查看: 2516|回复: 0
[NI驱动程序] LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes 18.0.0 Win32/64Eng LabVIEW可重配置示波器仪器设计库NIREOSCIDL2018
    昨天 08:08
  • 签到天数: 3821 天
    连续签到: 14 天
    发表于 2022-1-14 16:52:20 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    LabVIEW可重配置示波器仪器设计库
    LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes可帮助您使用用户可编程的FPGA为PXI示波器开发所需的应用程序。
    NIREOSCIDL2018
    文件大小: 1616665489 字节 (1.51 GB)
    修改日期: 2018-12-21 06:55
    MD5: a35b2d49979c18a6e45d65919a83f78d
    SHA1: ac6a8047eab70af3ec1f2ca08e7b3af5e3e69050
    SHA256: 4cf9bb64a8e3303542c22578e2d547b060133f220bdf6df184d15d2b565cea28
    CRC32: 8b796f8a
    NIREOSCIDL18.0.txt (595 Bytes, 下载次数: 0, 售价: 10 圆)
    NI LabVIEW 2018 Instrument Design Libraries for Reconfigurable Oscilloscopes 18.0 Readme
    October 2018
    This file contains important information about NI LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes, including installation information, new features, a partial list of bugs fixed, and known issues.
    Installation Information
    LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes 18.0 provides support for customers using the PXIe-5164, PXIe-5170, PXIe-5171, and PXIe-5172 reconfigurable oscilloscopes with LabVIEW 2018.
    LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes 18.0 has the following requirements:
    • Pentium 4 or equivalent processor
    • 2 GB RAM
    Note  To compile LabVIEW FPGA VIs, your computer must be running a 64-bit operating system. To compile VIs for reconfigurable oscilloscope FPGA targets, your computer must have at least 4 GB of RAM. The minimum system requirements support only the reconfigurable oscilloscopes runtime and compiled projects.
    LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes supports the following operating systems:
    • Windows 10/8.11/7 SP12
    • Windows Server 2012 R21
    • Windows Server 2008 R2 SP12
    Note  FPGA VIs cannot be compiled on a computer running Windows 8 or Windows 8.1. Visit ni.com/info and enter the Info Code exim4q for information on alternative methods of compiling FPGA VIs that have been developed on a Windows 8 or Windows 8.1 computer.
    Note  In 2016, LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes 16.2 dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes 16.2 and later will not install or run on an unsupported OS. You cannot deploy or distribute applications that use LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes 16.2 and later to an unsupported OS. Additionally, after installing LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes 16.2 and later, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    For more information about the changes to our OS support for 2016 and beyond, refer to KB 79UC78LS, Why Does My NI ADE Installer Fail on Windows XP/Vista and Windows Server 2003?.
    LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes does not support LabVIEW Real-Time Module or LabWindows™/CVI™ Real-Time Module.
    The following table lists the application software versions, including service packs, supported by LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes 18.0.
    Application SoftwareVersions Supported by LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes 18.0
    LabVIEW (32-bit and 64-bit)2018
    LabVIEW FPGA Module (recommended)2018
    Note  Support for LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes was first available in LabVIEW 2014 (32-bit).
    Note  You should install ADEs, such as NI LabVIEW, before installing the instrument design libraries. To add support for ADEs installed after installing the instrument design libraries, modify your instrument design libraries installation or launch the instrument design libraries installer again.
    As part of the instrument design libraries installation, the following software is installed. To completely remove the instrument design libraries installation from your system, you must also remove all of the following packages:
    • NI PXI Platform Services 18.0
    • NI System Configuration Runtime 18.0
    • NI-RIO 18.0
    • NI Measurement & Automation Explorer 18.0
    Notice  Several of the software packages listed above are shared with other NI software packages. If you attempt to remove a piece of software that something else is dependent on, a message launches to warn you about the software dependencies. You can choose to either uninstall all of the software or to leave the shared software installed. If you choose to uninstall the shared software, some of your other NI software may no longer function correctly.
    • LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes 18.0 includes the following new feature:
      • Support for LabVIEW 2018 (32-bit and 64-bit)
    • LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes 17.0 includes the following new feature:
      • Support for LabVIEW 2017 (32-bit)
    • LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes 16.2 includes the following new features:
      • Support for the following PXIe-5172 devices:
        • PXIe-5172 (4 channel, 325T FPGA)
        • PXIe-5172 (8 channel, 325T FPGA)
        • PXIe-5172 (8 channel, 410T FPGA)
    • LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes 16.1 includes the following new feature:
      • Support for the PXIe-5164 reconfigurable oscilloscope
    • LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes 16.0 includes the following new feature:
      • Support for LabVIEW 2016 (32-bit)
    • LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes 15.0 includes the following new feature:
      • Support for LabVIEW 2015 (32-bit)
    • LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes 14.0 includes the following new features:
      • Support for LabVIEW 2014 (32-bit)
      • Support for the NI PXIe-5170 and NI PXIe-5171 reconfigurable oscilloscopes
    • PXIe-5164
    • PXIe-5170
    • PXIe-5171
    • PXIe-5172
    You can access the software and documentation known issues list online. Refer to the NI website for an up-to-date list of known issues in LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes 18.0.
    Refer to the NI Reconfigurable Oscilloscopes Help, accessible from Start»All Programs» National Instruments»Reconfigurable Oscilloscopes»Reconfigurable Oscilloscope Documentation, for information about the instrument design libraries.
    © 2014–2018 National Instruments. All rights reserved.
    374867G-01
    GMT+8, 2026-3-11 05:42
