查看: 1365|回复: 0
[RTE运行引擎] NI RFmx CDMA2000 19.0 Runtime Win32ENG运行版下载
    昨天 16:17
  • 签到天数: 3506 天
    连续签到: 6 天
    发表于 2022-3-29 12:01:09 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx CDMA2000
    发布日期:
    2019/6/27
    包含的版本:
    19.0运行版
    Windows 10
    Windows Server 2012 R2 64-bit
    Windows 8.1
    Windows 7 (SP1) 64-bit
    Windows 7 (SP1) 32-bit
    应用程序位数:
    32位
    语言:
    英文
    文件大小: 573179904 字节 (546.63 MB)
    修改日期: 2019-07-17 15:35
    MD5: 2a36241dfccdaf358be6441ff5f7299e
    SHA1: 173942ac01ec5aac6c3035c43b233c5bd9156fa2
    SHA256: 360b7d98e86b657b93016a92d85ecb4b2c3305df725b2654384ace34e99a19ff
    CRC32: aa59a841
    注册登录视觉论坛,购买附件查看下载地址
    RFmx CDMA2000 19.0RTE32.txt (559 Bytes, 下载次数: 0, 售价: 5 元)
    RFmx CDMA2k 19.0 Readme
    June 2019
    This file contains important information about RFmx CDMA2k, including installation instructions, new features, bugs fixes, and known issues.
    [url=]Overview[/url]
    RFmx CDMA2k is an application software that provides simple access to the most advanced optimization techniques such as multimeasurement parallelism and multi-DUT measurements. The result is fast, high-quality measurements with minimal software development effort. Using this software, you can perform physical-layer analysis on CDMA2k cellular signals including MODACC, ACPR, CHP, OBW, QEVM, CDA, SlotPower, SlotPhase, and SEM. RFmx CDMA2k is completely interoperable with all RFmx APIs.
    [url=]New Features[/url]
    RFmx CDMA2k 19.0 includes the following new features:
    RFmx CDMA2k 3.0 includes the following new features:
    • Support for PXIe-5820
    • Support for self-calibration in the RFmx Soft Front Panel
    RFmx CDMA2k 2.5 includes the following new features:
    • Addition of APIs to perform self-calibration and partial self-calibration
    • Addition of RFmx Debug Configuration Utility to configure debug settings
    • Support for LabVIEW 2018 (32-bit and 64-bit)
    • Support for querying configuration attributes without calling RFmxCDMA2k Commit API
    RFmx CDMA2k 2.3 includes the following new features:
    • Addition of code domain analysis (CDA) measurement
    • Addition of Slot Power measurement
    • Addition of Slot Phase measurement
    Vector Signal Analyzers
    • PXIe-5663
    • PXIe-5663E
    • PXIe-5665
    • PXIe-5668
    • PXIe-5668 with PXIe-5698
    Vector Signal Transceivers
    • PXIe-5644
    • PXIe-5645
    • PXIe-5646
    • PXIe-5840
    • PXIe-5820
    • 4 GB RAM*
    RFmx CDMA2k 19.0 supports the following 64-bit operating systems:
    • Windows 10/8.11/7 SP12
    • Windows Server 2012 R21
    • Windows Server 2008 R2 SP12
    Note  In 2019, RFmx CDMA2k dropped support for all 32-bit Windows operating systems. RFmx CDMA2k will not install or run on an unsupported OS. Refer to RFmx CDMA2k Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021 for information about future OS support.
    RFmx CDMA2k supports the following application software versions, including service packs. You should install application software, such as LabVIEW, LabWindows/CVI or Microsoft Visual Studio®, before installing RFmx CDMA2k. To add support for application software installed after installing RFmx CDMA2k modify your RFmx CDMA2k installation or launch the RFmx CDMA2k installer again. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    [tr][/tr][/table][table]
    Versions Supported by RFmx CDMA2k
    LabVIEW2016, 2017, 2018 SP1 f4 patch, or 2019Required Software
    If you are using the RFmx CDMA2k .NET Class Library, .NET Framework 4.0 (minimum) is required. The RFmx CDMA2k .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0.
    To use the .NET API, you must install the .NET class libraries or the .NET wrapper in addition to the NI device driver. For information about versions of the .NET Framework and the drivers each supports, as well as the download location of the installer files, refer to National Instruments .NET Driver Support.
    NI installs RFmx CDMA2k using NI Package Manager. If you do not already have NI software installed, RFmx CDMA2k installs NI Package Manager to handle the installation of your NI software. Visit ni.com/info and enter the Info Code NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    [url=]Installed Software[/url]Installed Software
    Item
    Installed Location
    Import Library files (64-bit)
    C, .NET
    Examples\NI-RFmx\CDMA2k\Examples
    Examples\LabVIEW \examples\RFmx\CDMA2k
    Assemblies\DotNET\Assemblies\Current\NationalInstruments.RFmx.Cdma2kMX.Fx40.dll
    Select Start»All Programs»National Instruments»RFmx CDMA2k»RFmx CDMA2k Measurement Interactive Panel to launch the RFmx CDMA2k Measurement Interactive Panel.
    You can access all the installed RFmx CDMA2k examples at Start»All Programs»National Instruments»RFmx CDMA2k»RFmx CDMA2k Examples.
    Documentation for RFmx CDMA2k is located at Start»All Programs»National Instruments»RFmx CDMA2k»RFmx CDMA2k Documentation. The documentation set is composed of the following documents.
    Document
    Format
    Description
    RFmx CDMA2k HelpHTML/Windows HelpContains primary help content for RFmx CDMA2k. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to RFmx CDMA2k
    • A complete reference for all RFmx CDMA2k programming functions and VIs
    RFmx CDMA2k 19.0 ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    [url=]Accessing VIs[/url]
    RFmx CDMA2k palette VIs are available from the Functions»Measurement I/O»NI-RFmx»CDMA2k palette.
    [url=]Behavior Changes[/url]
    The following items are behavior changes in RFmx CDMA2k 19.0 from RFmx CDMA2k 3.0.
    The following items are behavior changes in RFmx CDMA2k 2.3.1 from RFmx CDMA2k 2.3.
    • Changed the default value of the I/Q Power Edge Source property to ""(empty string)
    • The alias 'default@CDMA2k' for the default signal name is accepted as a valid signal name in a selector string parameter
    • LabVIEW built binaries using RFmx versions older than 2.2 are no longer supported
    [url=]Bug Fixes[/url]
    The following items are the IDs and titles of a subset of issues fixed in RFmx CDMA2k. This is not an exhaustive list of issues fixed in the current version of the RFmx CDMA2k. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    The following items are changes in RFmx CDMA2k 3.0 from RFmx CDMA2k 2.5
    ID
    Fixed Issue
    706047Fixed an occasional crash which might occur on closing LabVIEW 2017 IDE or LabVIEW 2017 built applications that use RFmx.
    719203Fixed an issue where a timeout error was thrown when the digital trigger was configured when Using breakpoints in C/C++/.NET application was selected in the PXIe-5840.
    The following items are changes in RFmx CDMA2k 2.4 from RFmx CDMA2k 2.3.1.
    ID
    Fixed Issue
    640495Fixed an issue where switching between measurements from an RFmx cellular personality to Demod resulted in higher EVM on 5668R.
    The following items are changes in RFmx CDMA2k 2.3.1 from RFmx CDMA2k 2.3.
    ID
    Fixed Issue
    650095Fixed an issue where the RFmxInstr Close API did not abort a measurement in progress, but instead waited for the measurement to finish before closing.
    650083Fixed an issue with RFmxInstr Save All Configurations API to save the attribute configurations depending on the corresponding number of channels configured by user.
    648703Fixed an issue where passing NULL as selector string in a few C functions, caused the function to crash.
    RFmx CDMA2k will drop support for Windows 7 (64-bit) and Windows Server 2008 R2 starting in 2021. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    Info Code
    LabWindows/CVIcvi_lifecycle
    © 2015–2019 National Instruments. All rights reserved.
    375524J-01
    GMT+8, 2025-4-6 22:45
