查看: 2008|回复: 0
[NI软件产品] NI RFmx Niose Figure 20.6 Full Win32/64ENG RFmx噪声系数20.6完整版
    昨天 09:54
  • 签到天数: 3808 天
    发表于 2022-4-7 12:01:10 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx Noise Figure噪声系数
    RFmx Noise Figure为噪声系数分析提供交互式自动化测量。
    RFmx Noise Figure是一款运行在RFmx SpecAn内的应用软件,该软件与RFmx Noise figure一起安装(20.7版本之后是这样,与SpecAn共用文件,但是20.6及之前版本,则是独立的安装文件)。该软件可扩展NI RF射频仪器的性能,并帮助您使用Y因子和冷源法测量噪声系数、增益和有效温度。此外,您可以使用RFmx Noise Figure,通过软件内置的校准程序来提高测量精度,而集成的噪声源控制和多频测量优化可大幅缩短测试时间。您可以通过交互式软件前面板进行和调试测量,利用随附的RFmx Waveform Creator创建和回放开放的、未锁定的波形,并利用性能优化的API加快自动测试。
    发布日期:
    2021/1/20
    包含的版本:
    20.6完整版
    Windows 7 (SP1) 64-bit
    Windows 8.1 64-bit
    Windows Server 2012 R2 64-bit
    语言:
    英文
    应用程序位数:
    32/64位
    文件大小: 382134272 字节 (364.43 MB)
    修改日期: 2021-01-20 15:03
    MD5: 47e3eeba8af0dbca5b7853dd1efff871
    SHA1: d58e328d706420ab88a54d99296b26ad266c77d7
    SHA256: 24cb0508e5dc04602f01d8022ec9527295a463f86e78814c9e8ddd734d0f1b92
    CRC32: 9fdbfc8e
    注册登录视觉论坛用户,购买附件查看下载地址
    RFMx Noise Figure20.6.txt (579 Bytes, 下载次数: 0, 售价: 10 圆)
    RFmx Noise Figure 20.6 Readme
    January 2021
    This file contains important information about the RFmx Noise Figure, including system requirements, and installation instructions.
    RFmx Noise Figure Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021
    RFmx Noise Figure installer contains license files only. The RFmx Noise Figure measurement software is included in RFmx SpecAn. Install RFmx SpecAn 20.6 or later before installing the RFmx Noise Figure. Please refer to the RFmx SpecAn documentation for more information.
    RFmx Noise Figure has the following requirements:
    RFmx Noise Figure 20.6 supports the following 64-bit operating systems:
    • Windows 10/8.1 1 /7 SP1 2
    • Windows Server 2012 R2 1
    Note   In 2019, RFmx Noise Figure dropped support for all 32-bit Windows operating systems. RFmx Noise Figure will not install or run on an unsupported OS. Refer to RFmx Noise Figure Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021 for information about future OS support.
    Note   In 2016, RFmx Noise Figure dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. You cannot deploy or distribute applications that use RFmx Noise Figure 20.6 to an unsupported OS. Additionally, after installing RFmx Noise Figure 20.6, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    NI installs RFmx Noise Figure using NI Package Manager. If you do not already have NI software installed, RFmx Noise Figure installs NI Package Manager to handle the installation of your NI software. Visit ni.com/info and enter the Info Code NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • Use the serial number that is included with your software to activate RFmx Noise Figure. For more information on RFmx Noise Figure activation, refer to National Instruments Software Activation .
    RFmx Noise Figure will drop support for Windows 7 (64-bit) and Windows Server 2008 R2 starting in 2021. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    © 2016–2021 National Instruments. All rights reserved.
    376695M-01
    GMT+8, 2026-2-26 09:49
