查看: 1647|回复: 0
[NI软件产品] NI RFmx TD-SCDMA 19.0 Full Win32/64ENG RFmx蜂窝测试TD-SCDMA19.0完整版
    10 小时前
    发表于 2022-4-11 10:52:52 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx TD-SCDMA
    发布日期:
    2019/6/27
    包含的版本:
    19.0完整版
    Windows Server 2012 R2 64-bit
    Windows 7 (SP1) 64-bit
    Windows 8.1 64-bit
    语言:
    英文
    应用程序位数:
    32/64位
    文件大小: 909893632 字节 (867.74 MB)
    修改日期: 2019-07-18 18:13
    MD5: 9cb7f1c967cb75630fd69122786f8299
    SHA1: b3f2b79debcfcd2be7c332436a0e211214c127e8
    SHA256: 4e6864ba04d0b546acfa57c858d001ba88f4776ca2861da21180202cb88a2437
    CRC32: 82d8cafe
    注册登录视觉论坛用户,购买附件查看下载地址
    TDSCDMA19.0.txt (534 Bytes, 下载次数: 0, 售价: 10 圆)
    RFmx TD-SCDMA 19.0 Readme
    June 2019
    This file contains important information about RFmx TD-SCDMA, including installation instructions, new features, bugs fixes, and known issues.
    RFmx TD-SCDMA Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021
    RFmx TD-SCDMA is application software that provides simple access to the most advanced optimization techniques such as multimeasurement parallelism and multi-DUT measurements. The result is fast, high-quality measurements with minimal software development efforts. Using this software, you can perform physical layer analysis on TD-SCDMA cellular signals including MODACC, ACPR, CHP, and SEM. RFmx TD-SCDMA is completely interoperable with all RFmx APIs.
    RFmx TD-SCDMA 19.0 includes the following new features:
    • Addition of RFmx TD-SCDMA Soft Front Panel (SFP 64-bit) with debug support
    RFmx TD-SCDMA 3.0 includes the following new features:
    • Support for NI PXIe-5820
    • Support for self-calibration in the RFmx Soft Front Panel
    RFmx TD-SCDMA 2.5 includes the following new features:
    • Addition of APIs to perform self-calibration and partial self-calibration
    • Addition of RFmx Debug Configuration Utility to configure debug settings
    • Support for LabVIEW 2018 (32-bit and 64-bit)
    • Support for querying configuration attributes without calling RFmxTDSCDMA Commit API
    RFmx TD-SCDMA 2.3 includes the following new features:
    • Addition of Slot Power measurement
    • Addition of Subframe Synchronization Mode in the ModAcc measurement
    • Support for UpPTS in ModAcc measurement
    • Support for frequency-dependent amplitude correction on measured power spectrum data
    Vector Signal Analyzers
    • PXIe-5663
    • PXIe-5663E
    • PXIe-5665
    • PXIe-5668
    • PXIe-5668 with PXIe-5698
    Vector Signal Transceivers
    • PXIe-5644
    • PXIe-5645
    • PXIe-5646
    • PXIe-5840
    • PXIe-5820
    • 4 GB RAM*
    RFmx TD-SCDMA 19.0 supports the following 64-bit operating systems:
    • Windows 10/8.11/7 SP12
    • Windows Server 2012 R21
    • Windows Server 2008 R2 SP12
    Note  In 2019, RFmx TD-SCDMA dropped support for all 32-bit Windows operating systems. RFmx TD-SCDMA will not install or run on an unsupported OS. Refer to RFmx TD-SCDMA Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021 for information about future OS support.
    RFmx TD-SCDMA supports the following application software versions, including service packs. You should install application software, such as LabVIEW, LabWindows/CVI or Microsoft Visual Studio®, before installing RFmx TD-CDMA. To add support for application software installed after installing RFmx TD-CDMA modify your RFmx TD-CDMA installation or launch the RFmx TD-CDMA installer again. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    [tr][/tr][/table][table]
    Application SoftwareVersions Supported by RFmx TD-CDMA
    LabVIEW2016, 2017, 2018 SP1 f4 patch, or 2019Other Required Software
    If you are using the RFmx TD-SCDMA .NET Class Library, .NET Framework 4.0 (minimum) is required. The RFmx TD-SCDMA .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0.
    To use the .NET API, you must install the .NET class libraries or the .NET wrapper in addition to the NI device driver. For information about versions of the .NET Framework and the drivers each supports, as well as the download location of the installer files, refer to National Instruments .NET Driver Support.
    NI installs RFmx TD-SCDMA using NI Package Manager. If you do not already have NI software installed, RFmx TD-SCDMA installs NI Package Manager to handle the installation of your NI software. Visit ni.com/info and enter the Info Code NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    Installed SoftwareInstalled Software
      ItemInstalled Location
      Import Library files (32-bit)
      Import Library files (64-bit)
      C, .NET
      Examples\NI-RFmx\TDSCDMA\Examples
      Examples\LabVIEW \examples\RFmx\TDSCDMA
      Select Start»All Programs»National Instruments»RFmx TD-SCDMA»RFmx Soft Front Panel to launch the RFmx Soft Front Panel (64-bit).
      You can access all the installed RFmx TD-SCDMA examples at Start»All Programs»National Instruments»RFmx TD-SCDMA»RFmx TD-SCDMA Examples.
      Documentation for RFmx TD-SCDMA is located at Start»All Programs»National Instruments»RFmx TD-SCDMA»RFmx TD-SCDMA Documentation. The documentation set is composed of the following documents.
      DocumentFormatDescription
      RFmx TD-SCDMA HelpHTML/Windows HelpInformation about RFmx TD-SCDMA. This help file is an HTML version of a traditional user manual that includes the following information:
      • An introduction to RFmx TD-SCDMA
      • A complete reference for all RFmx TD-SCDMA programming functions and VIs
      RFmx TD-SCDMA 19.0 ReadmeHTML (this document)Information about supported hardware and operating systems, new features, fixed issues, and legal notices.
      Accessing VIs
      RFmx TD-SCDMA palette VIs are available from the Functions»Measurement I/O»NI-RFmx»TD-SCDMA palette.
      The following items are the behavior changes in RFmx TD-SCDMA 19.0 from RFmx TD-SCDMA 3.0:
      • Dropped support for RFmx TD-SCDMA Measurement Interactive Panel
      The following items are the behavior changes in RFmx TD-SCDMA 2.3.1 from RFmx TD-SCDMA 2.3:
      • The alias 'default@TDSCDMA' for the default signal name is accepted as a valid signal name in a selector string parameter
      • LabVIEW built binaries using RFmx versions older than 2.2 are no longer supported
      The following items are the IDs and titles of a subset of issues fixed in RFmx TD-SCDMA. This is not an exhaustive list of issues fixed in the current version of the RFmx TD-SCDMA. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
      The following items are changes in RFmx TD-SCDMA 3.0 from RFmx TD-SCDMA 2.5
      706047Fixed an occasional crash which might occur on closing LabVIEW 2017 IDE or LabVIEW 2017 built applications that use RFmx.
      719203Fixed an issue where a timeout error was thrown when the digital trigger was configured when Using breakpoints in C/C++/.NET application was selected in the NI-PXIe-5840.
      The following item is the change in RFmx TD-SCDMA 2.4 from RFmx TD-SCDMA 2.3.1:
      640495Fixed an issue where switching between measurements from an RFmx cellular personality to Demod resulted in higher EVM on 5668R.
      The following items are changes in RFmx TD-SCDMA 2.3.1 from RFmx TD-SCDMA 2.3:
      650095Fixed an issue where the RFmxInstr Close API did not abort a measurement in progress, but instead waited for the measurement to finish before closing.
      650083Fixed an issue with RFmxInstr Save All Configurations API to save the attribute configurations depending on the corresponding number of channels configured by user.
      648703Fixed an issue where passing NULL as selector string in a few C functions, caused the function to crash.
      The following items are changes in RFmx TD-SCDMA 2.3 from RFmx TD-SCDMA 2.2:
      641151Fixed an issue with configuring the following properties:
      • UL Scrambling Code property and Midamble properties in ModAcc, CDA, and PVT measurements with a named signal.
      • User Defined Channel properties in ModAcc and CDA measurements with a named signal.
      636356[ModAcc] Fixed an issue for User Defined channel configuration mode, to allow any number of user defined channels.
      608056[ModAcc] Fixed an issue so that the trace lengths during Averaging On or Off are the same.
      642156[ModAcc] Fixed issues with the length and values of Code Domain Error Trace and Maximum Code Domain Error Trace
      RFmx TD-SCDMA will drop support for Windows 7 (64-bit) and Windows Server 2008 R2 starting in 2021. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
      LabWindows/CVIcvi_lifecycle
      © 2015–2019 National Instruments. All rights reserved.
      375525J-01
    GMT+8, 2025-12-8 19:54
