop, as necessary.
    Finding All Programs
    NI LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    National Instruments LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of the instrument design libraries that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes.
    NI LabVIEWlifecycle
    NI TestStandtslcp
    NI DIAdemddlcp
    NI SignalExpressselcp
    NI VeriStandnivslifecycle
    © 2015 National Instruments. All rights reserved.
    374867B-01
    GMT+8, 2025-12-6 00:18
