查看: 1889|回复: 0
[NI软件产品] NI RFmx TD-SCDMA 2.0 Full Win32/64ENG RFmx蜂窝测试TD-SCDMA2.0完整版
    前天 16:03
    发表于 2022-4-11 09:40:32 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx TD-SCDMA
    发布日期:
    2015/10/17
    包含的版本:
    2.0完整版
    Windows 10
    Windows 8.1
    Windows Server 2008 R2 64-bit
    Windows 7
    语言:
    英文
    应用程序位数:
    32/64位
    文件大小: 677372704 字节 (645.99 MB)
    修改日期: 2015-10-17 06:16
    MD5: 4b8ff4388fab288832af973e4a611ae8
    SHA1: 051316bfe9d2d9bfc556e7b37de84d4ed1fe24d2
    SHA256: 844a59a07470784c64c1a847f119d213cbb701118408f472c5c50827381be398
    CRC32: d62cc803
    注册登录视觉论坛用户,购买附件查看下载地址
    TDSCDMA2.0.txt (504 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-RFmx TD-SCDMA 2.0 Readme
    October 2015
    Thank you for using NI-RFmx TD-SCDMA. This file contains important information about NI-RFmx TD-SCDMA and is organized into the following sections:
    Accessing VIs and Functions
    Uninstalling/Modifying NI-RFmx TD-SCDMA
    Using NI Software with Microsoft Windows 8.x
    Caution  Before you install NI-RFmx TD-SCDMA 2.0, ensure that you have uninstalled all related NI-RFmx 1.0 products.
    • NI PXIe-5663
    • NI PXIe-5663E
    • NI PXIe-5665
    • NI PXIe-5668R
    Vector Signal Transceivers
    • NI PXIe-5644R
    • NI PXIe-5645R
    • NI PXIe-5646R
    NI-RFmx TD-SCDMA 2.0 supports the following operating systems:
    • Windows 8.0 (32-bit and 64-bit)
    Note  NI-RFmx TD-SCDMA 2.0 does not support Windows Server non-R2 editions.
    Minimum System Requirements
    • RAM—2 GB*
    • A screen resolution of 1,300 x 700 with 256 colors
    • Windows 10/8.1/8.0/7, with all available critical updates and service packs
    Recommended System
    • RAM—4 GB*
    • NI LabVIEW 2013 SP1 (32-bit and 64-bit) f6 patch, 2014 SP1 (32-bit and 64-bit) f3 patch, 2015 (32-bit and 64-bit) f1 patch
    Note  NI-RFmx TD-SCDMA does not operate correctly without the LabVIEW service packs and patches in the preceding list.
    Note  Install NI LabVIEW before you install NI-RFmx TD-SCDMA. To add support for ADEs that are installed after you install NI-RFmx TD-SCDMA, modify your NI-RFmx TD-SCDMA installation or relaunch the NI-RFmx TD-SCDMA installer.
    Other Required Software
      • Windows 10 (32-bit)/8.1 (32-bit)/8.0 (32-bit)/7 (32-bit): Program Files\National Instruments
      • Windows 10 (64-bit)/8.1 (64-bit) /8.0 (64-bit)/7 (64-bit): Program Files (x86)\National Instruments
      • Windows 10 (32-bit)/8.1 (32-bit)/8.0 (32-bit)/7 (32-bit): windows\system32
        • 32-bit DLL: windows\SysWow64
        • 64-bit DLL: windows\system32
    ItemInstalled Location on Windows 10/8.1/8.0/7
    LabVIEW Examples\LabVIEW \examples\RFmx\TD-SCDMA
    Select Start»All Programs»National Instruments»NI-RFmx TD-SCDMA»NI-RFmx TD-SCDMA Measurement Interactive Panel to launch the NI-RFmx TD-SCDMA Measurement Interactive Panel.
    Documentation for NI-RFmx TD-SCDMA is located at Start»All Programs»National Instruments»NI-RFmx TD-SCDMA»NI-RFmx TD-SCDMA Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    NI-RFmx TD-SCDMA HelpHTML/Windows HelpInformation about NI-RFmx TD-SCDMA. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to NI-RFmx TD-SCDMA
    • A complete reference for all NI-RFmx TD-SCDMA programming functions
    NI-RFmx TD-SCDMA 2.0 ReadmeHTML (this document)Information about supported hardware, supported operating systems, and legal notices.
    NI-RFmx TD-SCDMA palette VIs are available from the Functions»Measurement I/O»NI-RFmx»TD-SCDMA palette.
    You can access all the installed NI-RFmx TD-SCDMA examples at Start»All Programs»National Instruments»NI-RFmx TD-SCDMA»NI-RFmx TD-SCDMA Examples.
    • Select NI-RFmx TD-SCDMA 2.0 from the dialog box that appears.
    For Windows 10/8.1/8.0, complete the following steps:
    • Click the Uninstall button.
    As part of the NI-RFmx TD-SCDMA 2.0 installation, the following software is installed. To completely remove the NI-RFmx TD-SCDMA 2.0 installation from your system, you must also remove the following package:
    • NI-RFmx TD-SCDMA Runtime 2.0 for LabVIEW
    You can access the software and documentation known issues list online. Refer to the NI-RFmx TD-SCDMA 2.0 Known Issues at ni.com for an up-to-date list of known issues in NI-RFmx TD-SCDMA 2.0.
    When developing memory intensive applications, you may encounter memory limits because 32-bit Windows applications utilize only 2 GB of memory by default. To expand the amount of memory an application can utilize, you can configure the executable to be large address aware to gain access to up to 3 GB of memory on a 32-bit Windows operating system and up to 4 GB of memory on a 64-bit Windows operating system.
    Note  LabVIEW 8.5 and later are large address aware. For more information about LabVIEW memory usage, refer to KB 2HDEH9DT, How Much Memory can LabVIEW 32-bit or 64-bit Use?.
    In TestStand 2013 and later, the Large Address Aware flag is enabled by default for the TestStand Sequence Editor and TestStand User Interfaces. For more information, refer to KB 5ZREUK2G, Using the Large Address Aware Flag With TestStand Applications.
    Using NI Launcher
    For convenience, you can pin your most-used NI applications, such as MAX, to either the Start screen or the Taskbar on the desktop, as necessary.
    Finding All Programs
    © 2015 National Instruments. All rights reserved.
    375525A-01
    GMT+8, 2026-2-25 04:18
