查看: 1823|回复: 0
[NI软件产品] NI RFmx SpecAn 1.0 Full Win32/64ENG RFmx频谱分析仪1.0完整版
  • 签到天数: 3723 天
    连续签到: 50 天
    发表于 2022-4-6 11:14:40 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx SpecAn
    RFmx SpecAn为时域和频谱分析提供互动和自动测量。
    发布日期:
    2014/11/10
    包含的版本:
    1.0完整版
    Windows 8.1(32-bit and 64-bit)
    Windows 8(32-bit and 64-bit)
    Windows 7(32-bit and 64-bit)
    Windows Server 2008 R2 64-bit
    语言:
    英文
    应用程序位数:
    32/64位
    文件大小: 269161248 字节 (256.69 MB)
    修改日期: 2014-11-10 23:51
    MD5: b1f3695c1b2e29339a5396e68aa4bd61
    SHA1: f0664a02667f15757138ab556b97e8078dcd3ed0
    SHA256: 4197f6c5692b485f1e931796a9d7a79a4b248d0b85d99d89b9cdacded7ce07b3
    CRC32: 60a54146
    注册登录视觉论坛用户,购买附件查看下载地址
    RFMx SpecAn1.0.txt (505 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-RFmx SpecAn Readme
    Version 1.0
    Thank you for using NI-RFmx SpecAn. This file contains important information about NI-RFmx SpecAn and is organized into the following sections:
    Accessing VIs and Functions
    Uninstalling/Modifying NI-RFmx SpecAn
    • NI PXIe-5663
    • NI PXIe-5663E
    • NI PXIe-5665
    Vector Signal Transceivers
    • NI PXIe-5644R
    • NI PXIe-5645R
    • NI PXIe-5646R
    NI-RFmx SpecAn 1.0 supports the following operating systems:
    Note  NI-RFmx SpecAn 1.0 and later does not support Windows Server non-R2 editions.
    Minimum System Requirements
    • RAM—2 GB*
    • Windows 8.1/8/7, with all available critical updates and service packs
    Recommended System
    • RAM—4 GB*
    Note  You should install ADEs, such as NI LabVIEW, before installing NI-RFmx SpecAn. To add support for ADEs installed after installing NI-RFmx SpecAn, modify your NI-RFmx SpecAn installation or launch the NI-RFmx SpecAn installer again.
    • NI LabVIEW 2012 SP1 (32-bit and 64-bit) f9 patch, 2013 SP1 (32-bit and 64-bit) f3 patch
    Note  NI-RFmx SpecAn will not operate correctly without the service packs and patches previously mentioned.
    Other Required Software
    NI-RFSA 2.9 or later
      • Windows 8.1 (32-bit)/8 (32-bit)/7 (32-bit): Program Files\National Instruments
      • Windows 8.1 (64-bit)/8 (64-bit) /7 (64-bit): Program Files (x86)\National Instruments
      • Windows 8.1/8/7: \LabVIEW
      • Windows 8.1/8/7: Users\Public\Documents\National Instruments
      • Windows 8.1 (32-bit)/8 (32-bit)/7 (32-bit): windows\system32
        • 32-bit DLL: windows\SysWow64
        • 64-bit DLL: windows\system32
    ItemInstalled Location on Windows 8.1/8/7
    DLL
    NI-RFmx SpecAn VIs\vi.lib\RFmx\SpecAn
    NI-RFmx SpecAn Examples\RFmx\SpecAn\Examples
    Documentation for NI-RFmx SpecAn is located at Start»All Programs»National Instruments»NI-RFmx SpecAn»RFmx SpecAn Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    NI-RFmx SpecAn HelpHTML/Windows HelpContains primary help content for NI-RFmx SpecAn. The help is an HTML version of a traditional user manual that includes the following information:
    • An introduction to NI-RFmx SpecAn
    • A complete reference for all NI-RFmx SpecAn programming VIs
    NI-RFmx SpecAn ReadmeHTML (this document)Contains information about supported hardware and operating systems, and legal notices.
    NI-RFmx SpecAn palette VIs are available from the Functions»Measurement I/O»NI-RFmx»SpecAn palette.
    You can access all the installed NI-RFmx SpecAn examples for LabVIEW at Start»All Programs»National Instruments»NI-RFmx SpecAn»RFmx SpecAn Examples.
    • Select NI-RFmx SpecAn 1.0 from the dialog box that appears.
    For Windows 8.1/8, complete the following steps:
    • Select Programs»Programs and Features.
    • Click the Uninstall button.
    As part of the NI-RFmx SpecAn 1.0 installation, the following software is installed. To completely remove the NI-RFmx SpecAn 1.0 installation from your system, you must also remove the following package:
    • NI-RFmx SpecAn Runtime 1.0 for LabVIEW
    You can access the software and documentation known issues list online. Refer to the NI-RFmx SpecAn 1.0 Known Issues at ni.com for an up-to-date list of known issues in NI-RFmx SpecAn 1.0.
    Using NI Launcher
    For convenience, you can pin your most-used NI applications, such as MAX, to either the Start screen or the Taskbar on the desktop, as necessary.
    Finding All Programs
    © 2014 National Instruments. All rights reserved.
    GMT+8, 2025-11-25 10:56
