NI RF Signal Generators 21.5.0 x64Win10 32/64bitEng NI RF信号发生器NI-RFSG21.5.0
NI-RFSG
发行日期
2022/01/28
包含的版本
21.5.0完整版
受支持的操作系统
程序位数
32/64位
语言
英文
校验和
文件大小: 5522141184 字节 (5.14 GB)
修改日期: 2022-01-28 20:48
MD5: feb8b2241b578a30654a1ff8123e6af8
SHA1: c51ebef71dd28ba35c0d54c33e2150c43a9d5601
SHA256: 7bfb82cf997838bdb60d1215d4a0d2ddb57f9e5ae68cc359c7fe5c5e725d6a65
CRC32: fb2c4797
NI-RFSG 21.5.txt
(518 Bytes, 下载次数: 0, 售价: 10 圆)
NI-RFSG 21.5 ReadmeJanuary 2022
This file contains installation instructions and compatibility information for NI-RFSG. You can find more release information on ni.com.
[url=]Overview[/url]This software installation provides support for customers using RF signal generator or vector signal transceiver hardware, as specified in the Supported Hardware section. To program your device, use the NI-RFSG instrument driver or NI-RFSG Soft Front Panel (SFP).
The getting started guide for your device provides information about how to install, configure, test, and begin using your hardware. [url=]New Features[/url]NI-RFSG 21.5 includes the following new features: - Support for RF list mode on PXIe-5840/5841 for LO Source, Upconverter Frequency Offset Mode, and Signal Bandwidth attributes
NI-RFSG 21.0 includes the following new features: - Support for LabVIEW 2021
- Support for Linux
NI-RFSG 20.7 includes the following new features: - Added new InstrumentStudio-based NI-RFSG Soft Front Panel with the ability to debug and monitor applications for the PXIe-5840/5841 and PXIe-5830/5831/5832
- Added the ability to load waveforms from TDMS files into the device memory for the PXIe-5840/5841 and PXIe-5830/5831/5832
- Added the ability to configure certain properties for a specific waveform on the PXIe-5840/5841 and PXIe-5830/5831/5832
[url=]Supported Hardware[/url]The following table shows which hardware products are supported in the NI-RFSG instrument driver and the NI-RFSG SFP. The following hardware products are supported in all operating systems listed in the Supported Operating Systems section. Hardware Product | Hardware Model | NI-RFSG | NI-RFSG Soft Front Panel (Classic) | NI-RFSG Soft Front Panel (InstrumentStudio) | | RF Signal Upconverter | PXI-5610 | √ | — | — | | I/Q Modulator | PXIe-5611 | √ | — | — | | Vector Signal Transceiver | PXIe-5644 | √ | √ | — | | PXIe-5645 | √ | √ | — | | PXIe-5646 | √ | √ | — | | PXIe-5820 | √ | — | √ | | PXIe-5830 | √ | √ | √ | | PXIe-5831 | √ | √ | √ | | PXIe-5832 | √ | √ | √ | | PXIe-5840 | √ | √ | √ | | PXIe-5841 | √ | √ | √ | PXIe-5841 with
PXIe-5655 RF Analog Signal Generator | √ | √ | √ | | RF Analog Signal Generator | PXI/PXIe-5650 | √ | √ | — | | PXI/PXIe-5651 | √ | √ | — | | PXI/PXIe-5652 | √ | √ | — | | PXIe-5653 | √ | — | — | | PXIe-5654 | √ | √ | — | PXIe-5654 with
PXIe-5696 Amplitude Extender | √ | √ | — | | Vector Signal Generator | PXI-5670 | √ | √ | — | | PXI-5671 | √ | √ | — | | PXIe-5672 | √ | √ | — | | PXIe-5673/5673E | √ | √ | — |
MXI Express and MXI-4 are supported on Windows 10. Note Some hardware products are not supported by the NI-DAQmx-based runtime. Visit ni.com/info and enter the Info Code rfsgdevices for more information about which NI-RFSG devices are supported by the NI-DAQmx-based runtime. Note You must install the same version of the NI-RFSA/NI-RFSG Runtime for PXIe-5644/5645/5646 and NI-RFSA/NI-RFSG Runtime for PXIe-5820/5830/5831/5832/5840/5841 if you choose to install the runtimes independently. Note For best memory performance on the PXIe-5831/5832, NI recommends using only 64-bit applications. System RequirementsNI-RFSG has the following requirements: - Processor—1 GHz 64-bit (x64) processor
- 4 GB RAM*
- Windows 10, with all available critical updates and service packs
*Depending on the amount of data acquired and/or processed, a larger amount of memory may be required. Note Guest accounts are not supported under any OS. Note NI-RFSG 21.5 is not compatible with NI-RFSA 2.6. Upgrade to NI-RFSA 2.7 or later before installing NI-RFSG 21.5. [url=]Supported Operating Systems[/url]NI-RFSG and NI-RFSG SFP support the following operating systems: - Windows 10
- Windows Server 2019
- Windows Server 2016
[url=]Application Software Support[/url]NI-RFSG supports the following application software versions, including service packs. You should install application software, such as LabVIEW, LabWindows/CVI or Microsoft Visual Studio®, before installing NI-RFSG. To add support for application software installed after installing NI-RFSG, modify your NI-RFSG installation or launch the NI-RFSG installer again. If you are not using NI application software, refer to Microsoft Visual Studio Support. Application Software | Versions Supported by NI-RFSG | | LabVIEW | 2018 SP1, 2019, 2020, or 2021 | | LabWindows/CVI | 2018 to current |
Note Install any toolkits or add-on software you intend to use with the NI-RFSG instrument driver after NI-RFSG installation is complete. Refer to the getting started guide for your device for more information about software and hardware installation. Note MXI users must install the software included with the MXI hardware. [url=]Microsoft Visual Studio Support[/url]If you are using the NI-RFSG .NET Class Library, .NET Framework 4.0 (minimum) is required. The NI-RFSG .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5. For more information on .NET development using NI .NET drivers, visit ni.com/info and enter Info Code NETAPIdriversupport. To install the NI-RFSG .NET Class Library, ensure that you select .NET Framework 4.5 Languages Support or .NET Framework 4.0 Languages Support in the NI-RFSG installer. [url=]Installation Instructions[/url]Download the NI-RFSG installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager. [url=]Accessing the API[/url]LabVIEWNI-RFSG VIs are available in LabVIEW from the Functions»Measurement I/O»NI-RFSG palette. LabWindows/CVINI-RFSG functions are available in LabWindows/CVI from the Instrument menu. To load the NI-RFSG function panel (.fp), select Instrument»Load, and navigate to IVI\Drivers\niRFSG\niRFSG.fp. .NET FrameworkYou can use the NI-RFSG .NET Class library by adding a reference to NationalInstruments.ModularInstruments.NIRfsg.Fx40 or NationalInstruments.ModularInstruments.NIRfsg.Fx45 and any dependent class libraries from within the Solution Explorer in Visual Studio. CYou can use the NI-RFSG C dynamically linked library by adding a reference to: Program Files (x86)\IVI Foundation\IVI\Bin\niRFSG.dll for 32-bit development or Program Files\IVI Foundation\IVI\Bin\niRFSG_64.dll for 64-bit development. NI-RFSG SFPTo launch the NI-RFSG SFP, navigate to Start»All Programs»National Instruments»NI-RFSG»NI-RFSG Soft Front Panel. [url=]Finding Examples[/url]Select Help»Find Examples from LabVIEW or LabWindows/CVI to launch the NI Example Finder and navigate to Hardware Input and Output»Modular Instruments»NI-RFSG. You can also select the Search tab to search all installed examples by keyword. You can access all the installed NI-RFSG examples at Start»All Programs»National Instruments»NI-RFSG»NI-RFSG Examples. Accessing the HelpDocumentation for NI-RFSG is located at Start»All Programs»National Instruments»NI-RFSG»Documentation. This documentation set is composed of the following documents. Document | Format | Description | | NI RF Signal Generators Help | HTML/Windows Help | Contains primary help content for NI-RFSG products. The help is an HTML version of a traditional user manual that includes the following information:- An introduction to RF fundamentals
- Hardware device overviews
- How to get started with application development
- The NI-RFSG Soft Front Panel Help
- A complete reference for all NI-RFSG VIs, properties, and functions, as well as the NI-RFSG .NET Class Library Help
| | NI-RFSG Readme | HTML (this document) | Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices. |
Few other documentation for NI-RFSG is located at Program Files\IVI Foundation\IVI\Drivers\niRFSG\documentation. This documentation set is composed of the following documents. Document | Format | Description | | Introduction to niRFSG | HTML | Contains information about driver documentation, examples, connecting to your instrument, configuring instrument settings, and known issues. | | NI-RFSG IVI Compliance Document | TXT | Contains information about IVI compliance. |
For the most recent revisions of documentation and for newly released documentation, visit ni.com/manuals. [url=]Product Security and Critical Updates[/url][url=]IVI Compliance Package Functionality[/url]NI-RFSG no longer installs IVI Compliance Package (ICP). NI-RFSG supports IVI configuration and runtime, but no longer installs the following IVI components: - LabVIEW and CVI IVI class drivers for developing IVI interchangeable applications
- IVI Class Simulation drivers
- IVI-COM Adapters
To use these features, you must install ICP separately. ICP is included in the Software Platform Bundle media. A stand-alone web distribution is available from ni.com/downloads. [url=]Automating the Installation of NI Products[/url]You can automate the installation of most NI products using command-line arguments to suppress some or all of the installer user interface and dialog boxes. If the NI product you are installing uses Microsoft .NET 4.6.2, the .NET installer may run before any NI software installs and may require a reboot before the installation of NI software begins. To avoid a .NET reboot, install .NET 4.6.2 separately before you install NI software. For more information about automating the installation of NI products, refer to Automating an Installer in the NI Package Manager manual. Using NI Software with Microsoft Windows 10Microsoft Windows 10 is the latest version of the Windows operating system and features significant changes compared to previous versions. Windows 10 introduces several new capabilities and also combines features from both Windows 7 and Windows 8. For more information about NI support for Windows 10, refer to NI Product Compatibility for Microsoft Windows 10. [url=]Unsupported Windows Operating Systems[/url]NI-RFSG no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport. Legal InformationCopyright © 2004–2022 National Instruments Corporation. All rights reserved. Under the copyright laws, this publication may not be reproduced or transmitted in any form, electronic or mechanical, including photocopying, recording, storing in an information retrieval system, or translating, in whole or in part, without the prior written consent of National Instruments Corporation. NI respects the intellectual property of others, and we ask our users to do the same. NI software is protected by copyright and other intellectual property laws. Where NI software may be used to reproduce software or other materials belonging to others, you may use NI software only to reproduce materials that you may reproduce in accordance with the terms of any applicable license or other legal restriction. End-User License Agreements and Third-Party Legal Notices You can find end-user license agreements (EULAs) and third-party legal notices in the following locations after installation: - Notices are located in the \_Legal Information and directories.
U.S. Government Restricted Rights If you are an agency, department, or other entity of the United States Government ("Government"), the use, duplication, reproduction, release, modification, disclosure or transfer of the technical data included in this manual is governed by the Restricted Rights provisions under Federal Acquisition Regulation 52.227-14 for civilian agencies and Defense Federal Acquisition Regulation Supplement Section 252.227-7014 and 252.227-7015 for military agencies. IVI Foundation Copyright Notice Content from the IVI specifications reproduced with permission from the IVI Foundation. The IVI Foundation and its member companies make no warranty of any kind with regard to this material, including, but not limited to, the implied warranties of merchantability and fitness for a particular purpose. The IVI Foundation and its member companies shall not be liable for errors contained herein or for incidental or consequential damages in connection with the furnishing, performance, or use of this material. Trademarks Refer to the NI Trademarks and Logo Guidelines at ni.com/trademarks for information on NI trademarks. Other product and company names mentioned herein are trademarks or trade names of their respective companies. Patents For patents covering the NI products/technology, refer to the appropriate location: Help» Patents in your software, the patents.txt file on your media, or the NI Patent Notice at ni.com/patents. 374769AG-01
