查看: 2114|回复: 0
[NI软件产品] NI RFmx CDMA2000 3.0 Full Win32/64ENG完整版下载
    昨天 08:12
  • 签到天数: 3740 天
    连续签到: 67 天
    发表于 2022-3-28 18:40:15 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx CDMA2000
    发布日期:
    2019/1/18
    包含的版本:
    3.0完整版
    Windows 10
    Windows Server 2012 R2 64-bit
    Windows 8.1
    Windows 7 (SP1) 64-bit
    Windows 7 (SP1) 32-bit
    应用程序位数:
    32/64位
    语言:
    英文
    文件大小: 601186264 字节 (573.34 MB)
    修改日期: 2019-01-18 18:50
    MD5: 2d8eda33fc727e71b4dc3f0add2a8e44
    SHA1: 751fc5e6be5d2ee0d83f3ed47b14dc1bea202fdf
    SHA256: 6d26ed8d5b84ac2701c228d085860971d97c15c20cd79d158bc28dedc972ccb8
    CRC32: 4ea92de9
    注册登录视觉论坛,购买附件查看下载地址
    RFmx CDMA2000 3.0.txt (500 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-RFmx CDMA2k 3.0 Readme
    January 2019
    This file contains important information about NI-RFmx CDMA2k and is organized into the following sections:
    [url=]New Features[/url]
    NI-RFmx CDMA2k 3.0 includes the following new features:
    • Support for NI PXIe-5820
    • Support for self-calibration in the RFmx Soft Front Panel
    NI-RFmx CDMA2k 2.5 includes the following new features:
    • Addition of APIs to perform self-calibration and partial self-calibration
    • Addition of NI-RFmx Debug Configuration Utility to configure debug settings
    • Support for LabVIEW 2018 (32-bit and 64-bit)
    • Support for querying configuration attributes without calling RFmxCDMA2k Commit API
    NI-RFmx CDMA2k 2.3 includes the following new features:
    • Addition of code domain analysis (CDA) measurement
    • Addition of Slot Power measurement
    • Addition of Slot Phase measurement
    [url=]Installation Instructions[/url]
    Caution  Before you install NI-RFmx CDMA2k 3.0, ensure that you have uninstalled all related NI-RFmx 1.0 products.
    Caution   If you are using only RFmx LabVIEW Runtime products, NI recommends uninstalling all the RFmx Runtime products before installing a newer version of RFmx Runtime products.
    [url=]Supported Hardware[/url]Vector Signal Analyzers
    • NI PXIe-5663
    • NI PXIe-5663E
    • NI PXIe-5665
    • NI PXIe-5668R
    Vector Signal Transceivers
    • NI PXIe-5644R
    • NI PXIe-5645R
    • NI PXIe-5646R
    • NI PXIe-5840
    • NI PXIe-5820
    [url=]System Requirements[/url]Supported Operating Systems
    NI-RFmx CDMA2k 3.0 supports the following operating systems:
    Note  In 2016, NI-RFmx CDMA2k dropped support for Microsoft Windows 7 RTM (with no service pack), Windows Vista, Windows XP, and Windows Server 2003. NI-RFmx CDMA2k 3.0 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-RFmx CDMA2k 3.0 to an unsupported OS. Additionally, after installing NI-RFmx CDMA2k 3.0, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    For more information about the changes to our OS support for 2017, refer to KB 79UC78LS, Why Does my LabVIEW, LabWindows/CVI, Measurement Studio, or TestStand Built Installer Fail on Windows XP/Vista and Server 2003?.
    Note  NI-RFmx CDMA2k 3.0 and later does not support Windows Server non-R2 editions.
    Minimum Requirements
    • RAM—4 GB*
    • Microsoft .NET Framework 4.6.2
    [url=]Application Development Environments (ADEs)[/url]
    Note  You should install ADEs, such as NI LabVIEW or Microsoft Visual Studio®, before installing NI-RFmx CDMA2k. To add support for ADEs installed after installing NI-RFmx CDMA2k, modify your NI-RFmx CDMA2k installation or launch the NI-RFmx CDMA2k installer again.
    • NI LabVIEW 2015 SP1 f5 patch, 2016, 2017, or 2018
    Note  NI-RFmx CDMA2k will not operate correctly without the service packs and patches previously mentioned.
    Other Required Software
    [url=]Installed Software, Documentation, and Examples[/url]Installed Software
      • (64-bit OS) Program Files (x86)\National Instruments
      • (32-bit) windows\system32
    Item
    Installed Location
    Import Library files (32-bit)
    Import Library files (64-bit)
    C, .NET
    Examples\NI-RFmx\CDMA2k\Examples
    Examples\LabVIEW \examples\RFmx\CDMA2k
    Assemblies\DotNET\Assemblies\Current\NationalInstruments.RFmx.Cdma2kMX.Fx40.dll
    Select Start»All Programs»National Instruments»NI-RFmx CDMA2k»NI-RFmx CDMA2k Measurement Interactive Panel to launch the NI-RFmx CDMA2k Measurement Interactive Panel.
    [url=]Documentation[/url]
    Documentation for NI-RFmx CDMA2k is located at Start»All Programs»National Instruments»NI-RFmx CDMA2k»NI-RFmx CDMA2k Documentation. The documentation set is composed of the following documents.
    Document
    Format
    Description
    NI-RFmx CDMA2k HelpHTML/Windows HelpContains primary help content for NI-RFmx CDMA2k. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to NI-RFmx CDMA2k
    • A complete reference for all NI-RFmx CDMA2k programming functions and VIs
    NI-RFmx CDMA2k 3.0 ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    [url=]Accessing VIs and Functions[/url]
    NI-RFmx CDMA2k palette VIs are available from the Functions»Measurement I/O»NI-RFmx»CDMA2k palette.
    [url=]Finding Examples[/url]
    You can access all the installed NI-RFmx CDMA2k examples at Start»All Programs»National Instruments»NI-RFmx CDMA2k»NI-RFmx CDMA2k Examples.
    [url=]Product Security and Critical Updates[/url]
    [url=]Behavior Changes[/url]
    The following items are behavior changes in NI-RFmx CDMA2k 2.3.1 from NI-RFmx CDMA2k 2.3.
    • Changed the default value of the IQ Power Edge Source property to ""(empty string).
    • The alias 'default@CDMA2k' for the default signal name is accepted as a valid signal name in a selector string parameter.
    • LabVIEW built binaries using RFmx versions older than 2.2 are no longer supported.
    [url=]Known Issues[/url]
    No known issues.
    [url=]Bug Fixes[/url]
    The following items are the IDs and titles of a subset of issues fixed in NI-RFmx CDMA2k. This is not an exhaustive list of issues fixed in the current version of the NI-RFmx CDMA2k. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    The following items are changes in NI-RFmx CDMA2k 3.0 from NI-RFmx CDMA2k 2.5
    ID
    Fixed Issue
    706047Fixed an occasional crash which might occur on closing LabVIEW 2017 IDE or LabVIEW 2017 built applications that use RFmx.
    719203Fixed an issue where a timeout error was thrown when the digital trigger was configured when Using breakpoints in C/C++/.NET application was selected in the NI-PXIe-5840.
    The following items are changes in NI-RFmx CDMA2k 2.4 from NI-RFmx CDMA2k 2.3.1.
    ID
    Fixed Issue
    640495Fixed an issue where switching between measurements from an NI-RFmx cellular personality to Demod resulted in higher EVM on 5668R.
    The following items are changes in NI-RFmx CDMA2k 2.3.1 from NI-RFmx CDMA2k 2.3.
    ID
    Fixed Issue
    650095Fixed an issue where the RFmxInstr Close API did not abort a measurement in progress, but instead waited for the measurement to finish before closing.
    650083Fixed an issue with RFmxInstr Save All Configurations API to save the attribute configurations depending on the corresponding number of channels configured by user.
    648703Fixed an issue where passing NULL as selector string in a few C functions, caused the function to crash.
    The following items are changes in NI-RFmx CDMA2k 2.3 from NI-RFmx CDMA2k 2.2.
    ID
    Fixed Issue
    [url=]Increasing Available Memory For Your Application[/url]
    [url=]Automating the Installation of NI Products[/url]
    [url=]Using NI Software with Microsoft Windows 10[/url]
    Microsoft Windows 10 is the latest version of the Windows operating system and features significant changes compared to previous versions. Windows 10 introduces several new capabilities and also combines features from both Windows 7 and Windows 8.1. For more information about NI support for Windows 10, visit ni.com/windows10.
    [url=]Using NI Software with Microsoft Windows 8.1[/url]
    [url=]Legal Information[/url]
    © 2015–2019 National Instruments. All rights reserved.
    375524H-01
    GMT+8, 2025-12-13 04:52
