查看: 1905|回复: 0
[NI软件产品] NI RFmx Waveform Creator 2.5 Full Win32/64ENG RFmx波形创造器2.5完整版
    10 小时前
    发表于 2022-4-11 15:16:32 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx Waveform Creator可帮您创建、可视化和再现通用型、蜂窝、连接性、物联网(IoT)、航空航天/防卫测试应用程序的波形。
    RFmx Waveform Creator是一款应用软件,您可以用来创建通用的和基于标准的波形,用于设计、验证和生产测试应用。借助这款软件,您可以结合信号发生器以交互方式生成波形,或保存开放的、未锁定的波形文件,用于借助自动仪器进行回放或仿真波形。该软件内置有标准的信号配置;您也可以修改、保存和加载自己的自定义波形参数。此外,在预览时域、频域和功率域的信号特征之前,您可以使用RFmx Waveform Creator来应用信号减损、滤波、波峰因子降低(CFR)等功能。
    发布日期:
    2018/7/3
    包含的版本:
    2.5完整版
    Windows 10
    Windows Server 2012 R2 64-bit
    Windows 8.1
    Windows Server 2008 R2 64-bit
    Windows 7 (SP1) 64-bit
    Windows 7 (SP1) 32-bit
    语言:
    英文
    应用程序位数:
    32/64位
    文件大小: 360976384 字节 (344.25 MB)
    修改日期: 2018-07-03 16:11
    MD5: f43e206c028441eb53640fcc9d7a877c
    SHA1: 1df9778a7fbe0db8ab534c8e5df5aad30bb38b8d
    SHA256: 2f21177eec7a5d12256085e76f7ab639a6671af87e8b8cf50b9cd61f47a8663a
    CRC32: 96ee75ba
    注册登录视觉论坛用户,购买附件查看下载地址
    RFmx Waveform Crreator 2.5.txt (530 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-RFmx Waveform Creator 2.5 Readme
    June 2018
    This file contains important information about NI-RFmx Waveform Creator and is organized into the following sections:
    NI-RFmx Waveform Creator 2.5 includes the following new features:
    • Support for waveform generation in eMTC uplink features such as,
      • Frequency Hopping
      • Guard symbols
    • Support for waveform generation in NB-IoT uplink features such as,
      • Single/multi tones
      • 15kHz/3.75kHz subcarrier spacing
      • NPUSCH Format 1/2
    • Support for LTE-LAA Resource Allocation Type 3
    • Support for 64-bit
    • Addition of the Waveform Summary window
    • Support for multi-carrier generation utility
    • Support for generating tones up to 1.25G
    • Support for updating the window duration based on LTE bandwidth
    • Improvements in the performance of waveform generation
    NI-RFmx Waveform Creator 2.4 includes the following new features:
    • Addition of LTE-LAA waveform generation support
    • Addition of GSM power ramp-up, ramp-down, and ramp delay support
    • Addition of DSB-AM support
    • Addition of 4096 QAM support
    • Addition of Half Sine pulse shaping filter support in PSK
    • Addition of Manchester encoding support in FSK
    Supported HardwareVector Signal Generators
    • NI PXIe-5673
    • NI PXIe-5673E
    Device-specific information about these modules is included in the NI RF Vector Signal Generators Help.
    Vector Signal Transceivers
    • NI PXIe-5644R
    • NI PXIe-5645R
    • NI PXIe-5646R
    • NI PXIe-5840
    NI-RFmx Waveform Creator 2.5 supports the following operating systems:
    Note  NI-RFmx Waveform Creator 2.5 does not support Windows Server non-R2 editions.
    Minimum Requirements
    • RAM—4 GB*
    • Microsoft .NET Framework 4.6.2
    Other Required Software
    • NI-RFSG 14.5 or later
      • (32-bit OS) Program Files\National Instruments\RFmxWaveformCreator
      • (64-bit OS) Program Files\National Instruments\RFmxWaveformCreator
    • is an alias for the following National Instruments file folder location: Users\Public\Documents\National Instruments\NI-RFmx Waveform Creator
    ItemInstalled Location
    Examples\examples
    Select Start»All Programs»National Instruments»NI-RFmx Waveform Creator»NI-RFmx Waveform Creator to launch the NI-RFmx Waveform Creator.
    Documentation for NI-RFmx Waveform Creator is located at Start»All Programs»National Instruments»NI-RFmx Waveform Creator»NI-RFmx Waveform Creator Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    NI-RFmx Waveform Creator HelpHTML/Windows HelpInformation about the NI-RFmx Waveform Creator. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to NI-RFmx Waveform Creator
    • How to get started with the application
    • A complete reference of all the different modulation schemes supported
    NI-RFmx Waveform Creator 2.5 ReadmeHTML (this document)Information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    The following items are the behavior changes in NI-RFmx Waveform Creator 2.5 from NI-RFmx Waveform Creator 2.4.
    • Updated the PAPR calculation for bursty signals in the presence of noise.
    • Removed restriction on configuring resource allocation type 0 and resource allocation type 1 settings in LTE.
    You can access the software and documentation known issues list online. Refer to the NI-RFmx Waveform Creator 2.5 Known Issues at ni.com for an up-to-date list of known issues in NI-RFmx Waveform Creator 2.5.
    The following items are the IDs and titles of a subset of issues fixed in NI-RFmx Waveform Creator. This is not an exhaustive list of issues fixed in the current version of the NI-RFmx Waveform Creator. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    The following items are changes in NI-RFmx Waveform Creator 2.5 from NI-RFmx Waveform Creator 2.4
    685187Fixed issue where an overflow error was reported on generating LTE.
    700390Fixed issue where the PAPR calculation for bursty signals with user plugin was incorrect.
    © 2018 National Instruments. All rights reserved.
    377066D-01
    GMT+8, 2025-12-8 20:12
