查看: 2518|回复: 0
[NI软件套件] Embedded Control and Monitoring Software Suite Fall 2021 x64Win10 64bitENG 嵌入式控制和监控软件套件2021秋季英文版ECMSS21.5
发表于 2022-3-31 16:34:12 | 显示全部楼层 |阅读模式
Embedded Control and Monitoring Software Suite是一组用于工业设备或设计智能机器的软件和工具集合。
Embedded Control and Monitoring Software Suite包含了LabVIEW以及推荐用于开发嵌入式控制和监测系统的附加工具。该套件可帮助您在设计周期的每个阶段,从建模和仿真到原型设计、验证和部署,都能通过一个高度优化的工具链快速响应系统不断变化的需求。
套件包含:
LabVIEW专业版
LabVIEW Real-Time模块
LabVIEW FPGA模块
LabVIEW MathScript模块
LabVIEW高级信号处理工具包
LabVIEW数字滤波器设计工具包
视觉采集软件
视觉开发模块
LabWindows/CVI执行评测工具包
LabWindows/CVI Real-Time模块
LabWindows/CVI SQL工具包
LabWindows/CVI完整版
Measurement Studio企业版
发布日期
2022/2/16
包含的版本
Fall 2021
受支持的操作系统
语言
English
校验和
2021Fall 64Eng
文件大小: 47035314176 字节 (43.81 GB)
修改日期: 2022-02-17 00:09
MD5: 5649ceb9d40c5de0903ef78c85d1efff(官方正确)
SHA1: e30d7bab554f72327ffb4968a57bd345fc76100c
SHA256: fb30139790d3f018cc50b0d7d034c7ae34c209a5306a092c04c5c0a4f9caa5e1
CRC32: 6253896f
注册登录视觉论坛,购买附件查看下载地址
Embedded Control and Monitoring Software Suite Fall 2021 Readme
February 2022
This file contains installation instructions and compatibility information for Embedded Control and Monitoring Software Suite.
Installation InstructionsInstalling and Activating the Embedded Control and Monitoring Software Suite
NI installs the Embedded Control and Monitoring Software Suite using NI Package Manager. If you do not already have NI software installed, the Embedded Control and Monitoring Software Suite installs NI Package Manager to handle the installation of your NI software. Visit ni.com/r/NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
  • Use the serial number that is included with your software to activate the Embedded Control and Monitoring Software Suite. For more information on the Embedded Control and Monitoring Software Suite activation, refer to NI Software Activation.
Complete the following steps to install products using the Embedded Control and Monitoring Software Suite media.
  • Insert the Embedded Control and Monitoring Software Suite installation media.
Save the media in order to modify or repair your installation or to distribute NI software with your custom-built installers.
Installing LabVIEW Add-Ons
Installing LabVIEW add-ons, such as modules and toolkits, from the Embedded Control and Monitoring Software Suite media ensures compatibility. Some versions of LabVIEW add-ons that are not found on the Embedded Control and Monitoring Software Suite media may not work with the version of LabVIEW included in this release. Installing an incompatible add-on might cause some features in the add-on or LabVIEW to behave incorrectly.
Products Included on the Embedded Control and Monitoring Software Suite Media
The following products are included on the Embedded Control and Monitoring Software Suite media. Refer to the readme of each product for information including system requirements, installation, activation, known issues, and bug fixes.
Note  Some drivers included with previous versions of the Embedded Control and Monitoring Software Suite are not included with this release. Visit ni.com/downloads for the latest driver versions.
Application Software
Version
Bitness
LabVIEW2021 SP132-bit and 64-bit
LabVIEW NXG5.1.064-bit
Add-Ons
Version
Bitness
JKI VI Package Manager2021 SP132-bit and 64-bit
LabVIEW Advanced Signal Processing Toolkit202132-bit and 64-bit
LabVIEW Desktop Execution Trace Toolkit202132-bit and 64-bit
LabVIEW Digital Filter Design Toolkit202132-bit and 64-bit
LabVIEW FPGA Compilation Tool for ISE 14.7202032-bit and 64-bit
LabVIEW FPGA Compilation Tool for Vivado 2019.1202064-bit
LabVIEW FPGA Compile Farm Toolkit202132-bit and 64-bit
LabVIEW FPGA Module202132-bit
LabVIEW MathScript Module202132-bit
LabVIEW NXG FPGA Module5.1.064-bit
LabVIEW NXG Real-Time Module5.1.064-bit
LabVIEW Real-Time Module202132-bit and 64-bit
LabVIEW Unit Test Framework Toolkit202132-bit and 64-bit
LabVIEW VI Analyzer Toolkit202132-bit and 64-bit
NI LabVIEW OPC UA Toolkit202132-bit and 64-bit
Vision Development Module202132-bit and 64-bit
Driver Software
Version
Bitness
FPGA Interface C API20.0.032-bit and 64-bit
FlexRIO with Integrated I/O21.5.032-bit and 64-bit
FlexRIO with Modular I/O21.5.032-bit and 64-bit
NI CompactRIO21.0.032-bit and 64-bit
NI R Series Multifunction RIO21.5.032-bit and 64-bit
NI-DAQmx21.3.032-bit and 64-bit
NI-IMAQ21.0.032-bit and 64-bit
NI-IMAQ I/O21.0.032-bit and 64-bit
NI-IMAQdx21.0.032-bit and 64-bit
NI-Industrial Communications for EtherNet/IP21.0.032-bit and 64-bit
NI-Serial21.5.032-bit and 64-bit
NI-Sync21.3.032-bit and 64-bit
NI-VISA21.5.032-bit and 64-bit
NI-XNET21.5.032-bit and 64-bit
Note  The LabVIEW Professional Development System installs the LabVIEW Database Connectivity Toolkit and the LabVIEW Report Generation Toolkit.
To compare the products included in NI Software Suites, including the Embedded Control and Monitoring Software Suite, refer to the NI Software Portfolio.
Embedded Control and Monitoring Software Suite no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport.
© 2013–2022 National Instruments Corporation. All rights reserved.
377939F-01
QQ|LabVIEW视觉
GMT+8, 2026-4-8 13:24
