查看: 1809|回复: 0
[RTE运行引擎] NI RFmx 21.5 Runtime x64Win10 32bitEng NI Wireless Test Standard Software运行版ni-rfmx-runtime-suite-x86_21.5.0
    昨天 09:46
  • 签到天数: 3643 天
    连续签到: 5 天
    发表于 2022-3-14 16:22:47 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx
    发布日期
    2022/1/27
    包含的版本
    21.5.0运行版
    受支持的操作系统
    应用程序位数
    32位
    语言
    English
    校验和
    文件大小: 788035584 字节 (751.53 MB)
    修改日期: 2022-01-27 13:46
    MD5: 0bfbf73a239eaad42641535304136214(官方正确)
    SHA1: 506b426cd91984a66089c6bb1ec0f8aa9b301063
    SHA256: 353c99322b136b6004e62b031d3ab319004701c15ff9a0a0d1099d7fe4a26953
    CRC32: 9c412d31
    NI RFmx 21.5 RTEx86.txt (605 Bytes, 下载次数: 0, 售价: 5 圆)
    RFmx Runtime (32-Bit) 21.5 Readme
    January 2022
    This file contains important information about the RFmx Runtime (32-Bit), including system requirements, and installation instructions.
    The following products are included in the RFmx Runtime (32-Bit) media. Refer to the readme of each product for information including installation, activation, new features, known issues, and bug fixes.
    Application Software
    • RFmx SpecAn Runtime (32-Bit)
    • RFmx Demod Runtime (32-Bit)
    • RFmx WLAN Runtime (32-Bit)
    • RFmx for Bluetooth® Test Runtime (32-Bit)
    • RFmx NR Runtime (32-Bit)
    • RFmx LTE Runtime (32-Bit)
    • RFmx WCDMA Runtime (32-Bit)
    • RFmx TD-SCDMA Runtime (32-Bit)
    • RFmx EV-DO Runtime (32-Bit)
    • RFmx CDMA2k Runtime (32-Bit)
    • RFmx GSM Runtime (32-Bit)
    Drivers
    • NI-RFSG Playback Library Runtime
    [url=]System Requirements[/url]
    RFmx Runtime (32-Bit) has the following requirements:
    [url=]Supported Operating Systems[/url]
    RFmx Runtime (32-Bit) 21.5 supports the following 64-bit operating systems:
    Note RFmx Runtime (32-Bit) no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx Runtime (32-Bit) 21.5 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx Runtime (32-Bit) 21.5 to an unsupported OS. Additionally, after installing RFmx Runtime (32-Bit) 21.5, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    [url=]Installation Instructions[/url]
    Download the RFmx Runtime (32-Bit) installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    [url=]Product Security and Critical Updates[/url]
    [url=]Automating the Installation of NI Products[/url]
    [url=]Using NI Software with Microsoft Windows 10[/url]
    377997H-01
    GMT+8, 2025-9-6 03:15
