查看: 1603|回复: 0
[RTE运行引擎] NI RFmx SpecAn 2.2 Runtime Win64ENG RFmx频谱分析仪2.2运行版
    昨天 09:46
  • 签到天数: 3643 天
    连续签到: 5 天
    发表于 2022-4-6 11:45:30 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx SpecAn
    RFmx SpecAn为时域和频谱分析提供互动和自动测量。
    发布日期:
    2016/12/18
    包含的版本:
    2.2运行版
    Windows 10 (64-bit)
    Windows 8.1 (64-bit)
    Windows 8.0 (64-bit)
    Windows 7(SP1) (64-bit)
    语言:
    英文
    应用程序位数:
    64位
    文件大小: 267681784 字节 (255.28 MB)
    修改日期: 2016-12-09 00:10
    MD5: 3622f6f6fa77017cc71c1e8455d9b734
    SHA1: acadef7117e47f729d44c0cffc25e7d992e12172
    SHA256: 9286639863a796cec62e56b585a16b8c53e16e1b1de00ff82f11f9a9ad33c069
    CRC32: b0eab77e
    注册登录视觉论坛用户,购买附件查看下载地址
    RFMx SpecAn2.2RTE64.txt (523 Bytes, 下载次数: 0, 售价: 5 圆)
    NI-RFmx SpecAn 2.2 Readme
    December 2016
    Thank you for using NI-RFmx SpecAn. This file contains important information about NI-RFmx SpecAn and is organized into the following sections:
    Activation Instructions for NI-RFmx Noise Figure License
    Accessing VIs and Functions
    Uninstalling/Modifying NI-RFmx SpecAn
    NI-RFmx SpecAn 2.2 includes the following new features:
    • Addition of noise figure (NF) measurement using Y-Factor and Cold Source methods.
    • Addition of intermodulation (IM) distortion measurements.
    • Support for noise compensation in Spectrum measurement.
    • Support for the linear LUT type in DPD.
    • Support for ENBW on RBW filter bandwidth definition.
    • Addition of Allan Deviation result in frequency counter (FCnt) measurement.
    • Support for LO leakage avoidance when using vector signal transciever as the analyzer.
    • Support for Limited Configuration Change when sweeping frequency and reference level in test applications.
    • Addition of advanced instrument attributes to measurement interactive panel.
    NI-RFmx SpecAn 2.1 f4 includes the following bug fixes and updates:
    • Fixed an issue where NI-RFmx was crashing when the memory usage in a process increased beyond 2 GB.
    • Recommended IQ Pre Trigger Time property now returns a positive number instead of a negative number. This property is applicable when NI-RFmx is used in the Analysis-Only mode.
    • For the Analysis-Only mode, user needs to adjust the t0 value of the I/Q waveforms according to pre-trigger samples present in the waveform before passing the waveform to the Analyze (IQ) function.
    NI-RFmx SpecAn 2.1 includes support for the Hardware Agnostic Mode that allows you to perform measurements on a user-specified I/Q or Spectrum waveform.
    NI-RFmx SpecAn 2.0 includes the following new features:
    • Addition of I/Q measurement
    • Support for multicarrier CHP measurements
    • Support for offset frequency definition in ACP and SEM measurements
    • Support for 3 dB, 6 dB, and bin width RBW definitions for spectral measurements
    • Support for detection of spurs with peak excursion as criteria in spur measurements and when using peak search with markers
    • Support for Magnitude Only and Phase Only correction for memory polynomial DPD models
    • Support for average, linear, and peak gain targets in DPD
    • Improved memory and speed performance of DPD measurements and composite measurements
    • Support for LabVIEW 2015 (32-bit and 64-bit)
    NI-RFmx SpecAn 1.2 includes the following new features:
    • Support for NI 5668R
    • Addition of AMPM and DPD measurements
    NI-RFmx SpecAn 1.1 includes support for C, LabWindows™/CVI™, and .NET.
    Caution  Before you install NI-RFmx SpecAn 2.2, ensure that you have uninstalled all related NI-RFmx 1.0 products.
    NI-RFmx drivers requires that all the installed driver versions remain the same for proper functionality. This requirement is because NI-RFmx drivers share components. If driver incompatibilities exist, they are reported through a dialog box after installation. You can also use the Version Compatibility Checker utility to manually check for version incompatibilities. Refer to the Installed Software, Documentation, and Examples section for more information about the installed location of the Version Compatibility Checker utility.
    Note  Some of the installed NI-RFmx SpecAn .NET examples require NI-RFSA .NET Class Libraries or NI-RFSG .NET Class Libraries. For these examples to build and run successfully, install NI-RFSA .NET Class Libraries or NI-RFSG .NET Class Libraries before or after installing NI-RFmx SpecAn.
    The Noise Figure measurement requires license activation. To evaluate or activate the Noise Figure license, you must install the Noise Figure license, which is a separate installer from the RFmx SpecAn installer. If you install the Noise Figure license but do not activate it, you will have 30 days from the first time you use the measurement to evaluate it.
    • NI PXIe-5663
    • NI PXIe-5663E
    • NI PXIe-5665
    • NI PXIe-5668R
    Vector Signal Transceivers
    • NI PXIe-5644R
    • NI PXIe-5645R
    • NI PXIe-5646R
    • NI PXIe-5840
    NI-RFmx SpecAn 2.2 supports the following operating systems:
    Note  NI-RFmx SpecAn 2.2 does not support Windows Server non-R2 editions.
    Minimum Requirements
    • RAM—2 GB*
    Recommended System
    • RAM—4 GB*
    Note  You should install ADEs, such as NI LabVIEW, NI LabWindows/CVI, or Microsoft Visual Studio®, before installing NI-RFmx SpecAn. To add support for ADEs installed after installing NI-RFmx SpecAn, modify your NI-RFmx SpecAn installation or launch the NI-RFmx SpecAn installer again.
    • NI LabVIEW 2013 SP1 f6 patch, 2014 SP1 f5 (32-bit) patch, 2014 SP1 f6 (64-bit) patch, 2015 SP1 f5 patch, or 2016
    • NI LabWindows/CVI 2010 or later
    Note  NI-RFmx SpecAn does not operate correctly without the service packs and patches previously mentioned installed.
    Other Required Software
    • NI-RFSG 14.0.1 or later
    • NI-RFSG Playback Library 2.2 or later (for DPD examples)
      • (64-bit) Program Files (x86)\National Instruments for 32-bit programs and Program Files\National Instruments for 64-bit programs
      • (32-bit) windows\system32
    ItemInstalled Location
    Function Panels
    \Shared\CVI\Bin\niRFmxSpecAn.lfp
    \Shared\CVI\Bin\niRFmxInstr.lfp
    Import Library files (32-bit)
    Import Library files (64-bit)
    C, .NET, NI TestStand
    Examples\RFmx\SpecAn\examples
    LabWindows/CVI
    Examples\CVI\samples\RFmx\SpecAn
    Examples\LabVIEW \examples\RFmx\SpecAn
    Select Start»All Programs»National Instruments»NI-RFmx SpecAn»NI-RFmx SpecAn Measurement Interactive Panel to launch the NI-RFmx SpecAn Measurement Interactive Panel.
    Documentation for NI-RFmx SpecAn is located at Start»All Programs»National Instruments»NI-RFmx SpecAn»NI-RFmx SpecAn Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    NI-RFmx SpecAn HelpHTML/Windows HelpInformation about NI-RFmx SpecAn. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to NI-RFmx SpecAn
    • A complete reference for all NI-RFmx SpecAn programming functions and VIs
    NI-RFmx SpecAn 2.2 ReadmeHTML (this document)Information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    To use the .NET API, you must install the .NET class libraries or the .NET Wrapper in addition to the NI device driver. For information about versions of the .NET Framework and the drivers each supports, as well as the download location of the installer files, refer to the National Instruments .NET Driver Support document at ni.com/info and enter Info Code NETAPIdriversupport.
    NI-RFmx SpecAn palette VIs are available from the Functions»Measurement I/O»NI-RFmx palette.
    NI-RFmx SpecAn functions are available in LabWindows/CVI from the Library»RFmx SpecAn Library menu.
    In LabVIEW, you can use the NI Example Finder to search or browse examples. NI-RFmx SpecAn examples are classified by keyword, so you can search for a particular device or measurement function. In LabVIEW, select Help»Find Examples to launch the NI Example Finder. The NI Example Finder offers two ways to access all installed LabVIEW example VIs (including NI–RFSG and Modulation Toolkit examples) and their descriptions:
    • Click the Browse tab to locate modulation examples by task at Hardware Input and Output»Modular Instruments»NI–RFmx»SpecAn or by directory structure at RFmx»SpecAn.
    • Click the Search tab to search all installed examples by keyword. For example, search for "SpecAn" to locate all NI-RFmx SpecAn examples.
    You can also access all the installed NI-RFmx SpecAn examples for LabVIEW and LabWindows/CVI at Start»All Programs»National Instruments»NI-RFmx SpecAn»NI-RFmx SpecAn Examples.
    Refer to ni.com/examples for these examples and for more information.
    NI-RFmx SpecAn 2.2 Drops Support for Microsoft Windows 7 RTM, Windows Vista, Windows XP, and Windows Server 2003
    With this release, NI-RFmx SpecAn drops support for Microsoft Windows 7 RTM (with no service pack), Windows Vista, Windows XP, and Windows Server 2003. NI-RFmx SpecAn 2.2 and later will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-RFmx SpecAn 2.2 to an unsupported OS. Additionally, after installing NI-RFmx SpecAn 2.2, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    • Select NI-RFmx SpecAn 2.2 from the dialog box that appears.
    • Select Control Panel.
    • Click the Uninstall button.
    As part of the NI-RFmx SpecAn 2.2 installation, the following software is installed. To completely remove the NI-RFmx SpecAn 2.2 installation from your system, you must also remove the following packages:
    • NI-RFmx SpecAn Runtime 2.2
    • NI-RFmx SpecAn Runtime 2.2 (64-bit)
    The following item is a behavior change in NI-RFmx SpecAn 2.0 from NI-RFmx SpecAn 1.2.
    • In the ACP measurement spectrum trace, RFmx 1.2 reports relative frequency from the RF center frequency on the x-axis. RFmx 2.0 reports RF absolute frequency on the x-axis.
    You can access the software and documentation known issues list online. Refer to the NI-RFmx SpecAn 2.2 Known Issues at ni.com for an up-to-date list of known issues in NI-RFmx SpecAn 2.2.
    The following items are the IDs and titles of a subset of issues fixed in NI-RFmx SpecAn. This is not an exhaustive list of issues fixed in the current version of the NI-RFmx SpecAn. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    The following items are changes in NI-RFmx SpecAn 2.2 from NI-RFmx SpecAn 2.1.
    579773Fixed an issue with CHP fetch results when multiple carriers are configured with a signal name.
    572302Fixed an issue with abort measurements when performing spectral acquisition.
    581477Fixed a memory leak with IQ measurement when a signal configuration containing IQ measurement is deleted.
    605884Fixed an issue in .NET where the enum values of the Threshold Type attribute used in CCDF, FCnt, and TxP were not consistent with LabVIEW and C API.
    601654Fixed an issue when switching between RFmx and RF toolkits where RFmx maynot apply the acquisition settings correctly in certain scenarios.
    The following items are changes in NI-RFmx SpecAn 2.1 from NI-RFmx SpecAn 2.0.
    560637Fixed an issue with fetching all spurs list when traces are disabled.
    554076Fixed an issue with the starting reference level used in auto level when preamp is enabled on NI PXIe-5668R.
    The following items are changes in NI-RFmx SpecAn 2.0 from NI-RFmx SpecAn 1.2.
    531357Fixed an issue with AMPM and DPD when using waveforms with high auto correlation.
    538026Fixed an issue with acquiring a signal using composite measurements and a trigger is enabled.
    541755Fixed an issue where the default RBW definition was set to 3 dB bandwidth of the FFT window instead of using FFT bin spacing when using an FFT based RBW filter type in spectral measurements.
    515825Fixed an issue with CHP measurement not integrating the power in the RRC filter roll off when the RRC filter is enabled and the span is not configured or it is configured to be less than integration bandwidth.
    The following items are changes in NI-RFmx SpecAn 1.2 from NI-RFmx SpecAn 1.1.
    457564Fixed composite measurement on a multicarrier signal with at least one measurement measuring a single carrier.
    506637Fixed an issue in which peaks were detected twice in some cases of Spur measurement.
    510432Fixed an issue in which incorrect peaks were detected when the limit line had a nonzero slope in Spur measurement.
    The following items are changes in NI-RFmx SpecAn 1.1 from NI-RFmx SpecAn 1.0.
    484980Fixed an issue in which the RFmxSpecAn Auto Level VI was not able to handle RF front end attributes.
    488782Fixed an issue in which an error was not returned when the start frequency was equal to the stop frequency for Spur and SEM measurements.
    484136Fixed an issue in which the waveform duration and delay in zero span were incorrect when RBW was set to a value less than 2 MHz.
    487678Fixed an issue in which incorrect power was reported when the span was less than the integration bandwidth for CHP measurement.
    © 2014–2016 National Instruments. All rights reserved.
    374847E-01
    GMT+8, 2025-9-6 03:13
