查看: 1694|回复: 0
[RTE运行引擎] NI RFmx CDMA2000 20.7.1 Runtime x64Win10 64bitENG运行版下载
    3 小时前
  • 签到天数: 3539 天
    连续签到: 9 天
    发表于 2022-3-29 12:31:59 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx CDMA2000
    发布日期:
    2021/7/22
    包含的版本:
    20.7.1运行版
    应用程序位数:
    64位
    语言:
    英文
    文件大小: 611155968 字节 (582.84 MB)
    修改日期: 2021-07-22 02:01
    MD5: 6a1b618337cdea55fc1e8d0d7340822d
    SHA1: 95e0597f73bd4932f400ca0d5a9ce519f04b9138
    SHA256: 10c99e5bc0128e9af1bb78e923dbf5155fb2c2a2dce3ec371788fa87728ba782
    CRC32: f22a55ae
    注册登录视觉论坛,购买附件查看下载地址
    RFmx CDMA2000 20.7.1RTE64.txt (578 Bytes, 下载次数: 0, 售价: 5 元)
    RFmx CDMA2k 20.7.1 Readme
    July 2021
    [url=]Overview[/url]
    RFmx CDMA2k is an application software that provides simple access to the most advanced optimization techniques such as multimeasurement parallelism and multi-DUT measurements. The result is fast, high-quality measurements with minimal software development effort. Using this software, you can perform physical-layer analysis on CDMA2k cellular signals including MODACC, ACPR, CHP, OBW, QEVM, CDA, SlotPower, SlotPhase, and SEM. RFmx CDMA2k is completely interoperable with all RFmx APIs.
    [url=]New Features[/url]
    RFmx CDMA2k 20.0 includes the following new features:
    RFmx CDMA2k 19.1 includes the following new features:
    RFmx CDMA2k 19.0 includes the following new features:
    RFmx CDMA2k 3.0 includes the following new features:
    • Support for PXIe-5820
    • Support for self-calibration in the RFmx Soft Front Panel
    [url=]Supported Hardware[/url]
    Vector Signal Analyzers
    • PXIe-5663
    • PXIe-5663E
    • PXIe-5665
    • PXIe-5668
    • PXIe-5668 with PXIe-5698
    Vector Signal Transceivers
    • PXIe-5820
    • PXIe-5840
    • PXIe-5841
    • PXIe-5644
    • PXIe-5645
    • PXIe-5646
    • PXIe-5841 with PXIe-5655
    [url=]System Requirements[/url]
    [url=]Supported Operating Systems[/url]
    RFmx CDMA2k 20.7.1 supports the following 64-bit operating systems:
    Note    RFmx CDMA2k no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx CDMA2k 20.7.1 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx CDMA2k 20.7.1 to an unsupported OS. Additionally, after installing RFmx CDMA2k 20.7.1, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    [url=]Application Software Support[/url]
    RFmx CDMA2k supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx CDMA2k. If you are not using NI application software, refer to  Microsoft Visual Studio Support.
    Application SoftwareVersions Supported by RFmx CDMA2k
    LabVIEW2017, 2018 SP1 f4 patch, 2019 SP1 f3 patch, or 2020 SP1
    [url=]Required Software[/url]
    [url=]Microsoft Visual Studio Support[/url]
    [url=]Installation Instructions[/url]
    • If Windows Update is enabled, the installation process might hang if Windows Update interferes with the installation of Microsoft Visual C++ 2015 Run-Time. Visit ni.com/r/exjq43for more information and steps to resolve this issue.
    [url=]Installed Software[/url]
    ItemInstalled Location
    Header files\Shared\ExternalCompilerSupport\C\include
    Import Library files (64-bit)
    Assemblies\DotNET\Assemblies\Current\NationalInstruments.RFmx.Cdma2kMX.Fx40.dll
    Select Start » All Programs » National Instruments » RFmx CDMA2k » RFmx Soft Front Panel to launch the RFmx Soft Front Panel (64-bit).
    [url=]Accessing the API[/url]
    RFmx CDMA2k palette VIs are available from the Functions » Measurement I/O » NI-RFmx » CDMA2K palette.
    Documentation for RFmx CDMA2k is located at Start » All Programs » National Instruments » RFmx CDMA2k » RFmx CDMA2k Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    RFmx CDMA2k HelpHTML/Windows HelpContains primary help content for RFmx CDMA2k. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to RFmx CDMA2k
    • A complete reference for all RFmx CDMA2k programming functions and VIs
    RFmx CDMA2k 20.7.1 ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    You can access all the installed RFmx CDMA2k examples at Start » All Programs » National Instruments » RFmx CDMA2k » RFmx CDMA2k Examples.
    [url=]Product Security and Critical Updates[/url]
    [url=]Behavior Changes[/url]
    The following are the behavior changes in RFmx RFmx CDMA2k 20.7 from RFmx RFmx CDMA2k 20.6.
    The following items are behavior changes in RFmx CDMA2k 19.0 from RFmx CDMA2k 3.0.
    [url=]Known Issues[/url]
    You can access the RFmx CDMA2k known issues list online at RFmx CDMA2k 20.7.1 Known Issues.
    [url=]Bug Fixes[/url]
    You can access the RFmx CDMA2k bug fix list online at RFmx CDMA2k 20.7.1 Bug Fixes.
    [url=]Automating the Installation of NI Products[/url]
    [url=]Using NI Software with Microsoft Windows 10[/url]
    © 2015–2021 National Instruments Corporation. All rights reserved.
    375524P-01
    GMT+8, 2025-5-14 10:57
