查看: 1426|回复: 0
[RTE运行引擎] NI RFmx CDMA2000 20.0 Runtime Win64ENG运行版下载
  • 签到天数: 3602 天
    连续签到: 10 天
    发表于 2022-3-29 12:14:45 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx CDMA2000
    发布日期:
    2020/6/9
    包含的版本:
    20.0运行版
    Windows 7 (SP1) 64-bit
    Windows 8.1 64-bit
    Windows Server 2012 R2 64-bit
    应用程序位数:
    64位
    语言:
    英文
    文件大小: 582088704 字节 (555.12 MB)
    修改日期: 2020-06-09 15:48
    MD5: 28631a5f87977f5132b475980cf5f5ff
    SHA1: bcd91bd8d812f791781f96d9cea130b99abf18ff
    SHA256: d6bff6e9a53366c729af052826151138ace5331592f17fc80a2c6b0cb9454d5d
    CRC32: 31866c97
    注册登录视觉论坛,购买附件查看下载地址
    RFmx CDMA2000 20.0RTE64.txt (576 Bytes, 下载次数: 0, 售价: 5 元)
    RFmx CDMA2k 20.0 Readme
    June 2020
    RFmx CDMA2k Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021
    RFmx CDMA2k is an application software that provides simple access to the most advanced optimization techniques such as multimeasurement parallelism and multi-DUT measurements. The result is fast, high-quality measurements with minimal software development effort. Using this software, you can perform physical-layer analysis on CDMA2k cellular signals including MODACC, ACPR, CHP, OBW, QEVM, CDA, SlotPower, SlotPhase, and SEM. RFmx CDMA2k is completely interoperable with all RFmx APIs.
    RFmx CDMA2k 20.0 includes the following new features:
    RFmx CDMA2k 19.1 includes the following new features:
    RFmx CDMA2k 19.0 includes the following new features:
    RFmx CDMA2k 3.0 includes the following new features:
    • Support for PXIe-5820
    • Support for self-calibration in the RFmx Soft Front Panel
    Vector Signal Analyzers
    • PXIe-5663
    • PXIe-5663E
    • PXIe-5665
    • PXIe-5668
    • PXIe-5668 with PXIe-5698
    Vector Signal Transceivers
    • PXIe-5820
    • PXIe-5840
    • PXIe-5841
    • PXIe-5644
    • PXIe-5645
    • PXIe-5646
    • PXIe-5841 with PXIe-5655
    RFmx CDMA2k 20.0 supports the following 64-bit operating systems:
    • Windows 10/8.1 1 /7 SP1 2
    • Windows Server 2012 R2 1
    Note   In 2019, RFmx CDMA2k dropped support for all 32-bit Windows operating systems. RFmx CDMA2k will not install or run on an unsupported OS. Refer to RFmx CDMA2k Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021 for information about future OS support.
    Note   In 2016, RFmx CDMA2k dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. You cannot deploy or distribute applications that use RFmx CDMA2k 20.0 to an unsupported OS. Additionally, after installing RFmx CDMA2k 20.0, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    RFmx CDMA2k supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx CDMA2k. To add support for application software installed after installing RFmx CDMA2k modify your RFmx CDMA2k installation or launch the RFmx CDMA2k installer again. If you are not using NI application software, refer to  Microsoft Visual Studio Support.
    Application SoftwareVersions Supported by RFmx CDMA2k
    LabVIEW2017, 2018 SP1 f4 patch, 2019 SP1 f3 patch, 2020
    NI installs RFmx CDMA2k using NI Package Manager. If you do not already have NI software installed, RFmx CDMA2k installs NI Package Manager to handle the installation of your NI software. Visit ni.com/info and enter the Info Code NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • Use the serial number that is included with your software to activate RFmx CDMA2k. For more information on RFmx CDMA2k activation, refer to National Instruments Software Activation .
    ItemInstalled Location
    Header files\Shared\ExternalCompilerSupport\C\include
    Import Library files (64-bit)
    Assemblies\DotNET\Assemblies\Current\NationalInstruments.RFmx.Cdma2kMX.Fx40.dll
    Select Start » All Programs » National Instruments » RFmx CDMA2k » RFmx Soft Front Panel to launch the RFmx Soft Front Panel (64-bit).
    RFmx CDMA2k palette VIs are available from the Functions » Measurement I/O » NI-RFmx » CDMA2K palette.
    Documentation for RFmx CDMA2k is located at Start » All Programs » National Instruments » RFmx CDMA2k » RFmx CDMA2k Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    RFmx CDMA2k HelpHTML/Windows HelpContains primary help content for RFmx CDMA2k. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to RFmx CDMA2k
    • A complete reference for all RFmx CDMA2k programming functions and VIs
    RFmx CDMA2k 20.0 ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    You can access all the installed RFmx CDMA2k examples at Start » All Programs » National Instruments » RFmx CDMA2k » RFmx CDMA2k Examples.
    The following items are behavior changes in RFmx CDMA2k 19.0 from RFmx CDMA2k 3.0.
    You can access the RFmx CDMA2k known issues list online at RFmx CDMA2k 20.0 Known Issues.
    You can access the RFmx CDMA2k bug fix list online at RFmx CDMA2k 20.0 Bug Fixes.
    RFmx CDMA2k will drop support for Windows 7 (64-bit) and Windows Server 2008 R2 starting in 2021. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    © 2015–2020 National Instruments. All rights reserved.
    375524L-01
    GMT+8, 2025-7-23 12:14
