查看: 1873|回复: 0
[NI驱动程序] NI-HSDIO 21.5 Driver x64Win10 32/62bitEng/Jpn NI高速数字输入输出仪器驱动程序21.5
  • 签到天数: 3602 天
    连续签到: 10 天
    发表于 2022-3-10 10:11:20 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI-HSDIO
    NI-HSDIO为使用NI PXI数字波形仪器或数字波形设备的客户提供支持。
    NI-HSDIO是与数字波形硬件进行通信的NI仪器驱动程序,用于执行高速DIO  (HSDIO)任务。该驱动程序软件包含基于IVI准则的灵活API、完整的硬件支持文档,以及配置和测试实用程序。
    发布日期:
    2022/1/27
    包含的版本:
    21.5.0完整版
    支持的操作操作系统:
    语言:
    English
    Japanese
    应用程序位数:
    32/64位
    文件大小: 3099244544 字节 (2.89 GB)
    修改日期: 2022-01-28 07:17
    MD5: 3070d22bbd7bd558179fb15ad917ea5b(官方正确)
    SHA1: c76d28dc764a68b1cd81b60874143af73b96d19b
    SHA256: b792018db66185bb0d901eccf2639fae89f187e476c2733a3e51c00a9632eaed
    CRC32: 23ed86c3
    请注册登录视觉论坛,购买附件后查看下载地址
    NI-HSDIO 21.5.txt (532 Bytes, 下载次数: 0, 售价: 10 元)
    NI-HSDIO 21.5 Readme
    January 2022
    This file contains installation instructions and compatibility information for NI-HSDIO 21.5.
    You can find more information on ni.com
    NI-HSDIO provides support for customers using NI digital waveform generators/analyzers. To program NI digital waveform generators/analyzers, use the NI-HSDIO API.
    System RequirementsMinimum Requirements
    • Processor—1 GHz or faster 64-bit (x64) processor
    • 2 GB RAM (64-bit)
    NI-HSDIO 21.5 supports the following operating systems:
    • Windows Server 2016 (64-bit)
    NI-HSDIO 21.5 supports the following application software versions, including service packs. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by NI-HSDIO
    LabVIEW2018, 2019, 2020, 2021
    LabVIEW NXG5.1
    LabVIEW Real-Time Module2018, 2019, 2020, 2021
    LabWindows/CVI2015 or later
    LabWindows/CVI Real-Time Module2015 or later
    Microsoft Visual C++ (MSVC)6.0 or later
    Note  NI-HSDIO 21.5 does not support self-calibration of the NI PXIe-6556 with LabVIEW Real-Time Module. Use NI-HSDIO 15.0 and LabVIEW 2012 to perform self-calibration of the PXIe-6556 with LabVIEW Real-Time Module.
    If you are using the NI-HSDIO .NET Class Library, .NET Framework 4.0 (minimum) is required. The NI-HSDIO .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5.
    To use the .NET API, you must install the .NET class libraries or the .NET wrapper in addition to the NI device driver. For information about versions of the .NET Framework and the drivers each supports, as well as the download location of the installer files, refer to National Instruments .NET Driver Support.
    NI installs NI-HSDIO and other NI software using NI Package Manager. Visit ni.com/r/NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • NI Script Editor is no longer installed with NI-HSDIO.
    NI-HSDIO no longer installs IVI Compliance Package (ICP). NI-HSDIO supports IVI configuration and runtime, but no longer installs the following IVI components:
    • IVI-COM Adapters
    • Added support for LabVIEW 2021
    • Added support for Windows Server 2019
    • NI-HSDIO 21.5 removes support for NI-HWS.
    • NI-HSDIO 21.5 removes calibration support for the PXIe-6555/6556 high-speed digital I/O devices.
    The following list details which hardware models are supported in NI-HSDIO:
    • PXI/PCI-6541
    • PXI/PCI-6542
    • PXIe-6544
    • PXIe-6545
    • PXIe-6547
    • PXIe-6548
    • PXI/PCI-6551
    • PXI/PCI-6552
    • PXIe-6555
    • PXIe-6556
    • PXI/PCI-6561
    • PXI/PCI-6562
    Note:  Device-specific information about these modules is included in the NI Digital Waveform Generator/Analyzer Help.
    Refer to the NI-HSDIO Help, accessible from Start»All Programs»National Instruments»NI-HSDIO»Documentation, for information about the NI-HSDIO API and NI digital waveform generators/analyzers.
    The documentation set is composed of the following documents:
    Document
    Format
    Description
    NI Digital Waveform Generator/Analyzer HelpHTML/Windows HelpContains instructions for opening, configuring, initiating signal generation, and closing the session. Also, contains information about programming and fundamentals.
    NI Digital Waveform Generator/Analyzer Getting Started Guide for your devicePrinted and PDFContains software and hardware installation, MAX configuration, signal connection, and troubleshooting information for your device.
    Specifications for your devicePDFContains specifications for the capabilities and valid operating conditions of your NI device.
    NI-HSDIO ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    File Locations and ExamplesInstalled Software
      • (32-bit) Program Files\IVI Foundation\IVI\
      • (64-bit) Program Files (x86)\IVI Foundation\IVI\
        • (32-bit) Program Files\IVI\
        • (64-bit) Program Files (x86)\IVI\
      • (64-bit) Program Files\IVI Foundation\IVI\
    Item
    Installed Location
    NI-HSDIO\Drivers\niHSDIO
    NI-HSDIO Examples\NI-HSDIO\Examples
    NI-HSDIO Header files\Include
    NI-HSDIO Import Library files (32-bit)\Lib
    NI-HSDIO Import Library files (64-bit)\Lib_x64
    NI-HSDIO DLL (32-bit)\Bin
    Additional File Locations for 64-bit operating systems
    Item
    Installed Location
    NI-HSDIO DLL (64-bit)\Bin
    The following sections detail considerations for using LabVIEW NXG with NI-HSDIO.
    LabVIEW NXG Hardware Support
    • PXI/PCI-6541
    • PXI/PCI-6542
    • PXIe-6544
    • PXIe-6545
    • PXIe-6547
    • PXIe-6548
    • PXI/PCI-6551
    • PXI/PCI-6552
    • PXIe-6555
    • PXIe-6556
    • PXI/PCI-6561
    • PXI/PCI-6562
    Installing NI-HSDIO for LabVIEW NXG
    NI automates LabVIEW NXG installation using a package manager. Complete the following steps to install NI-HSDIO for LabVIEW NXG.
    • Click Download LabVIEW NXG 5.0.
    • NI Package Manager installs, then automatically opens a download window.
    • Select LabVIEW NXG Suite and click the green Install button.
    • Select LabVIEW NXG 5.0 and NI-HSDIO.
    • Complete the installer instructions to download LabVIEW NXG 4.0 and NI-HSDIO.
    LabVIEW NXG Help
    LabVIEW NXG Examples
    NI-HSDIO no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport.
    © 2003–2022 National Instruments Corporation. All rights reserved.
    375376K-01
    GMT+8, 2025-7-23 12:13
