查看: 2852|回复: 0
[LabVIEW] NI LabVIEW 2021 SP1 Runtime Linux64ENG LV2021SP1运行版 64位Linux系统 64位英文版离线安装包下载
    4 小时前
  • 签到天数: 3713 天
    连续签到: 40 天
    发表于 2022-2-28 12:25:52 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    LabVIEW 2021 SP1 Linux RTE
    发布日期:
    22-2-16
    包含的版本:
    2021 SP1
    openSUSE
    Scientific Linux
    RedHat
    Ubuntu
    Linux
    语言:
    英文
    文件大小: 93532160 字节 (89.20 MB)
    修改日期: 2022-01-18 18:30
    MD5: c5fe2e16dfe6fb4ef0297574660d5e8a
    SHA1: 0a07b3be5a618be8ff468ea6a13f78f3e5317eeb
    SHA256: b53ea9b1983272b671611e88fdb898e3671715ac881104f6684163e67689f777
    CRC32: cbb4f8c4
    注册登录视觉论坛会员,购买附件查看
    LV2021SP1 Linux RTE.txt (536 Bytes, 下载次数: 2, 售价: 5 圆)
    LabVIEW 2021 SP1 Readme for GNU/Linux
    January 2022
    LabVIEW Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    LabVIEW Manuals: New features, behavior changes, and other documentation
    Supported Drivers
    LabVIEW 2021 SP1 for Linux has the following requirements:
    Linux
    Processor        Pentium 4 G1 (or equivalent) or later        Pentium 4 G1 (or equivalent) or later
    RAM        256 MB        1 GB
    Screen Resolution        1024 x 768 pixels        1024 x 768 pixels
    Operating System        Linux kernel 2.6x or 3.x
    GNU C Library (glibc) Version 2.11 or later for the Intel x86_64 architecture        openSUSE Leap 15.2
    openSUSE Leap 15.1
    Red Hat Enterprise Linux 8
    Red Hat Enterprise Linux 7
    CentOS 8
    CentOS 7
    Ubuntu 18
    Ubuntu 20
    Disk Space        98 MB        1.1 GB for the complete installation
    Color Palette        N/A        LabVIEW and the LabVIEW Help contain 16-bit color graphics. LabVIEW requires a minimum color palette setting of 16-bit color.
    Temporary Files Directory        N/A        LabVIEW uses a directory for storing temporary files. NI recommends that you have several megabytes of disk space available for this temporary directory.
    Adobe Reader        N/A        You must have Adobe Reader installed to search PDF versions of all LabVIEW manuals.
    LabVIEW 2021 SP1 for Linux is available only in 64-bit.
    LabVIEW and LabVIEW Run-Time Engine require 64-bit processors that support SSE2 instructions.
    Complete the following steps to install and activate LabVIEW for Linux.
    Insert and mount the LabVIEW installation media. As the root user in the mounted directory, enter sh ./INSTALL to install LabVIEW in the /usr/local directory.
    To install LabVIEW modules and toolkits, refer to the readme of each product for installation instructions. The VI Analyzer Toolkits installs with the LabVIEW Professional Development System for Linux.
    NoteVI Analyzer toolkit is not supported on Ubuntu in LabVIEW 2021 SP1.
    You can install NI device drivers from ni.com/linuxdrivers.
    Refer to the LabVIEW Upgrade Notes for information about protecting existing VIs and projects before installing a new version of LabVIEW, as well as upgrade and compatibility issues and a complete list of new features in LabVIEW 2021 SP1.
    Complete the following steps to install a patch on computers with LabVIEW 2021 SP1. Replace f# with the specific patch you are installing.
    Close all NI software.
    Download LV2021_f#LPatch.tgz into a folder. For example, download the file to ~/Desktop/Patch/LV2021_f#LPatch.tgz.
    Unpack LV2021_f#LPatch.tgz. For example, cd ~/Desktop/Patch and tar -xzf LV2021_f#LPatch.tgz.
    Run the installation script as root. For example, type su and enter the password. Then run ./INSTALL.
    After the installation script reports that Patch installation completed, verify that the patch installed correctly. Select Help?About LabVIEW and look for 21.0.0f# on the right portion of the window.
    Repeat these steps for all development systems where you want to install the patch.
    LabVIEW 2021 SP1 for Linux supports the following modules and toolkits.
    Control Design and Simulation Module1
    MathScript Module2
    VI Analyzer Toolkit3
    Application Builder3
    Supported Drivers
    Refer to the NI website for information about drivers compatible with LabVIEW for Linux. To use hardware with LabVIEW 2021 SP1, install the latest version of the driver for the device. Refer to the readme of each driver for more information about system requirements and installation instructions.
    Refer to the LabVIEW Help, accessible by selecting Help?LabVIEW Help from LabVIEW, for information about LabVIEW 2021 SP1.
    ? 2004–2022 National Instruments Corporation. All rights reserved.
    For patents covering the NI products/technology, refer to the appropriate location: Help?Patents in your software, the patents.txt file on your media, or the NI Patent Notice at ni.com/patents.
    374718T-01
    GMT+8, 2025-11-15 13:54
