查看: 1641|回复: 0
[NI软件产品] NI RFmx TD-SCDMA 19.1 Full Win32/64ENG RFmx蜂窝测试TD-SCDMA19.1完整版
    10 小时前
    发表于 2022-4-11 10:58:52 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx TD-SCDMA
    发布日期:
    2019/10/17
    包含的版本:
    19.1完整版
    Windows Server 2012 R2 64-bit
    Windows 7 (SP1) 64-bit
    Windows 8.1 64-bit
    语言:
    英文
    应用程序位数:
    32/64位
    文件大小: 912293888 字节 (870.03 MB)
    修改日期: 2019-10-18 16:13
    MD5: ef37f93497f88e643ce9c1e6a036948d
    SHA1: ce71a081a98a555d5e56dbc52858cd1526a8ea00
    SHA256: 468566010e8cb3070b0727453244ec7c45f5369debe8e7a15e7512efa0ce4a24
    CRC32: c8dcfe87
    注册登录视觉论坛用户,购买附件查看下载地址
    TDSCDMA19.1.txt (534 Bytes, 下载次数: 0, 售价: 10 圆)
    RFmx TD-SCDMA 19.1 Readme
    October 2019
    This file contains important information about the RFmx TD-SCDMA, including system requirements and installation instructions.
    RFmx TD-SCDMA Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021
    RFmx TD-SCDMA is application software that provides simple access to the most advanced optimization techniques such as multimeasurement parallelism and multi-DUT measurements. The result is fast, high-quality measurements with minimal software development efforts. Using this software, you can perform physical layer analysis on TD-SCDMA cellular signals including MODACC, ACPR, CHP, and SEM. RFmx TD-SCDMA is completely interoperable with all RFmx APIs.
    RFmx TD-SCDMA 19.1 includes the following new feature:
    • Support for PXIe-5841
    RFmx TD-SCDMA 19.0 includes the following new features:
    • Addition of RFmx TD-SCDMA Soft Front Panel (SFP 64-bit) with debug support
    RFmx TD-SCDMA 3.0 includes the following new features:
    • Support for PXIe-5820
    • Support for self-calibration in the RFmx Soft Front Panel
    Vector Signal Analyzers
    • PXIe-5663
    • PXIe-5663E
    • PXIe-5665
    • PXIe-5668
    • PXIe-5668 with PXIe-5698
    Device-specific information about these modules is included in the NI RF Vector Signal Analyzers Help .
    Vector Signal Transceivers
    • PXIe-5644
    • PXIe-5645
    • PXIe-5646
    • PXIe-5820
    • PXIe-5840
    • PXIe-5841
    Device-specific information about these modules is included in the NI RF Vector Signal Transceivers Help .
    System RequirementsRFmx TD-SCDMA has the following requirements:
    RFmx TD-SCDMA 19.1 supports the following 64-bit operating systems:
    • Windows 10/8.1 1 /7 SP1 2
    • Windows Server 2012 R2 1
    Note   In 2019, RFmx TD-SCDMA dropped support for all 32-bit Windows operating systems. RFmx TD-SCDMA will not install or run on an unsupported OS. Refer to RFmx TD-SCDMA Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021 for information about future OS support.
    RFmx TD-SCDMA supports the following application software versions, including service packs. You should install application software, such as LabVIEW, LabWindows/CVI or Microsoft Visual Studio®, before installing RFmx TD-SCDMA. To add support for application software installed after installing RFmx TD-SCDMA modify your RFmx TD-SCDMA installation or launch the RFmx TD-SCDMA installer again. If you are not using NI application software, refer to  Microsoft Visual Studio Support .
    Application SoftwareVersions Supported by RFmx TD-SCDMA
    LabVIEW2016, 2017, 2018 SP1 f4 patch, or 2019
    If you are using the RFmx TD-SCDMA .NET Class Library, .NET Framework 4.0 (minimum) is required. The RFmx TD-SCDMA .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0.
    NI installs RFmx TD-SCDMA using NI Package Manager. If you do not already have NI software installed, RFmx TD-SCDMA installs NI Package Manager to handle the installation of your NI software. Visit ni.com/info and enter the Info Code NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    ItemInstalled Location
    Import Library files (64-bit)
    Assemblies \DotNET\Assemblies\Current\NationalInstruments.RFmx.TdscdmaMX.Fx40.dll
    Select Start » All Programs » National Instruments» RFmx TD-SCDMA» RFmx Soft Front Panel to launch the RFmx Soft Front Panel (64-bit).
    RFmx TD-SCDMA palette VIs are available from the Functions » Measurement I/O » NI-RFmx » TDSCDMA palette.
    Documentation for RFmx TD-SCDMA is located at Start»All Programs»National Instruments»RFmx TD-SCDMA»RFmx TD-SCDMA Documentation . The documentation set is composed of the following documents.
    DocumentFormatDescription
    RFmx TD-SCDMA HelpHTML/Windows HelpContains primary help content for RFmx TD-SCDMA. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to RFmx TD-SCDMA
    • A complete reference for all RFmx TD-SCDMA programming functions and VIs
    RFmx TD-SCDMA 19.1 ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    You can access all the installed RFmx TD-SCDMA examples at Start»All Programs»National Instruments»RFmx TD-SCDMA»RFmx TD-SCDMA Examples.
    For the most recent revisions of documentation and for newly released documentation, visit ni.com/manuals .
    The following is the behavior change in RFmx TD-SCDMA 19.1 from RFmx TD-SCDMA 19.0:
    • Obsoleted RFmxTDSCDMA Analyze (IQ) and RFmxTDSCDMA Analyze (Spectrum) APIs. Use RFmxTDSCDMA Analyze (IQ, 1 Wfm) and RFmxTDSCDMA Analyze (Spectrum, 1 Wfm) APIs instead.
    The following are the behavior changes in RFmx TD-SCDMA 19.0 from RFmx TD-SCDMA 3.0:
    • Dropped support for RFmx TD-SCDMA Measurement Interactive Panel
    You can access the software and documentation known issues list online. Refer to the TD-SCDMA Known Issues for an up-to-date list of known issues.
    The following are IDs and titles of a subset of issues fixed in RFmx TD-SCDMA. This is not an exhaustive list of issues fixed in the current version of the RFmx TD-SCDMA. If you have a Bug ID, you can search this list to validate that the issue has been fixed.
    The following are the bug fixes in RFmx TD-SCDMA 19.1 from RFmx TD-SCDMA 19.0:
    249283Fixed an issue to report an error when the measurement bandwidth exceeds the instantaneous bandwidth on PXIe-5668 and PXIe-5665.
    234240Fixed an intermittent error occurring at Analyze IQ and Analyze Spectrum APIs when performing a composite measurement with different averaging count for each measurement.
    The following are the bug fixes in RFmx TD-SCDMA 3.0 from RFmx TD-SCDMA 2.5:
    248862Fixed an occasional crash which might occur on closing LabVIEW 2017 IDE or LabVIEW 2017 built applications that use RFmx.
    244193Fixed an issue where a timeout error was thrown when the digital trigger was configured when Using breakpoints in C/C++/.NET application was selected in the PXIe-5840.
    • For more information about silent installations of individual NI products, refer to Customize and Automate Installation of a Single Installer .
    • For more information about silent installations of NI products in a suite, such as NI Developer Suite, refer to Customize and Automate Installation of a Suited Installer .
    • To determine what version of NI Installers your product contains, refer to Determine Type and Version of My National Instruments Installer .
    Microsoft Windows 10 is the latest version of the Windows operating system and features significant changes compared to previous versions. Windows 10 introduces several new capabilities and also combines features from both Windows 7 and Windows 8. For more information about NI support for Windows 10, visit ni.com/windows10 .
    When you install NI software on Microsoft Windows 8.1, you will notice a few additional tiles in the Apps view, including shortcuts to NI application software products such as NI LabVIEW, Measurement & Automation Explorer (NI MAX), and NI Launcher. For more information about NI support for Windows 8.1, visit ni.com/windows8 .
    RFmx TD-SCDMA will drop support for Windows 7 (64-bit) and Windows Server 2008 R2 starting in 2021. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport .
    LabWindows/CVIcvi_lifecycle
    © 2014–2019 National Instruments. All rights reserved.
    For patents covering the NI products/technology, refer to the appropriate location: Help» Patents in your software, the patents.txt file on your media, or the NI Patent Notice at ni.com/patents .
    375525K-01
    GMT+8, 2025-12-8 19:53
