查看: 2002|回复: 0
[NI软件产品] NI RFmx Waveform Creator 2.4 Full Win32/64ENG RFmx波形创造器2.4完整版
    10 小时前
    发表于 2022-4-11 15:14:22 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx Waveform Creator可帮您创建、可视化和再现通用型、蜂窝、连接性、物联网(IoT)、航空航天/防卫测试应用程序的波形。
    RFmx Waveform Creator是一款应用软件,您可以用来创建通用的和基于标准的波形,用于设计、验证和生产测试应用。借助这款软件,您可以结合信号发生器以交互方式生成波形,或保存开放的、未锁定的波形文件,用于借助自动仪器进行回放或仿真波形。该软件内置有标准的信号配置;您也可以修改、保存和加载自己的自定义波形参数。此外,在预览时域、频域和功率域的信号特征之前,您可以使用RFmx Waveform Creator来应用信号减损、滤波、波峰因子降低(CFR)等功能。
    发布日期:
    2017/12/6
    包含的版本:
    2.4完整版
    Windows 10
    Windows Server 2008 R2 64-bit
    Windows 8.1
    Windows 7
    语言:
    英文
    应用程序位数:
    32/64位
    文件大小: 273805312 字节 (261.12 MB)
    修改日期: 2017-12-11 13:41
    MD5: 3497ecb121163f5b98e8390192aef259
    SHA1: 5cdf6e81dc301e4e768c4dd2007141a4b193381e
    SHA256: 28766f0eb7a3dd3d4293aca5bf080316603da3f7691c309d9e11d20b1970a5fb
    CRC32: 51a5d526
    注册登录视觉论坛用户,购买附件查看下载地址
    RFmx Waveform Crreator 2.4.txt (530 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-RFmx Waveform Creator 2.4 Readme
    November 2017
    This file contains important information about NI-RFmx Waveform Creator and is organized into the following sections:
    Uninstalling/Modifying NI-RFmx Waveform Creator
    NI-RFmx Waveform Creator 2.4 includes the following new features:
    • Addition of LTE-LAA waveform generation support
    • Addition of GSM power ramp-up, ramp-down, and ramp delay support
    • Addition of DSB-AM support
    • Addition of 4096 QAM support
    • Addition of Half Sine pulse shaping filter support in PSK
    • Addition of Manchester encoding support in FSK
    Supported HardwareVector Signal Generators
    • NI PXIe-5673
    • NI PXIe-5673E
    Device-specific information about these modules is included in the NI RF Vector Signal Generators Help.
    Vector Signal Transceivers
    • NI PXIe-5644R
    • NI PXIe-5645R
    • NI PXIe-5646R
    • NI PXIe-5840
    NI-RFmx Waveform Creator 2.4 supports the following operating systems:
    Note  NI-RFmx Waveform Creator 2.4 does not support Windows Server non-R2 editions.
    Minimum Requirements
    • RAM—2 GB*
    Recommended System
    • RAM—4 GB*
    Other Required Software
    • NI-RFSG 14.5 or later
      • (32-bit OS) Program Files\National Instruments\RFmxWaveformCreator
      • (64-bit OS) Program Files (x86)\National Instruments\RFmxWaveformCreator for 32-bit programs
    • is an alias for the following National Instruments file folder location: Users\Public\Documents\National Instruments\NI-RFmx Waveform Creator
    ItemInstalled Location
    Examples\examples
    Select Start»All Programs»National Instruments»NI-RFmx Waveform Creator»NI-RFmx Waveform Creator to launch the NI-RFmx Waveform Creator.
    Documentation for NI-RFmx Waveform Creator is located at Start»All Programs»National Instruments»NI-RFmx Waveform Creator»NI-RFmx Waveform Creator Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    NI-RFmx Waveform Creator HelpHTML/Windows HelpThis help file is an HTML version of a traditional user manual that provides an introduction to the NI-RFmx Waveform Creator.
    NI-RFmx Waveform Creator User GuideHTML (.chm)This help file provides detailed information on the different modulation schemes that NI-RFmx Waveform Creator supports.
    NI-RFmx Waveform Creator Getting Started GuideHTML (.chm)This help file provides a quick look at the waveform setup procedure.
    NI-RFmx Waveform Creator 2.4 ReadmeHTML (this document)Information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    • Select NI-RFmx Waveform Creator 2.4 from the dialog box that appears.
    • Select Control Panel.
    • Click the Uninstall button.
    You can access the software and documentation known issues list online. Refer to the NI-RFmx Waveform Creator 2.4 Known Issues at ni.com for an up-to-date list of known issues in NI-RFmx Waveform Creator 2.4.
    © 2017 National Instruments. All rights reserved.
    377066C-01
    GMT+8, 2025-12-8 20:13
