查看: 2391|回复: 0
[NI软件套件] LabVIEW 2015 roboRIO software Suite 1.0 Win32Eng 基于RIO的机器人软件套件1.0
    4 小时前
  • 签到天数: 3733 天
    连续签到: 60 天
    发表于 2022-3-22 10:04:34 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    LabVIEW roboRIO software Suite软件套件
    基于RIO的机器人软件套件
    所需软件
    LabVIEW Development System
    LabVIEW Real-Time Module
    LabVIEW roboRIO Toolkit
    可选软件
    LabVIEW Control Design and Simulation Module
    Control Design Assistant
    System Identification Assistant
    LabVIEW FPGA Module
    LabVIEW MathScript RT Module
    LabVIEW Robotics Module for LabRIO
    Compilation Tools for Vivado
    VI Package Manager
    Vision Acquisition Software
    Vision Development Module
    发布日期:
    2015/8/3
    支持操作系统:
    Windows 7
    Windows Server 2012 R2 64-bit
    Windows 8.1
    Windows Server 2008 R2 64-bit
    Windows Server 2003 R2 32-bit
    Windows XP (SP3) 32-bit
    Windows Vista
    Windows 8
    语言:
    英文
    应用程序位数:
    32位
    版本:
    2015完整版
    文件大小: 2882963456 字节 (2.68 GB)
    修改日期: 2015-08-03 14:09
    MD5: b9fc957021b8845265717e0f11ac007b
    SHA1: 272ff15d851460c0fe7b4a562349234284a858a7
    SHA256: fc28121cec4cbd408bc8f99679e5c1b3e633e8ebc3196053c50f8d75c0cd8759
    CRC32: a7aef1a3
    LV roboRIO软件套件2016.txt (521 Bytes, 下载次数: 2, 售价: 15 圆)
    LabVIEW 2015 roboRIO Software Bundle Readme
    June 2015
    This file contains important information about the LabVIEW roboRIO Software Bundle, including system requirements, installation instructions, and links to detailed information about included products.
    With the LabVIEW roboRIO Software Bundle, one installation gives you access to the LabVIEW roboRIO Toolkit and other NI software for developing roboRIO applications. The LabVIEW roboRIO Software Bundle contains the following products:
    • LabVIEW Development System
    • LabVIEW Real-Time Module
    • LabVIEW roboRIO Toolkit
    Optional Software
    • VI Package Manager
    • LabVIEW FPGA Module
    • Compilation Tools for Vivado
    • Vision Development Module
    • Vision Acquisition Software
    • LabVIEW Control Design and Simulation Module
      • Control Design Assistant
    • LabVIEW MathScript RT Module
    • LabVIEW Robotics Module for myRIO and roboRIO
    Refer to the documentation of each product for specific system requirements and supported operating systems.
    The LabVIEW roboRIO Software Bundle supports the following operating systems:
    • Windows 8.0/8.1 (32-bit and 64-bit)
    • Windows XP Service Pack 3 Professional
    Complete the following steps to install LabVIEW, Real-Time Module, roboRIO Toolkit, and other NI software on a development computer:
    • Log in to the development computer as an administrator or as a user with administrative privileges.
    • Insert the LabVIEW roboRIO Software Bundle DVD 1.
    • Follow the instructions on the screen to install and activate the software.
    • (Optional) Insert the LabVIEW roboRIO Software Bundle DVD 2 if you want to install optional software for FPGA programming.
    Using NI Launcher
    Current Application
    Icon Location
    Pin to Action
    Finding All Programs
    NI LabVIEW roboRIO Software Bundle Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    National Instruments LabVIEW roboRIO Software Bundle will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of the LabVIEW roboRIO Software Bundle that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    Info Code
    LabWindows™/CVI™cvi_lifecycle
    © 2015 National Instruments. All rights reserved.
    375390A-01
    LabVIEW 2015 roboRIO Toolkit Readme
    June 2015
    This file contains important information about the LabVIEW roboRIO Toolkit, including system requirements, installation instructions, and known issues.
    Installing the USBLAN Driver in Microsoft Windows XP and Windows Server 2003
    Using the Universal Asynchronous Receiver/Transmitter (UART) and the ANSI/EIA-232 Standard (RS-232) Channels
    Accessing the LabVIEW for roboRIO Environment
    The LabVIEW roboRIO Toolkit provides you with tools for creating and deploying applications on the roboRIO.
    The roboRIO Toolkit has the following requirements:
    • (Optional for C Programming) LabVIEW 2015 Student, Full, or Professional Development System (32-bit)
    • (Optional for C Programming) LabVIEW 2015 Real-Time Module
    • At least 2 GB of disk space in addition to the LabVIEW-recommended minimum
    • 1 GB RAM
    • One of the following operating systems for application development:
    • The roboRIO Toolkit is compatible with only 32-bit LabVIEW. Install 32-bit LabVIEW even if you use a 64-bit operating system.
    • You might need more memory than the LabVIEW-recommended minimum depending on the size of the application you design in LabVIEW on the host computer.
    • Support for Windows Server 2003 R2 may require disabling physical address extensions (PAE). Refer to the National Instruments website for information about how this might affect your use of Windows Server 2003 R2 and what actions you might have to take.
    • The roboRIO Toolkit does not support the Windows Server non-R2 editions.
    Refer to the LabVIEW Readme for additional system requirements and supported operating systems for LabVIEW 2015.
    To install the roboRIO Toolkit using the LabVIEW roboRIO Software Bundle media, complete the following steps:
    • Select Install NI LabVIEW 2015 roboRIO Toolkit.
    • (Optional for C Programming) Click the drop-down arrow next to LabVIEW Support and select Install this feature to a local drive.
    • Click Next and follow the instructions on the screen to install the roboRIO Toolkit.
    To install the roboRIO Toolkit using the installer from ni.com/downloads, double-click the setup.exe file in the root directory of the roboRIO Toolkit installer and follow the instructions on the screen to install this product.
    You must manually install the USBLAN driver before using the roboRIO with Microsoft Windows XP and Windows Server 2003. Complete the following steps to install the USBLAN driver:
    Note  Before completing the following steps, make sure that you have downloaded and installed the KB 931125 package from Microsoft. For more information, refer to the Workarounds and Recommendations section of KB 65O8AH55, Why Are National Instruments Installers Failing on Windows XP and Server 2003 Machines?.
    • Connect the roboRIO to your computer after you install the roboRIO Toolkit.
    • In the Found New Hardware Wizard, select No, not this time and click Next.
    • Select Install from a list or specific location and click Next.
    • Select Include this location in the search and navigate to the National Instruments\CompactRIO\Staging\USBLAN\XP directory.
    • Click Next to install the USBLAN driver. Click Continue Anyway when you see the Windows Logo testing warning.
    • Click Finish.
    The USBLAN driver appears under Network adapters in the Windows Device Manager.
    You can access the software and documentation known issues list online. Refer to the National Instruments website for an up-to-date list of known issues in the LabVIEW roboRIO Toolkit.
    Visit ni.com/info and enter the Info Code exkvqg for information about using the UART and the RS-232 channels on the roboRIO.
    The roboRIO Toolkit provides the LabVIEW for roboRIO environment to allow you to easily access roboRIO-specific features and focus on developing roboRIO applications.
    You can use the Choose Environment Settings dialog box to change your LabVIEW environment. To display this dialog box, select Tools»Choose Environment from LabVIEW.
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help from LabVIEW, for information about the roboRIO Toolkit.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for the roboRIO Toolkit are located in the labview\examples\roboRIO directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    Using NI Launcher
    NI LabVIEW roboRIO Toolkit Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    National Instruments LabVIEW roboRIO Toolkit will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of the LabVIEW roboRIO Toolkit that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    375389A-01
    GMT+8, 2025-12-5 12:47
