查看: 1942|回复: 0
[NI软件产品] NI RFmx Niose Figure 2.5 Full Win32/64ENG RFmx噪声系数2.5完整版
    昨天 09:54
  • 签到天数: 3808 天
    发表于 2022-4-7 11:41:39 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx Noise Figure噪声系数
    RFmx Noise Figure为噪声系数分析提供交互式自动化测量。
    RFmx Noise Figure是一款运行在RFmx SpecAn内的应用软件,该软件与RFmx Noise figure一起安装(20.7版本之后是这样,与SpecAn共用文件,但是20.6及之前版本,则是独立的安装文件)。该软件可扩展NI RF射频仪器的性能,并帮助您使用Y因子和冷源法测量噪声系数、增益和有效温度。此外,您可以使用RFmx Noise Figure,通过软件内置的校准程序来提高测量精度,而集成的噪声源控制和多频测量优化可大幅缩短测试时间。您可以通过交互式软件前面板进行和调试测量,利用随附的RFmx Waveform Creator创建和回放开放的、未锁定的波形,并利用性能优化的API加快自动测试。
    发布日期:
    2018/7/3
    包含的版本:
    2.5完整版
    Windows 10
    Windows Server 2012 R2 64-bit
    Windows 8.1
    Windows 7 (SP1) 64-bit
    Windows 7 (SP1) 32-bit
    语言:
    英文
    应用程序位数:
    32/64位
    文件大小: 234979312 字节 (224.09 MB)
    修改日期: 2018-07-03 16:07
    MD5: c4e615d1fac2e93db1df0eea13ee3967
    SHA1: 70025542aad84857122ca671c9582ce1ae82dc68
    SHA256: 0371d1e6ddfc9a9d484162b79bdf2a3fa2d9bbe2fea715dfd13bdf7f9fbc8d0d
    CRC32: 48466484
    注册登录视觉论坛用户,购买附件查看下载地址
    RFMx Noise Figure2.5.txt (517 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-RFmx Noise Figure 2.5 Readme
    June 2018
    This file contains important information about NI-RFmx Noise Figure 2.5 and is organized into the following sections:
    Activation Instructions
    NI-RFmx Noise Figure 2.5 installs the license files only. The Noise Figure measurement software is included in NI-RFmx SpecAn 2.5.
    Install NI-RFmx SpecAn 2.5 or later before installing the NI-RFmx Noise Figure.
    The Noise Figure measurement requires license activation. If you install the NI-RFmx Noise Figure 2.5 but do not activate it, you will have 30 days from the first time you use the measurement to evaluate it.
    NI-RFmx Noise Figure 2.5 supports the following operating systems:
    Note  In 2016, NI-RFmx Noise Figure dropped support for Microsoft Windows 7 RTM (with no service pack), Windows Vista, Windows XP, and Windows Server 2003. NI-RFmx Noise Figure 2.5 and later will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-RFmx Noise Figure 2.5 to an unsupported OS. Additionally, after installing NI-RFmx Noise Figure 2.5, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    Note  NI-RFmx Noise Figure 2.5 does not support Windows Server non-R2 editions.
    Minimum Requirements
    • RAM—4 GB*
    • Microsoft .NET Framework 4.6.2
    © 2016-2018 National Instruments. All rights reserved.
    376695E-01
    GMT+8, 2026-2-26 09:48
