查看: 2136|回复: 0
[NI软件产品] NI RFmx Niose Figure 19.0 Full Win32/64ENG RFmx噪声系数19.0完整版
    昨天 09:54
  • 签到天数: 3808 天
    发表于 2022-4-7 11:49:13 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx Noise Figure噪声系数
    RFmx Noise Figure为噪声系数分析提供交互式自动化测量。
    RFmx Noise Figure是一款运行在RFmx SpecAn内的应用软件,该软件与RFmx Noise figure一起安装(20.7版本之后是这样,与SpecAn共用文件,但是20.6及之前版本,则是独立的安装文件)。该软件可扩展NI RF射频仪器的性能,并帮助您使用Y因子和冷源法测量噪声系数、增益和有效温度。此外,您可以使用RFmx Noise Figure,通过软件内置的校准程序来提高测量精度,而集成的噪声源控制和多频测量优化可大幅缩短测试时间。您可以通过交互式软件前面板进行和调试测量,利用随附的RFmx Waveform Creator创建和回放开放的、未锁定的波形,并利用性能优化的API加快自动测试。
    发布日期:
    2019/6/27
    包含的版本:
    19.0完整版
    Windows Server 2012 R2 64-bit
    Windows 7 (SP1) 64-bit
    Windows 8.1 64-bit
    语言:
    英文
    应用程序位数:
    32/64位
    文件大小: 380614656 字节 (362.98 MB)
    修改日期: 2019-07-11 21:57
    MD5: 8b77d280fa088af4188da6f24847de64
    SHA1: e86443301935aa92f941fd523a7136ceae8a0568
    SHA256: ab0a970c2bd503c89ab1887cf8bc6aadb99558d621df845d8ea1c115de63fe57
    CRC32: 48b1db59
    注册登录视觉论坛用户,购买附件查看下载地址
    RFMx Noise Figure19.0.txt (565 Bytes, 下载次数: 0, 售价: 10 圆)
    RFmx Noise Figure 19.0 Readme
    June 2019
    This file contains important information about RFmx Noise Figure 19.0 and is organized into the following sections:
    RFmx Noise Figure Drops Support for Windows 7 (64-bit) and Windows Server 2008 R2 in 2021
    RFmx Noise Figure installer contains license files only. The Noise Figure measurement software is included in RFmx SpecAn. Install RFmx SpecAn 19.0 or later before installing the RFmx Noise Figure. Please refer to the RFmx SpecAn documentation for more information.
    RFmx Noise Figure has the following requirements:
    • 4 GB RAM*
    RFmx Noise Figure 19.0 supports the following 64-bit operating systems:
    • Windows 10/8.1/7 SP12
    • Windows Server 2012 R21
    • Windows Server 2008 R2 SP12
    Note  In 2019, RFmx Noise Figure dropped support for all 32-bit Windows operating systems. RFmx Noise Figure will not install or run on an unsupported OS. Refer to RFmx Noise Figure Drops Support for Windows 7 (64-bit) and Windows Server 2008 R2 in 2021 for information about future OS support.
    NI automates RFmx Noise Figure installation using NI Package Manager. Visit ni.com/info and enter the Info Code NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    RFmx Noise Figure is available for download from NI Software Product Downloads.
    The RFmx Noise Figure measurement requires license activation. If you install the Noise Figure license but do not activate it, you will have 30 days to activate the measurement from the day you use it.
    RFmx Noise Figure will drop support for Windows 7 and Windows Server 2008 R2 starting in 2021. Versions of this product that ship after May 1, 2021, will not install or run on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    LabWindows/CVIcvi_lifecycle
    © 2016–2019 National Instruments. All rights reserved.
    376695J-01
    GMT+8, 2026-2-26 09:48
