查看: 2066|回复: 0
[NI软件产品] NI RFmx Niose Figure 19.1 Full Win32/64ENG RFmx噪声系数19.1完整版
    昨天 09:54
  • 签到天数: 3808 天
    发表于 2022-4-7 11:53:10 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx Noise Figure噪声系数
    RFmx Noise Figure为噪声系数分析提供交互式自动化测量。
    RFmx Noise Figure是一款运行在RFmx SpecAn内的应用软件,该软件与RFmx Noise figure一起安装(20.7版本之后是这样,与SpecAn共用文件,但是20.6及之前版本,则是独立的安装文件)。该软件可扩展NI RF射频仪器的性能,并帮助您使用Y因子和冷源法测量噪声系数、增益和有效温度。此外,您可以使用RFmx Noise Figure,通过软件内置的校准程序来提高测量精度,而集成的噪声源控制和多频测量优化可大幅缩短测试时间。您可以通过交互式软件前面板进行和调试测量,利用随附的RFmx Waveform Creator创建和回放开放的、未锁定的波形,并利用性能优化的API加快自动测试。
    发布日期:
    2019/10/17
    包含的版本:
    19.1完整版
    Windows Server 2012 R2 64-bit
    Windows 7 (SP1) 64-bit
    Windows 8.1 64-bit
    语言:
    英文
    应用程序位数:
    32/64位
    文件大小: 379828224 字节 (362.23 MB)
    修改日期: 2019-10-18 16:10
    MD5: 236eb6388573ccc538b67fa35661ed1d
    SHA1: 4fc28ea966654801fec55f6d6b98ea6883fd4efb
    SHA256: 7a1aae08a07877dcbe5c4b2d649bfbf48964f9ac5c5658b768756267cebe40d4
    CRC32: eac7f4ca
    注册登录视觉论坛用户,购买附件查看下载地址
    RFMx Noise Figure19.1.txt (561 Bytes, 下载次数: 0, 售价: 10 圆)
    RFmx Noise Figure 19.1 Readme
    October 2019
    This file contains important information about the RFmx Noise Figure, including system requirements and installation instructions.
    RFmx Noise Figure Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021
    RFmx Noise Figure installer contains license files only. The RFmx Noise Figure measurement software is included in RFmx SpecAn. Install RFmx SpecAn 19.1 or later before installing the RFmx Noise Figure. Please refer to the RFmx SpecAn documentation for more information.
    System RequirementsRFmx Noise Figure has the following requirements:
    RFmx Noise Figure 19.1 supports the following 64-bit operating systems:
    • Windows 10/8.1 1 /7 SP1 2
    • Windows Server 2012 R2 1
    Note   In 2019, RFmx Noise Figure dropped support for all 32-bit Windows operating systems. RFmx Noise Figure will not install or run on an unsupported OS. Refer to RFmx Noise Figure Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021 for information about future OS support.
    NI automates RFmx Noise Figure installation using NI Package Manager. Visit ni.com/info and enter the Info Code NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    RFmx Noise Figuree is available for download from NI Software Product Downloads .
    The RFmx Noise Figure measurement requires license activation. If you install the RFmx Noise Figure license but do not activate it, you will have 30 days to activate the measurement from the day you use it.
    • For more information about silent installations of individual NI products, refer to Customize and Automate Installation of a Single Installer .
    • For more information about silent installations of NI products in a suite, such as NI Developer Suite, refer to Customize and Automate Installation of a Suited Installer .
    • To determine what version of NI Installers your product contains, refer to Determine Type and Version of My National Instruments Installer .
    Microsoft Windows 10 is the latest version of the Windows operating system and features significant changes compared to previous versions. Windows 10 introduces several new capabilities and also combines features from both Windows 7 and Windows 8. For more information about NI support for Windows 10, visit ni.com/windows10 .
    When you install NI software on Microsoft Windows 8.1, you will notice a few additional tiles in the Apps view, including shortcuts to NI application software products such as NI LabVIEW, Measurement & Automation Explorer (NI MAX), and NI Launcher. For more information about NI support for Windows 8.1, visit ni.com/windows8 .
    RFmx Noise Figure will drop support for Windows 7 (64-bit) and Windows Server 2008 R2 starting in 2021. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport .
    LabWindows/CVIcvi_lifecycle
    © 2016–2019 National Instruments. All rights reserved.
    For patents covering the NI products/technology, refer to the appropriate location: Help» Patents in your software, the patents.txt file on your media, or the NI Patent Notice at ni.com/patents .
    376695K-01
    GMT+8, 2026-2-26 09:48
