查看: 1262|回复: 0
[RTE运行引擎] NI RFmx SpecAn 20.6 Runtime Win64ENG RFmx频谱分析仪20.6运行版-64位
  • 签到天数: 3538 天
    连续签到: 8 天
    发表于 2022-4-6 15:51:34 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx SpecAn
    RFmx SpecAn为时域和频谱分析提供互动和自动测量。
    发布日期:
    2021/1/20
    包含的版本:
    20.6运行版
    Windows 8.1 64-bit
    Windows 7 (SP1) 64-bit
    Windows Server 2012 R2 64-bit
    语言:
    英文
    应用程序位数:
    64位
    文件大小: 573710336 字节 (547.13 MB)
    修改日期: 2021-01-20 15:04
    MD5: 529e01494ff8738b2f6a520c604c562a
    SHA1: b0c5968b15df0ca5d12a7ae4e9244c31e9841484
    SHA256: b9c75b8083abe5dd90df599a2cadd1017a15033c63eda44f50726cf61239a031
    CRC32: e86d97e9
    注册登录视觉论坛用户,购买附件查看下载地址
    RFMx SpecAn20.6RTE64.txt (582 Bytes, 下载次数: 0, 售价: 5 元)
    RFmx SpecAn 20.6 Readme
    January 2021
    This file contains important information about the RFmx SpecAn, including system requirements, and installation instructions.
    RFmx SpecAn Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021
    RFmx SpecAn offers simple access to the most advanced optimization techniques such as multi-measurement parallelism, multi-DUT measurements, and high dynamic range noise correction. The result is extremely fast and high-quality measurements with the minimal software development effort.
    RFmx SpecAn 20.6 includes the following new features:
    • Support for PXIe-5832
    RFmx SpecAn 20.0 includes the following new features:
    • Support to configure RFInstr properties in the context of signal configuration
    • Support for noise compensation in CHP measurement
    • Support to configure PAVT measurement properties for each segment
    • Support for the trigger-type ' None ' in the PAVT measurement when measuring a single segment
    • Addition of Phase Unwrap Enabled and Frequency Error Mean properties in the PAVT measurement
    • Execution speed improvements for AMPM PxdB measurement
    RFmx SpecAn 19.1 includes the following new features:
    • Support for PXIe-5830, PXIe-5831, and PXIe-5841
    • Support for single port phase and amplitude versus time (PAVT) measurement
    • Support for frequency converting DUTs using Y-Factor method in the noise figure measurement
    • Addition of high dynamic range and noise compensation features in the harmonics measurement
    • Addition of the equalizer feature in AMPM measurement
    Vector Signal Analyzers
    • PXIe-5663
    • PXIe-5663E
    • PXIe-5665
    • PXIe-5668
    • PXIe-5668 with PXIe-5698
    Vector Signal Transceivers
    • PXIe-5644
    • PXIe-5645
    • PXIe-5646
    • PXIe-5840
    • PXIe-5820
    • PXIe-5830
    • PXIe-5831
    • PXIe-5832
    • PXIe-5841
    • PXIe-5841 with PXIe-5655
    RFmx SpecAn has the following requirements:
    RFmx SpecAn 20.6 supports the following 64-bit operating systems:
    • Windows 10/8.1 1 /7 SP1 2
    • Windows Server 2012 R2 1
    Note   In 2019, RFmx SpecAn dropped support for all 32-bit Windows operating systems. RFmx SpecAn will not install or run on an unsupported OS. Refer to RFmx SpecAn Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021 for information about future OS support.
    Note   In 2016, RFmx SpecAn dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. You cannot deploy or distribute applications that use RFmx SpecAn 20.6 to an unsupported OS. Additionally, after installing RFmx SpecAn 20.6, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    RFmx SpecAn supports the following application software versions, including service packs. You should install application software, such as LabVIEW, LabWindows/CVI or Microsoft Visual Studio®, before installing RFmx SpecAn. To add support for application software installed after installing RFmx SpecAn modify your RFmx SpecAn installation or launch the RFmx SpecAn installer again. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Application SoftwareVersions Supported by RFmx SpecAn
    LabVIEW2017, 2018 SP1 f4 patch, 2019 SP1 f3 patch, or 2020
    LabWindows™/CVI™2015 or later
    • NI-RFSG 14.0.1 or later
    NI installs RFmx SpecAn using NI Package Manager. If you do not already have NI software installed, RFmx SpecAn installs NI Package Manager to handle the installation of your NI software. Visit ni.com/info and enter the Info Code NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    ItemInstalled Location
    Import Library files (64-bit)
    Select Start » All Programs » National Instruments » RFmx SpecAn » RFmx Soft Front Panel to launch the RFmx Soft Front Panel (64-bit).
    Documentation for RFmx SpecAn is located at Start » All Programs » National Instruments » RFmx SpecAn » RFmx SpecAn Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    RFmx SpecAn HelpHTML/Windows HelpContains primary help content for RFmx SpecAn. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to RFmx SpecAn
    • A complete reference for all RFmx SpecAn programming functions and VIs
    RFmx SpecAn 20.6 ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    You can access all the installed RFmx SpecAn examples at Start » All Programs » National Instruments » RFmx SpecAn » RFmx SpecAn Examples.
    The following are the behavior changes in RFmx SpecAn 20.0 from RFmx SpecAn 19.1.
    • Deprecated the PAVT Measurement Start Time(s) property and the PAVT Configure Measurement Start Time API. Instead, use PAVT Segment Start Time (s) property and PAVT Configure Segment Start Time API, respectively.
    • Spectrum traces obtained after noise compensation in the ACP and Spectrum measurements are no longer hard-clipped to stay above -174 dBm/Hz.
    The following are the behavior changes in RFmx SpecAn 19.1 from RFmx SpecAn 19.0.
    • For the noise figure measurement on PXIe-5830 and PXIe-5831, calibration data saved from the previous version of RFmx will not be valid and requires recalibration in RFmx 19.1.
    • Dropped support for Cleaner Spectrum property on PXIe-5830 and PXIe-5831
    • Obsoleted RFmxSpecAn Analyze (IQ) and RFmxSpecAn Analyze (Spectrum) APIs. Use RFmxSpecAn Analyze (IQ, 1 Wfm) and RFmxSpecAn Analyze (Spectrum, 1 Wfm) APIs instead.
    The following are the behavior changes in RFmx SpecAn 19.0 from RFmx SpecAn 3.0.
    You can access the RFmx SpecAn known issues online at RFmx SpecAn 20.6 Known Issues.
    You can access the RFmx SpecAn bug fix list online at RFmx SpecAn 20.6 Bug Fixes. This list describes a subset of issues fixed in the RFmx SpecAn. If you have a Bug ID, you can search this list to validate that the issue has been fixed.
    RFmx SpecAn will drop support for Windows 7 (64-bit) and Windows Server 2008 R2 starting in 2021. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    © 2014–2021 National Instruments. All rights reserved.
    374847P-01
    GMT+8, 2025-5-14 04:23
