查看: 2046|回复: 0
[NI软件产品] NI RFmx SpecAn 1.1 Full Win32/64ENG RFmx频谱分析仪1.1完整版
  • 签到天数: 3723 天
    连续签到: 50 天
    发表于 2022-4-6 11:21:26 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx SpecAn
    RFmx SpecAn为时域和频谱分析提供互动和自动测量。
    发布日期:
    2014/11/14
    包含的版本:
    1.1完整版
    Windows 8.1(32-bit and 64-bit)
    Windows 8(32-bit and 64-bit)
    Windows 7(32-bit and 64-bit)
    Windows Server 2008 R2 64-bit
    语言:
    英文
    应用程序位数:
    32/64位
    文件大小: 603317024 字节 (575.37 MB)
    修改日期: 2014-11-14 05:35
    MD5: a7336aa2041a7b93a7c0a8794e1b8ca6
    SHA1: ed9f27d6230366c88103be272cb32ec378edb550
    SHA256: ef582131c4906c2decf881f02157ffcaeee19366931a6a2ec4179f55f9f30c77
    CRC32: e5e132fc
    注册登录视觉论坛用户,购买附件查看下载地址
    RFMx SpecAn1.1.txt (505 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-RFmx SpecAn 1.1 Readme
    September 2014
    Thank you for using NI-RFmx SpecAn. This file contains important information about NI-RFmx SpecAn and is organized into the following sections:
    Accessing VIs and Functions
    Uninstalling/Modifying NI-RFmx SpecAn
    NI-RFmx SpecAn 1.1 includes support for C/CVI and .NET.
    Installation InstructionsCaution  Before you install NI-RFmx SpecAn 1.1, ensure that you have uninstalled all related NI-RFmx SpecAn 1.0 and NI-RFmx Demod 1.0 products.
    • NI PXIe-5663
    • NI PXIe-5663E
    • NI PXIe-5665
    Vector Signal Transceivers
    • NI PXIe-5644R
    • NI PXIe-5645R
    • NI PXIe-5646R
    NI-RFmx SpecAn 1.1 supports the following operating systems:
    Note  NI-RFmx SpecAn 1.1 and later does not support Windows Server non-R2 editions.
    Minimum System Requirements
    • RAM—2 GB*
    • Windows 8.1/8/7, with all available critical updates and service packs
    Recommended System
    • RAM—4 GB*
    Note  You should install ADEs, such as NI LabVIEW, NI LabWindows/CVI or Microsoft Visual Studio®, before installing NI-RFmx SpecAn. To add support for ADEs installed after installing NI-RFmx SpecAn, modify your NI-RFmx SpecAn installation or launch the NI-RFmx SpecAn installer again.
    • 2012 SP1 (32-bit and 64-bit) f9 patch, 2013 (32-bit and 64-bit) f5 patch, 2014 (32-bit and 64-bit) f1 patch
    • NI LabWindows/CVI 8.5 or later
    • Visual Studio 2010 SP1 or later
    Note  NI-RFmx SpecAn will not operate correctly without the service packs and patches previously mentioned.
    Other Required Software
    NI-RFSA 2.9 or later
      • Windows 8.1 (32-bit)/8 (32-bit)/7 (32-bit): Program Files\National Instruments\MeasurementStudioVS2010
      • Windows 8.1 (64-bit)/8 (64-bit) /7 (64-bit): Program Files (x86)\National Instruments\MeasurementStudioVS2010
      • Windows 8.1/8/7: Users\Public\Documents\National Instruments
      • Windows 8.1 (32-bit)/8 (32-bit)/7 (32-bit): windows\system32
        • 32-bit DLL: windows\SysWow64
        • 64-bit DLL: windows\system32
    ItemInstalled Location on Windows 8.1/8/7
    Function Panels
    \Shared\CVI\Bin\niRFmxSpecAn.lfp
    \Shared\CVI\Bin\niRFmxInstr.lfp
    Import Library files
    Windows 8.1 (32-bit)/8 (32-bit)/7 (32-bit):\Shared\ExternalCompilerSupport\C\include
    Windows 8.1 (64-bit)/8 (64-bit)/7 (64-bit):
    • 32-bit installation: \Shared\ExternalCompilerSupport\C\lib32\msvc
    • 64-bit installation: \Shared\ExternalCompilerSupport\C\lib64\msvc
    C, .NET, TestStand
    Examples\RFmx\SpecAn\Examples
    CVI
    Examples\CVI\samples\RFmx\SpecAn
    Examples\LabVIEW \examples\RFmx\SpecAn\mx
    Documentation for NI-RFmx SpecAn is located at Start»All Programs»National Instruments»NI-RFmx SpecAn»RFmx SpecAn Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    NI-RFmx SpecAn HelpHTML/Windows HelpContains primary help content for NI-RFmx SpecAn. The help is an HTML version of a traditional user manual that includes the following information:
    • An introduction to NI-RFmx SpecAn
    • A complete reference for all NI-RFmx SpecAn programming functions
    NI-RFmx SpecAn 1.1 ReadmeHTML (this document)Contains information about supported hardware and operating systems, and legal notices.
    NI-RFmx SpecAn palette VIs are available from the Functions»Measurement I/O»NI-RFmx palette.
    NI-RFmx SpecAn functions are available in LabWindows/CVI from the Library»RFmx SpecAn Library menu.
    You can access all the installed NI-RFmx SpecAn examples at Start»All Programs»National Instruments»NI-RFmx SpecAn»RFmx SpecAn Examples.
    • Select NI-RFmx SpecAn 1.1 from the dialog box that appears.
    For Windows 8.1/8, complete the following steps:
    • Click the Uninstall button.
    As part of the NI-RFmx SpecAn 1.1 installation, the following software is installed. To completely remove the NI-RFmx SpecAn 1.1 installation from your system, you must also remove the following package:
    • NI-RFmx SpecAn Runtime 1.1 for LabVIEW
    • NI-RFmx SpecAn Runtime 1.1 for C/.NET
    • NI-RFmx SpecAn Runtime 1.1 (64-bit) for C/.NET
    You can access the software and documentation known issues list online. Refer to the NI-RFmx SpecAn 1.0 and 1.1 Known Issues at ni.com for an up-to-date list of known issues in NI-RFmx SpecAn 1.1.
    The following items are changes in NI-RFmx SpecAn 1.1 from NI-RFmx SpecAn 1.0.
    484980Fixed an issue in which the RFmxSpecAn Auto Level VI was not able to handle RF front end attributes.
    488782Fixed an issue in which an error was not returned when the start frequency was equal to the stop frequency for Spur and SEM measurements.
    484136Fixed an issue in which the waveform duration and delay in zero span were incorrect when RBW was set to a value less than 2 MHz.
    487678Fixed an issue in which incorrect power was reported when the span was less than the integration bandwidth for CHP measurement.
    Using NI Launcher
    For convenience, you can pin your most-used NI applications, such as MAX, to either the Start screen or the Taskbar on the desktop, as necessary.
    Finding All Programs
    © 2014 National Instruments. All rights reserved.
    374847A-01
    GMT+8, 2025-11-25 10:55
