查看: 1996|回复: 0
[NI软件产品] NI RFmx Waveform Creator 3.0 Full Win32/64ENG RFmx波形创造器3.0完整版
    10 小时前
    发表于 2022-4-11 15:18:49 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx Waveform Creator可帮您创建、可视化和再现通用型、蜂窝、连接性、物联网(IoT)、航空航天/防卫测试应用程序的波形。
    RFmx Waveform Creator是一款应用软件,您可以用来创建通用的和基于标准的波形,用于设计、验证和生产测试应用。借助这款软件,您可以结合信号发生器以交互方式生成波形,或保存开放的、未锁定的波形文件,用于借助自动仪器进行回放或仿真波形。该软件内置有标准的信号配置;您也可以修改、保存和加载自己的自定义波形参数。此外,在预览时域、频域和功率域的信号特征之前,您可以使用RFmx Waveform Creator来应用信号减损、滤波、波峰因子降低(CFR)等功能。
    发布日期:
    2019/1/17
    包含的版本:
    3.0完整版
    Windows 10
    Windows Server 2012 R2 64-bit
    Windows 8.1
    Windows Server 2008 R2 64-bit
    Windows 7 (SP1) 64-bit
    Windows 7 (SP1) 32-bit
    语言:
    英文
    应用程序位数:
    32/64位
    文件大小: 585695232 字节 (558.56 MB)
    修改日期: 2019-01-18 18:51
    MD5: 13a21bbe5e65f894821549dfc62f5342
    SHA1: d46c9ede7633371501a9806dc23dd00436919303
    SHA256: 5582b2f1a3ce5433b18b39160d64eb87684b1669157f2052103842a9aa384f47
    CRC32: 5e03e318
    注册登录视觉论坛用户,购买附件查看下载地址
    RFmx Waveform Crreator 3.0.txt (530 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-RFmx Waveform Creator 3.0 Readme
    January 2019
    This file contains important information about NI-RFmx Waveform Creator and is organized into the following sections:
    NI-RFmx Waveform Creator 3.0 includes the following new features:
    • Addition of 5G new radio (NR) modulation scheme
    • Support for launching the WLAN Generation SFP
    • Support for launching the Bluetooth Generation SFP
    • Support for NI PXIe-5820
    • Addition of crest factor reduction (CFR) in LTE, NR, and Multi-Carrier modulation schemes. Supported CFR types are Clipping and Peak Windowing.
    • Support for custom output sample rate in multi-carrier plugin.
    • GSM relative power per slot
    NI-RFmx Waveform Creator 2.5 includes the following new features:
    • Support for waveform generation in eMTC uplink features such as,
      • Frequency Hopping
      • Guard symbols
    • Support for waveform generation in NB-IoT uplink features such as,
      • Single/multi tones
      • 15kHz/3.75kHz subcarrier spacing
      • NPUSCH Format 1/2
    • Support for LTE-LAA Resource Allocation Type 3
    • Support for 64-bit
    • Addition of the Waveform Summary window
    • Support for multi-carrier generation utility
    • Support for generating tones up to 1.25G
    • Support for updating the window duration based on LTE bandwidth
    • Improvements in the performance of waveform generation
    NI-RFmx Waveform Creator 2.4 includes the following new features:
    • Addition of LTE-LAA waveform generation support
    • Addition of GSM power ramp-up, ramp-down, and ramp delay support
    • Addition of DSB-AM support
    • Addition of 4096 QAM support
    • Addition of Half Sine pulse shaping filter support in PSK
    • Addition of Manchester encoding support in FSK
    Supported HardwareVector Signal Generators
    • NI PXIe-5673
    • NI PXIe-5673E
    Device-specific information about these modules is included in the NI RF Vector Signal Generators Help.
    Vector Signal Transceivers
    • NI PXIe-5644R
    • NI PXIe-5645R
    • NI PXIe-5646R
    • NI PXIe-5840
    • NI PXIe-5820
    NI-RFmx Waveform Creator 3.0 supports the following operating systems:
    Note  NI-RFmx Waveform Creator 3.0 does not support Windows Server non-R2 editions.
    Minimum Requirements
    • RAM—4 GB*
    • Microsoft .NET Framework 4.6.2
    Other Required Software
    • NI-RFSG 14.5 or later
      • (32-bit OS) Program Files\National Instruments\RFmxWaveformCreator
      • (64-bit OS) Program Files\National Instruments\RFmxWaveformCreator
    • is an alias for the following National Instruments file folder location: Users\Public\Documents\National Instruments\NI-RFmx Waveform Creator
    ItemInstalled Location
    Examples\examples
    Select Start»All Programs»National Instruments»NI-RFmx Waveform Creator»NI-RFmx Waveform Creator to launch the NI-RFmx Waveform Creator.
    Documentation for NI-RFmx Waveform Creator is located at Start»All Programs»National Instruments»NI-RFmx Waveform Creator»NI-RFmx Waveform Creator Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    NI-RFmx Waveform Creator HelpHTML/Windows HelpInformation about the NI-RFmx Waveform Creator. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to NI-RFmx Waveform Creator
    • How to get started with the application
    • A complete reference of all the different modulation schemes supported
    NI-RFmx Waveform Creator 3.0 ReadmeHTML (this document)Information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    The following items are the behavior changes in NI-RFmx Waveform Creator 3.0 from NI-RFmx Waveform Creator 2.5.
    • Fractional resampling is performed in LTE and NR carrier aggregation so that the final sample rate is a multiple of 3.84 MHz.
    • CCDF graph calculates PAPR based on generated waveform excluding OFF power period.
    • UI controls on the Download & Play window are reset based on selected device.
    The following items are the behavior changes in NI-RFmx Waveform Creator 2.5 from NI-RFmx Waveform Creator 2.4.
    • Updated the PAPR calculation for bursty signals in the presence of noise.
    • Removed restriction on configuring resource allocation type 0 and resource allocation type 1 settings in LTE.
    The following item is a known issue in NI-RFmx Waveform Creator 3.0.
    IDKnown Issue
    711673PAPR displayed on CCDF graph does not match with PAPR stored in the tdms file in User plugin.
    The following items are the IDs and titles of a subset of issues fixed in NI-RFmx Waveform Creator. This is not an exhaustive list of issues fixed in the current version of the NI-RFmx Waveform Creator. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    The following items are changes in NI-RFmx Waveform Creator 3.0 from NI-RFmx Waveform Creator 2.5
    704721Fixed the phase discontinuity issue on configuring GSM on first slot and EDGE on last slot.
    698120Fixed the issue where CCDF graph was reporting negative results for some configurations.
    701478Fixed the issue of not reporting burst start and stop locations for NB-IoT and eMTC FDD.
    705738 and 701490Fixed the issue of reporting incorrect burst PAPR for impaired bursty signal in Multi-Carrier and User plugins.
    712524Fixed the issue where IQ impairments per carrier set were incorrect, when multiple carrier sets are configured.
    The following items are changes in NI-RFmx Waveform Creator 2.5 from NI-RFmx Waveform Creator 2.4
    685187Fixed issue where an overflow error was reported on generating LTE.
    700390Fixed issue where the PAPR calculation for bursty signals with user plugin was incorrect.
    © 2018–2019 National Instruments. All rights reserved.
    377066E-01
    GMT+8, 2025-12-8 20:15
