查看: 2105|回复: 0
[NI驱动程序] NI Linux Device Drivers 2021 Q4 Online Linux64Eng Linux设备驱动程序2021Q4DeviceDrivers在线安装
  • 签到天数: 3733 天
    连续签到: 60 天
    发表于 2022-3-1 11:10:56 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI Linux Device Drivers 2021 Q4 Online Linux64Eng Linux仪器驱动程序NIlinux2021Q4DeviceDrivers在线安装
    NI Linux仪器驱动程序
    NI Linux Device Drivers软件为采用Linux操作系统的NI和第三方硬件提供了所需的NI仪器驱动。
    NI Linux Device Drivers软件为各种NI测试和测量硬件提供了Linux桌面支持。该软件提供了一个存储库附加工具,下载该附加工具后,就可以指示Linux软件包管理器安装NI驱动软件包,如NI-DAQmx、NI-VISA、NI-488.2和NI-Sync。NI Linux Device Drivers软件也支持LabVIEW。
    发布日期:
    2021/10/27
    包含的版本:
    2021Q4
    RedHat
    CentOS
    SUSE
    Ubuntu
    语言:
    English
    文件大小: 388903 字节 (379.79 KB)
    修改日期: 2022-02-23 17:58
    MD5: b72ddc3755a3a5ba2e7ee784caa01544
    SHA1: 996a65683714e6c1e4e8defd2a9863b657d8c6ea
    SHA256: 47d6b5ca06ac2485a8772d118e813bb2a2f7babf1801aeb16d02b2a3fddeb2b9
    CRC32: df60d7e2
    百度网盘和NI官方下载地址(在线安装,需要连网支持,且能正常连接NI服务器):
    请注册视觉论坛会员登录后购买附件下载查看,充值请联系在线客服
    NILinux2021Q4DeviceDrivers.txt (518 Bytes, 下载次数: 0, 售价: 5 圆)
    NI Linux Device Drivers 2021 Q4 Readme
    October 2021
    This file contains installation instructions and compatibility information for NI Linux Device Drivers 2021 Q4.
    You can find more release information, such as known issues, bugs fixed since the last release, and other notes about this release, in the NI Linux Device Drivers Release Notes. For more general NI Linux information, refer to the NI Linux Users Community on ni.com.
    Package Repositories
    Supported Drivers
    NI Linux Device Drivers software provides Linux Desktop support for a variety of NI test and measurement hardware. It offers repository registration packages for each supported Linux distribution. Once the appropriate driver software repository is registered for the system, use the Linux distribution's native package manager to install NI driver software packages.
    Refer to Download and Install NI Driver Software on Linux Desktop.
    NI Linux Device Drivers are installed from one of the following two options.
    • Static repository registration packages are labeled with a date-based suffix, such as ni-RHEL7CENTOS7-drivers-2021Q4. Software from this repository is not intended to change, and it is updated only for critical patches. Use this kind of repository when you need to reproduce a specific software stack.
    • Stream repository registration packages are labeled with a -stream suffix, for example: ni-RHEL7CENTOS7-drivers-stream. Software in this repository is updated regularly with the latest versions of each driver package as it is released. Running an update/upgrade command with a package manager will update installed NI packages to their latest released version for systems that have registered a stream repository. This kind of repository is the simplest way to keep NI driver software up to date.
    "Firstlook" is present in repository registration package names, for example ni-ubuntu2004firstlook-drivers-2021Q3.deb, to identify a repository that does not contain one or more of the drivers present in the other feeds. This commonly occurs when NI adds support for a new Linux OS distribution and there is a transition period while individual drivers are gradually added or validated on that distribution.
    If you plan to upgrade to a new distribution and you see "firstlook" in its NI repository registration package name, refer to the Supported Drivers table to ensure that the NI products you need support the new distribution.
    Supported Drivers
    For details about a specific driver's system requirements, supported hardware, limitations, and so on, refer to the readme for the individual driver.
    The following table shows driver support for several Linux distributions. Use your Linux distribution's package manager to install the specified add-on files for an NI driver.
    NI Driver Support for Linux Distributions
    Driver
    Packages
    RHEL1/
    CentOS 7
    Kernel 3.10
    RHEL1/
    CentOS 8
    Kernel 4.18
    SUSE2 15.1
    Kernel 4.12
    SUSE2 15.2
    Kernel 5.3
    Ubuntu3 18.04
    Kernel 5.4
    First Look
    Ubuntu3 20.04
    Kernel 5.8
    First Look
    Driver
    Readmes
    NI-488.2
    ni-488.2
    libni4882-devel
    ni-488.2-iotrace-support
    378678a
    NI-DCPower
    ni-dcpower
    ni-dcpower-daqmx
    ni-dcpower-labview-20xy-support
    378680a
    NI-FlexRIO
    ni-flexrio
    ni-flexrio-795x
    ni-flexrio-796x
    ni-flexrio-797x
    378682a
    NI-RIO4
    ni-fpga-interface
    ni-rio-mxie
    378683a
    NI-RFSA
    ni-rfsa
    ni-rfsa-daqmx
    ni-rfsa-labview-20xy-support
    n/a
    n/a
    378692a
    NI-RFSG
    ni-rfsg
    ni-rfsg-daqmx
    ni-rfsg-labview-20xy-support
    n/a
    n/a
    378693a
    NI-SCOPE
    ni-scope
    ni-scope-daqmx
    ni-scope-labview-20xy-support
    378687a
    NI-Sync
    ni-sync
    libnisync1-devel
    ni-sync-labview-20xy-support
    Driver Info
    NI-VISA
    ni-visa
    ni-visa-labview-20xy-support
    378691a
    1 Red Hat Enterprise Linux
    2 OpenSUSE Leap
    3 Ubuntu LTS
    4 Enables connections via the FPGA Interface API to remote RIO devices such as CompactRIO, Single-Board RIO, and Ethernet RIO
    © 2018–2021 National Instruments Corporation. All rights reserved.
    378353E-01
    GMT+8, 2025-12-5 13:49
