查看: 1687|回复: 0
[RTE运行引擎] NI RFmx Niose Figure 2.3.1 Runtime Win32/64ENG RFmx噪声系数2.3.1运行版
    昨天 09:54
  • 签到天数: 3808 天
    发表于 2022-4-7 11:33:45 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx Noise Figure噪声系数
    RFmx Noise Figure为噪声系数分析提供交互式自动化测量。
    RFmx Noise Figure是一款运行在RFmx SpecAn内的应用软件,该软件与RFmx Noise figure一起安装(20.7版本之后是这样,与SpecAn共用文件,但是20.6及之前版本,则是独立的安装文件)。该软件可扩展NI RF射频仪器的性能,并帮助您使用Y因子和冷源法测量噪声系数、增益和有效温度。此外,您可以使用RFmx Noise Figure,通过软件内置的校准程序来提高测量精度,而集成的噪声源控制和多频测量优化可大幅缩短测试时间。您可以通过交互式软件前面板进行和调试测量,利用随附的RFmx Waveform Creator创建和回放开放的、未锁定的波形,并利用性能优化的API加快自动测试。
    发布日期:
    2017/10/16
    包含的版本:
    2.3.1运行版
    Windows 7 (SP1) 64-bit
    Windows 7 (SP1) 32-bit
    Windows 10
    Windows 8.1
    语言:
    英文
    应用程序位数:
    32/64位
    文件大小: 169050136 字节 (161.22 MB)
    修改日期: 2017-10-13 16:26
    MD5: 230ac2b61ec25c73d9fdafe1e397b953
    SHA1: 091c7cbd09be720bac634cedbdd1b28fcced760c
    SHA256: fe760cd675967886d83c2f06688bad7e5339e2ba9559a31ee40b766d6a93b558
    CRC32: 634fd786
    注册登录视觉论坛用户,购买附件查看下载地址
    RFMx Noise Figure2.3.1RTE.txt (526 Bytes, 下载次数: 0, 售价: 5 圆)
    NI-RFmx Noise Figure 2.3.1 Readme
    October 2017
    This file contains important information about NI-RFmx Noise Figure 2.3.1 and is organized into the following sections:
    Activation Instructions
    Uninstalling/Modifying NI-RFmx Noise Figure 2.3.1
    NI-RFmx Noise Figure 2.3.1 installs the license files only. The Noise Figure measurement software is included in NI-RFmx SpecAn 2.3.1.
    Install NI-RFmx SpecAn 2.3.1 or later before installing the NI-RFmx Noise Figure.
    The Noise Figure measurement requires license activation. If you install the NI-RFmx Noise Figure 2.3.1 but do not activate it, you will have 30 days from the first time you use the measurement to evaluate it.
    NI-RFmx Noise Figure 2.3.1 supports the following operating systems:
    Note  NI-RFmx Noise Figure 2.3.1 does not support Windows Server non-R2 editions.
    Minimum Requirements
    • RAM—2 GB*
    Recommended System
    • RAM—4 GB*
    Refer to ni.com/examples for these examples and for more information.
    NI-RFmx Noise Figure 2.3.1 Drops Support for Microsoft Windows 7 RTM, Windows Vista, Windows XP, and Windows Server 2003
    With this release, NI-RFmx Noise Figure 2.3.1 drops support for Microsoft Windows 7 RTM (with no service pack), Windows Vista, Windows XP, and Windows Server 2003. NI-RFmx Noise Figure 2.3.1 and later will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-RFmx Noise Figure 2.3.1 to an unsupported OS. Additionally, after installing NI-RFmx Noise Figure 2.3.1, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    • Select NI-RFmx Noise Figure 2.3.1 from the dialog box that appears.
    • Select Control Panel.
    • Select Programs»Programs and Features.
    • Click the Uninstall button.
    As part of the NI-RFmx Noise Figure 2.3.1 installation, the following software is installed. To completely remove the NI-RFmx Noise Figure 2.3.1 installation from your system, you must also remove the following packages:
    • NI-RFmx Noise Figure Runtime 2.3.1
    © 2016-2017 National Instruments. All rights reserved.
    376695C-01
    GMT+8, 2026-2-26 09:48
