查看: 1434|回复: 0
[RTE运行引擎] NI RFmx SpecAn/Power Amplifier/Phase Noise/Niose Figure 21.5 Runtime x64Win10 64bitENG RFmx频谱分析仪/功率放大器/相位噪声/噪声系数21.5运行版-64位
  • 签到天数: 3538 天
    连续签到: 8 天
    发表于 2022-4-6 16:12:28 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx SpecAn
    RFmx SpecAn为时域和频谱分析提供互动和自动测量。
    发布日期:
    2022/1/27
    包含的版本:
    21.5.0运行版
    语言:
    英文
    应用程序位数:
    64位
    文件大小: 604776448 字节 (576.76 MB)
    修改日期: 2022-01-27 14:01
    MD5: 5e61093dd9fbbea675a99f743818eccf
    SHA1: ae8396540528329db3a87989a50eeab7b12cbddf
    SHA256: 7c0a90b074d3f85955716d706017df1dd904b9a15700951d1e0085b76c598d47
    CRC32: 18510275
    注册登录视觉论坛用户,购买附件查看下载地址
    RFMx SpecAn21.5RTE64.txt (582 Bytes, 下载次数: 0, 售价: 5 元)
    RFmx SpecAn 21.5 Readme
    January 2022
    This file contains important information about the RFmx SpecAn, including system requirements, and installation instructions.
    • RFmx SpecAn Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • RFmx SpecAn Manuals: New features, behavior changes, and other documentation
    RFmx SpecAn offers simple access to the most advanced optimization techniques such as multi-measurement parallelism, multi-DUT measurements, and high dynamic range noise correction. The result is extremely fast and high-quality measurements with the minimal software development effort.
    RFmx SpecAn 21.3 includes the following new features:
    • Support for list mode feature on PXIe-5840/5841/5830/5831/5832
    • Support for configuring manual gain reference for compression point computation in AMPM measurement
    • Support for all FFT window types and user-defined overlap (%) for Sequential FFT measurement method in ACP measurement
    • Support for I-Only and Q-Only modes in Spectrum measurement for PXIe-5820
    • Addition of I vs Time and Q vs Time traces in IQ measurement in the RFmx Soft Front Panel
    RFmx SpecAn 20.7 includes the following new features:
    • Support for Pre-CFR PAPR result in the DPD measurement
    • Support for Noise Figure measurement Y-Factor method on PXIe-5665
    RFmx SpecAn 20.6 includes the following new features:
    • Support for PXIe-5832
    RFmx SpecAn 20.0 includes the following new features:
    • Support to configure RFInstr properties in the context of signal configuration
    • Support for noise compensation in CHP measurement
    • Support to configure PAVT measurement properties for each segment
    • Support for the trigger-type ' None ' in the PAVT measurement when measuring a single segment
    • Addition of Phase Unwrap Enabled and Frequency Error Mean properties in the PAVT measurement
    • Execution speed improvements for AMPM PxdB measurement
    Vector Signal Analyzers
    • PXIe-5663
    • PXIe-5663E
    • PXIe-5665
    • PXIe-5668
    • PXIe-5668 with PXIe-5698
    Vector Signal Transceivers
    • PXIe-5644
    • PXIe-5645
    • PXIe-5646
    • PXIe-5840
    • PXIe-5820
    • PXIe-5830
    • PXIe-5831
    • PXIe-5832
    • PXIe-5841
    • PXIe-5841 with PXIe-5655
    RFmx SpecAn has the following requirements:
    RFmx SpecAn 21.5 supports the following 64-bit operating systems:
    Note    RFmx SpecAn no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx SpecAn 21.5 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx SpecAn 21.5 to an unsupported OS. Additionally, after installing RFmx SpecAn 21.5, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    RFmx SpecAn supports the following application software versions, including service packs. You should install application software, such as LabVIEW, LabWindows/CVI or Microsoft Visual Studio®, before installing RFmx SpecAn. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Application SoftwareVersions Supported by RFmx SpecAn
    LabWindows™/CVI™2017 or later
    • NI-RFSG 14.0.1 or later
    Download the RFmx SpecAn installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • RFmx SpecAn installs the following licensed products
      • RFmx Noise Figure: This will enable the Noise Figure measurement in RFmx SpecAn.
      • RFmx Phase Noise: This will enable the Phase Noise measurement in RFmx SpecAn.
      • RFmx Power Amplifier: This will enable the AMPM and DPD measurements and the Crest Factor Reduction (CFR) support in RFmx SpecAn.
    • Use the serial number that is included with your software to activate the product. Refer to the NI Software Activation for more information on product activation.
    ItemInstalled Location
    Import Library files (64-bit)
    Select Start » National Instruments » RFmx Soft Front Panel to launch the RFmx Soft Front Panel (64-bit).
    Documentation for RFmx SpecAn is located at Start » National Instruments » RFmx SpecAn Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    RFmx SpecAn HelpHTML/Windows HelpContains primary help content for RFmx SpecAn. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to RFmx SpecAn
    • A complete reference for all RFmx SpecAn programming functions and VIs
    RFmx SpecAn 21.5 ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    You can access all the installed RFmx SpecAn examples at Start » National Instruments » RFmx SpecAn » RFmx SpecAn Examples.
    The following are the behavior changes in RFmx SpecAn 20.7 from RFmx SpecAn 20.6.
    The following are the behavior changes in RFmx SpecAn 20.0 from RFmx SpecAn 19.1.
    • Deprecated the PAVT Measurement Start Time(s) property and the PAVT Configure Measurement Start Time API. Instead, use PAVT Segment Start Time (s) property and PAVT Configure Segment Start Time API, respectively.
    • Spectrum traces obtained after noise compensation in the ACP and Spectrum measurements are no longer hard-clipped to stay above -174 dBm/Hz.
    The following are the behavior changes in RFmx SpecAn 19.1 from RFmx SpecAn 19.0.
    • For the noise figure measurement on PXIe-5830 and PXIe-5831, calibration data saved from the previous version of RFmx will not be valid and requires recalibration in RFmx 19.1.
    • Dropped support for Cleaner Spectrum property on PXIe-5830 and PXIe-5831
    • Obsoleted RFmxSpecAn Analyze (IQ) and RFmxSpecAn Analyze (Spectrum) APIs. Use RFmxSpecAn Analyze (IQ, 1 Wfm) and RFmxSpecAn Analyze (Spectrum, 1 Wfm) APIs instead.
    374847V-01
    GMT+8, 2025-5-14 03:48
