查看: 2036|回复: 0
[NI软件产品] NI RFmx TD-SCDMA 2.1 Full Win32/64ENG RFmx蜂窝测试TD-SCDMA2.1完整版
    前天 16:03
    发表于 2022-4-11 09:46:55 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx TD-SCDMA
    发布日期:
    2016/2/3
    包含的版本:
    2.1完整版
    Windows 10
    Windows 8.1
    Windows Server 2008 R2 64-bit
    Windows 7
    语言:
    英文
    应用程序位数:
    32/64位
    文件大小: 777097792 字节 (741.10 MB)
    修改日期: 2016-02-03 01:08
    MD5: adf8894b67bde82336a03267b9ed1f9b
    SHA1: 648e2f9228f2f29068d0680a3d653a7922ec04ec
    SHA256: 1933b0f6703e54d1ffdda600f7003c40e55f2b5a612bbdf05220b93854aad815
    CRC32: 29e90cf2
    注册登录视觉论坛用户,购买附件查看下载地址
    TDSCDMA2.1.txt (504 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-RFmx TD-SCDMA 2.1 Readme
    February 2016
    Thank you for using NI-RFmx TD-SCDMA. This file contains important information about NI-RFmx TD-SCDMA and is organized into the following sections:
    Accessing VIs and Functions
    Uninstalling/Modifying NI-RFmx TD-SCDMA
    NI-RFmx TD-SCDMA 2.1 includes the following new features:
    • Support for C and .NET
    • Support for Hardware Agnostic Mode that allows you to perform measurements on a user-specified I/Q or Spectrum waveform
    Caution  Before you install NI-RFmx TD-SCDMA 2.1, ensure that you have uninstalled all related NI-RFmx 1.0 products.
    • NI PXIe-5663
    • NI PXIe-5663E
    • NI PXIe-5665
    • NI PXIe-5668R
    Vector Signal Transceivers
    • NI PXIe-5644R
    • NI PXIe-5645R
    • NI PXIe-5646R
    NI-RFmx TD-SCDMA 2.1 supports the following operating systems:
    Note  NI-RFmx TD-SCDMA 2.1 does not support Windows Server non-R2 editions.
    Minimum System Requirements
    • RAM—2 GB*
    • A screen resolution of 1,300 x 700 with 256 colors
    Recommended System
    • RAM—4 GB*
    • NI LabVIEW 2013 SP1 (32-bit and 64-bit) f6 patch, 2014 SP1 (32-bit and 64-bit) f3 patch, 2015 (32-bit and 64-bit) f1 patch
    Note  NI-RFmx TD-SCDMA does not operate correctly without the service packs and patches previously mentioned installed.
    Note  Install NI LabVIEW before you install NI-RFmx TD-SCDMA. To add support for ADEs that are installed after you install NI-RFmx TD-SCDMA, modify your NI-RFmx TD-SCDMA installation or relaunch the NI-RFmx TD-SCDMA installer.
    Other Required Software
      • Windows 10 (32-bit)/8.1 (32-bit)/7 (32-bit): Program Files\National Instruments\MeasurementStudioVS2010
      • Windows 10 (64-bit)/8.1 (64-bit)/7 (64-bit): Program Files (x86)\National Instruments\MeasurementStudioVS2010
      • Windows 10/8.1/7: Users\Public\Documents\National Instruments
      • Windows 10 (64-bit)/8.1 (64-bit) /7 (64-bit): Program Files (x86)\National Instruments
      • Windows 10 (32-bit)/8.1 (32-bit)/7 (32-bit): windows\system32
        • 32-bit DLL: windows\SysWow64
        • 64-bit DLL: windows\system32
    ItemInstalled Location on Windows 10/8.1/7
    Import Library files
    Windows 10 (32-bit)/8.1 (32-bit)/7 (32-bit):\Shared\ExternalCompilerSupport\C\include
    C, .NET
    Examples\RFmx\TDSCDMA\Examples
    Examples\LabVIEW \examples\RFmx\TDSCDMA
    Select Start»All Programs»National Instruments»NI-RFmx TD-SCDMA»NI-RFmx TD-SCDMA Measurement Interactive Panel to launch the NI-RFmx TD-SCDMA Measurement Interactive Panel.
    Documentation for NI-RFmx TD-SCDMA is located at Start»All Programs»National Instruments»NI-RFmx TD-SCDMA»NI-RFmx TD-SCDMA Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    NI-RFmx TD-SCDMA HelpHTML/Windows HelpInformation about NI-RFmx TD-SCDMA. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to NI-RFmx TD-SCDMA
    • A complete reference for all NI-RFmx TD-SCDMA programming functions
    NI-RFmx TD-SCDMA 2.1 ReadmeHTML (this document)Information about supported hardware, supported operating systems, and legal notices.
    NI-RFmx TD-SCDMA palette VIs are available from the Functions»Measurement I/O»NI-RFmx»TD-SCDMA palette.
    You can access all the installed NI-RFmx TD-SCDMA examples at Start»All Programs»National Instruments»NI-RFmx TD-SCDMA»NI-RFmx TD-SCDMA Examples.
    • Select NI-RFmx TD-SCDMA 2.1 from the dialog box that appears.
    • Click the Uninstall button.
    As part of the NI-RFmx TD-SCDMA 2.1 installation, the following software is installed. To completely remove the NI-RFmx TD-SCDMA 2.1 installation from your system, you must also remove the following package:
    • NI-RFmx TD-SCDMA Runtime 2.1 for LabVIEW
    You can access the software and documentation known issues list online. Refer to the NI-RFmx TD-SCDMA 2.1 Known Issues at ni.com for an up-to-date list of known issues in NI-RFmx TD-SCDMA 2.1.
    The following items are changes in NI-RFmx TD-SCDMA 2.1 from NI-RFmx TD-SCDMA 2.0.
    563071Fixed an issue where you could not fetch scalar results from the property node when traces are disabled in NI-RFmx TD-SCDMA ModAcc measurement.
    555713Fixed an issue where the absolute mask limits in the SEM offset segment definition were corrected according to Table 5.5.2.1.2.2 in 3GPP TS 34.122
    554076Fixed an issue with the starting reference level used in auto level when preamp is enabled on NI PXIe-5668R.
    When developing memory intensive applications, you may encounter memory limits because 32-bit Windows applications utilize only 2 GB of memory by default. To expand the amount of memory an application can utilize, you can configure the executable to be large address aware to gain access to up to 3 GB of memory on a 32-bit Windows operating system and up to 4 GB of memory on a 64-bit Windows operating system.
    Note  LabVIEW 8.5 and later are large address aware. For more information about LabVIEW memory usage, refer to KB 2HDEH9DT, How Much Memory can LabVIEW 32-bit or 64-bit Use?.
    In TestStand 2013 and later, the Large Address Aware flag is enabled by default for the TestStand Sequence Editor and TestStand User Interfaces. For more information, refer to KB 5ZREUK2G, Using the Large Address Aware Flag With TestStand Applications.
    When you install National Instruments software on Microsoft Windows 8.1, you will notice a few additional tiles in the Apps view, including shortcuts to NI application software products such as NI LabVIEW, Measurement & Automation Explorer (NI MAX), and NI Launcher.
    Using NI Launcher
    Note  NI MAX does not appear as a desktop shortcut when installed on Microsoft Windows 8.1. You can launch NI MAX either from the Apps view or from within NI Launcher.
    For convenience, you can pin your most-used NI applications, such as MAX, to either the Start screen or the Taskbar on the desktop, as necessary.
    Finding All Programs
    If you want to find a particular application or related files, such as documentation files, from the Start screen, you can access all installed files from the Apps view. To get to the Apps view, click the down arrow on the bottom left of the screen (Windows 8.1).
    © 2015–2016 National Instruments. All rights reserved.
    375525B-01
    GMT+8, 2026-2-25 04:17
