查看: 2164|回复: 0
[NI软件套件] NI Static Test Software Suite 1.1 x64Win10 64bitEng NI静态测试软件套件1.1
    昨天 10:51
  • 签到天数: 3789 天
    连续签到: 40 天
    发表于 2022-3-21 15:24:50 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    Static Test Software Suite静态测试软件套件
    静态测试软件套件包括帮助处理在静态或疲劳结构测试中收集数据的软件,此软件用于航空航天应用程序。
    静态测试软件套件包括用于航空航天数据采集和测试开发环境的FlexLogger、SystemLink服务器、静态数据查看器(Static Data Viewer)等应用软件。该套件可与连接至应变计的CompactDAQ系统一起使用,用于测试航空器机身、太空运载工具等结构。FlexLogger帮助测试操作员配置测试,记录从几分钟到几周或更长时间的应变数据,而结构工程师可以通过静态数据查看器Web应用程序远程访问测试数据,以便分析结构的行为。
    1.1
    发布日期
    2021/9/3
    包含的版本
    1.1完整版
    受支持的操作系统
    应用程序位数
    64位
    语言
    英文
    校验和
    文件大小: 7411941376 字节 (6.90 GB)
    修改日期: 2021-09-03 09:18
    MD5: 48f0ed8d2aa07a3223e5b0ea4b328524
    SHA1: 6e9eee3e51e48aa036fc930693cfcaab7d7f6fb0
    SHA256: a99c82985b29ec1f846f31505995ebab82179c133630c9f0b6ff479c3d272de2
    CRC32: c75b2b4b
    注册登录视觉论坛,购买附件查看下载地址
    NI STSS1.1.txt (637 Bytes, 下载次数: 0, 售价: 15 圆)
    Static Test Software Suite 1.1 Readme
    September 2021
    This file contains installation instructions and compatibility information for the Static Test Software Suite used in the Static Structural Test Reference Architecture.
    For known issues, bugs fixed since the last release, and other notes about a Static Test Software Suite release, visit Static Test Software Suite Release Notes.
    You can access the Static Structural Test Reference Architecture documentation by search at ni.com.
    The Static Test Software Suite includes FlexLogger, the Static Data Viewer web application, and SystemLink Server for use in aerospace data acquisition and test development environments.
    Included Components
    Static Test Software Suite 1.1 includes the following major components:
    • FlexLogger 2021 R3
    • Static Data Viewer 1.1
    • SystemLink 2021 R2 (Server only)
    Note   The Static Test Software Suite does not include licenses for FlexLogger and SystemLink. You must purchase separate licenses for each product.
    Static Test Software Suite 1.1 requires the following:
    • Intel Xeon E-2286G CPU 4.0 GHz, 6-Core
    • 64 GB RAM
    • At least 30 GB of disk space
    • Gigabit Ethernet adapter (x2) (one dedicated for instrumentation network)
    • Windows 10 64-bit
    • DHCP server support or an external DHCP-enabled router
    Download the Static Test Software Suite installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    © 2021 National Instruments Corporation. All rights reserved.
    378599A-01
    GMT+8, 2026-2-1 16:40
