查看: 1758|回复: 0
[NI软件产品] NI RFmx Phase Noise 20.6 Full Win32/64ENG RFmx相位噪声20.6完整版
    10 小时前
    发表于 2022-4-8 10:23:25 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx Phase Noise相位噪声
    RFmx Phase Noise为相位噪声分析提供交互式自动化测量。
    RFmx Phase Noise是一款运行在RFmx SpecAn内的应用软件,该软件与RFmx Phase Noise一起安装(20.7版本之后是这样,与SpecAn共用文件,但是20.6及之前版本,则是独立的安装文件)。该软件扩展了NI射频仪器的相位噪声分析能力,帮助您通过智能自动范围设置或手动配置来测量对数图、点和集成相位噪声。使用迹线平滑、消除杂散和消除仪器相位噪声等先进技术有助于提升测量性能。您可以通过交互式软件前面板进行和调试测量,利用随附的RFmx Waveform Creator创建和回放开放的、未锁定的波形,并利用性能优化的API加快自动测试。
    发布日期:
    2021/1/20
    包含的版本:
    20.6完整版
    Windows 8.1 64-bit
    Windows 7 (SP1) 64-bit
    Windows Server 2012 R2 64-bit
    语言:
    英文
    应用程序位数:
    32/64位
    文件大小: 386764800 字节 (368.85 MB)
    修改日期: 2021-01-20 15:03
    MD5: a9345040c80dcb22f07e5f2b14126c55
    SHA1: 79a401aab545edbccd676aef59193811598af5a6
    SHA256: d601308518bb93f483772d9ab58cd92cbb0373a307f8f89d0c5744b1e90d54c5
    CRC32: 5dfe26e9
    注册登录视觉论坛用户,购买附件查看下载地址
    RFmx Phase Noise20.6.txt (580 Bytes, 下载次数: 0, 售价: 10 圆)
    RFmx Phase Noise 20.6 Readme
    January 2021
    This file contains important information about the RFmx Phase Noise, including system requirements, and installation instructions.
    RFmx Phase Noise Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021
    RFmx Phase Noise installer contains the license files only. The RFmx Phase Noise measurement software is included in RFmx SpecAn. Install RFmx SpecAn 20.6 or later before installing the RFmx Phase Noise. Please refer to the RFmx SpecAn documentation for more information.
    RFmx Phase Noise has the following requirements:
    RFmx Phase Noise 20.6 supports the following 64-bit operating systems:
    • Windows 10/8.1 1 /7 SP1 2
    • Windows Server 2012 R2 1
    Note   In 2019, RFmx Phase Noise dropped support for all 32-bit Windows operating systems. RFmx Phase Noise will not install or run on an unsupported OS. Refer to RFmx Phase Noise Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021 for information about future OS support.
    Note   In 2016, RFmx Phase Noise dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. You cannot deploy or distribute applications that use RFmx Phase Noise 20.6 to an unsupported OS. Additionally, after installing RFmx Phase Noise 20.6, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    NI installs RFmx Phase Noise using NI Package Manager. If you do not already have NI software installed, RFmx Phase Noise installs NI Package Manager to handle the installation of your NI software. Visit ni.com/info and enter the Info Code NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • Use the serial number that is included with your software to activate RFmx Phase Noise. For more information on RFmx Phase Noise activation, refer to National Instruments Software Activation .
    RFmx Phase Noise will drop support for Windows 7 (64-bit) and Windows Server 2008 R2 starting in 2021. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    © 2019–2021 National Instruments. All rights reserved.
    378027D-01
    GMT+8, 2025-12-8 19:54
