查看: 2007|回复: 0
[RTE运行引擎] NI RFmx TD-SCDMA 2.5 Runtime Win64ENG RFmx蜂窝测试TD-SCDMA2.5运行版-64位
    前天 16:03
    发表于 2022-4-11 10:41:37 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx TD-SCDMA
    发布日期:
    2018/7/3
    包含的版本:
    2.5运行版
    Windows 10
    Windows Server 2012 R2 64-bit
    Windows 8.1
    Windows 7 (SP1) 64-bit
    语言:
    英文
    应用程序位数:
    64位
    文件大小: 358146048 字节 (341.55 MB)
    修改日期: 2018-07-03 17:50
    MD5: 836caf8f3f70d7b0cc4f1b2621089b26
    SHA1: 28b976378d8b7ec08112db16aab2308f95145751
    SHA256: 06c288b2745cc797bcf0ba0b599dbe392f18616513bbfe4add51fe8718566d8a
    CRC32: 88f3f477
    注册登录视觉论坛用户,购买附件查看下载地址 TDSCDMA2.4RTE64.txt (521 Bytes, 下载次数: 0, 售价: 5 圆)
    NI-RFmx TD-SCDMA 2.5 Readme
    June 2018
    This file contains important information about NI-RFmx TD-SCDMA and is organized into the following sections:
    Accessing VIs and Functions
    NI-RFmx TD-SCDMA 2.5 includes the following new features:
    • Addition of APIs to perform self-calibration and partial self-calibration
    • Addition of NI-RFmx Debug Configuration Utility to configure debug settings
    • Support for LabVIEW 2018 (32-bit and 64-bit)
    • Support for querying configuration attributes without calling RFmxTDSCDMA Commit API
    NI-RFmx TD-SCDMA 2.3 includes the following new features:
    • Addition of Slot Power measurement
    • Addition of Subframe Synchronization Mode in the ModAcc measurement
    • Support for UpPTS in ModAcc measurement
    • Support for frequency-dependent amplitude correction on measured power spectrum data
    Caution  Before you install NI-RFmx TD-SCDMA 2.5, ensure that you have uninstalled all related NI-RFmx 1.0 products.
    • NI PXIe-5663
    • NI PXIe-5663E
    • NI PXIe-5665
    • NI PXIe-5668R
    Vector Signal Transceivers
    • NI PXIe-5644R
    • NI PXIe-5645R
    • NI PXIe-5646R
    • NI PXIe-5840
    NI-RFmx TD-SCDMA 2.5 supports the following operating systems:
    Note  In 2016, NI-RFmx TD-SCDMA dropped support for Microsoft Windows 7 RTM (with no service pack), Windows Vista, Windows XP, and Windows Server 2003. NI-RFmx TD-SCDMA 2.5 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-RFmx TD-SCDMA 2.5 to an unsupported OS. Additionally, after installing NI-RFmx TD-SCDMA 2.5, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    For more information about the changes to our OS support for 2017, refer to KB 79UC78LS, Why Does my LabVIEW, LabWindows/CVI, Measurement Studio, or TestStand Built Installer Fail on Windows XP/Vista and Server 2003?.
    Note  NI-RFmx TD-SCDMA 2.5 does not support Windows Server non-R2 editions.
    Minimum Requirements
    • RAM—4 GB*
    • Microsoft .NET Framework 4.6.2
    Note  You should install NI LabVIEW ADE before installing NI-RFmx TD-SCDMA. To add support for ADEs installed after installing NI-RFmx TD-SCDMA, modify your NI-RFmx TD-SCDMA installation or launch the NI-RFmx TD-SCDMA installer again.
    • NI LabVIEW 2015 SP1 f5 patch, 2016, 2017, or 2018
    Note  NI-RFmx TD-SCDMA does not operate correctly without the service packs and patches previously mentioned installed.
    Other Required Software
      • (32-bit) windows\system32
    ItemInstalled Location
    Import Library files (32-bit)
    Import Library files (64-bit)
    C, .NET
    Examples\NI-RFmx\TDSCDMA\Examples
    Examples\LabVIEW \examples\RFmx\TDSCDMA
    Select Start»All Programs»National Instruments»NI-RFmx TD-SCDMA»NI-RFmx TD-SCDMA Measurement Interactive Panel to launch the NI-RFmx TD-SCDMA Measurement Interactive Panel.
    Documentation for NI-RFmx TD-SCDMA is located at Start»All Programs»National Instruments»NI-RFmx TD-SCDMA»NI-RFmx TD-SCDMA Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    NI-RFmx TD-SCDMA HelpHTML/Windows HelpInformation about NI-RFmx TD-SCDMA. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to NI-RFmx TD-SCDMA
    • A complete reference for all NI-RFmx TD-SCDMA programming functions and VIs
    NI-RFmx TD-SCDMA 2.5 ReadmeHTML (this document)Information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    NI-RFmx TD-SCDMA palette VIs are available from the Functions»Measurement I/O»NI-RFmx»TD-SCDMA palette.
    You can access all the installed NI-RFmx TD-SCDMA examples at Start»All Programs»National Instruments»NI-RFmx TD-SCDMA»NI-RFmx TD-SCDMA Examples.
    The following items are the behavior changes in NI-RFmx TD-SCDMA 2.3.1 from NI-RFmx TD-SCDMA 2.3:
    • The alias 'default@TDSCDMA' for the default signal name is accepted as a valid signal name in a selector string parameter
    • LabVIEW built binaries using RFmx versions older than 2.2 are no longer supported
    You can access the software and documentation known issues list online. Refer to the NI-RFmx TD-SCDMA 2.5 Known Issues at ni.com for an up-to-date list of known issues in NI-RFmx TD-SCDMA 2.5.
    The following items are the IDs and titles of a subset of issues fixed in NI-RFmx TD-SCDMA. This is not an exhaustive list of issues fixed in the current version of the NI-RFmx TD-SCDMA. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    The following item is the change in NI-RFmx TD-SCDMA 2.4 from NI-RFmx TD-SCDMA 2.3.1:
    640495Fixed an issue where switching between measurements from an NI-RFmx cellular personality to Demod resulted in higher EVM on 5668R.
    The following items are changes in NI-RFmx TD-SCDMA 2.3.1 from NI-RFmx TD-SCDMA 2.3:
    650095Fixed an issue where the RFmxInstr Close API did not abort a measurement in progress, but instead waited for the measurement to finish before closing.
    650083Fixed an issue with RFmxInstr Save All Configurations API to save the attribute configurations depending on the corresponding number of channels configured by user.
    648703Fixed an issue where passing NULL as selector string in a few C functions, caused the function to crash.
    The following items are changes in NI-RFmx TD-SCDMA 2.3 from NI-RFmx TD-SCDMA 2.2:
    641151Fixed an issue with configuring the following properties:
    • UL Scrambling Code property and Midamble properties in ModAcc, CDA, and PVT measurements with a named signal.
    • User Defined Channel properties in ModAcc and CDA measurements with a named signal.
    636356[ModAcc] Fixed an issue for User Defined channel configuration mode, to allow any number of user defined channels.
    608056[ModAcc] Fixed an issue so that the trace lengths during Averaging On or Off are the same.
    642156[ModAcc] Fixed issues with the length and values of Code Domain Error Trace and Maximum Code Domain Error Trace
    When developing memory intensive applications, you may encounter memory limits because 32-bit Windows applications utilize only 2 GB of memory by default. To expand the amount of memory an application can utilize, you can configure the executable to be large address aware to gain access to up to 3 GB of memory on a 32-bit Windows operating system and up to 4 GB of memory on a 64-bit Windows operating system.
    Note  LabVIEW 8.5 and later are large address aware. For more information about LabVIEW memory usage, refer to KB 2HDEH9DT, How Much Memory can LabVIEW 32-bit or 64-bit Use?.
    In TestStand 2013 and later, the Large Address Aware flag is enabled by default for the TestStand Sequence Editor and TestStand User Interfaces. For more information, refer to KB 5ZREUK2G, Using the Large Address Aware Flag With TestStand Applications.
    © 2015–2018 National Instruments. All rights reserved.
    375525G-01
    GMT+8, 2026-2-25 04:17
