查看: 1917|回复: 0
[NI软件产品] NI RFmx Waveform Creator 20.0 Full Win32/64ENG RFmx波形创造器20.0完整版
    10 小时前
    发表于 2022-4-11 15:25:53 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx Waveform Creator可帮您创建、可视化和再现通用型、蜂窝、连接性、物联网(IoT)、航空航天/防卫测试应用程序的波形。
    RFmx Waveform Creator是一款应用软件,您可以用来创建通用的和基于标准的波形,用于设计、验证和生产测试应用。借助这款软件,您可以结合信号发生器以交互方式生成波形,或保存开放的、未锁定的波形文件,用于借助自动仪器进行回放或仿真波形。该软件内置有标准的信号配置;您也可以修改、保存和加载自己的自定义波形参数。此外,在预览时域、频域和功率域的信号特征之前,您可以使用RFmx Waveform Creator来应用信号减损、滤波、波峰因子降低(CFR)等功能。
    发布日期:
    2020/6/9
    包含的版本:
    20.0完整版
    Windows 7 (SP1) 64-bit
    Windows 8.1 64-bit
    Windows Server 2012 R2 64-bit
    语言:
    英文
    应用程序位数:
    32/64位
    文件大小: 698351616 字节 (666.00 MB)
    修改日期: 2020-06-09 15:48
    MD5: 692f48434975a87e1711461d1efe3b60
    SHA1: 792e3e786031d9e6de1a4fb9b2dfdee38594d15c
    SHA256: 66b7883281623ac8bdb4d8b5007c4b9887e37f69ae731b58d766958cb5d6429f
    CRC32: 13c6b23d
    注册登录视觉论坛用户,购买附件查看下载地址
    RFmx Waveform Crreator 20.0.txt (595 Bytes, 下载次数: 0, 售价: 10 圆)
    RFmx Waveform Creator 20.0 Readme
    June 2020
    This file contains important information about the RFmx Waveform Creator, including system requirements, and installation instructions.
    RFmx Waveform Creator Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021
    RFmx Waveform Creator provides a unified interface for creating and generating waveforms for multiple wireless standards. You can create unencrypted, unlocked IQ waveform files for playback on NI PXI RF instrumentation. Supported standards include 5G NR, LTE/LTE-Advanced, W-CDMA/HSPA+, GSM/EDGE+, TD-SCDMA, and more.
    RFmx Waveform Creator 20.0 includes the following new features:
    • Added support for Auto Increment Cell ID Enabled parameter in LTE modulation scheme
    • Added support for NB-IoT short frame generation
    • Added support for LTE Downlink E-UTRA Test Model 2b and E-UTRA Test Model 3.1b as per 3GPP TS 36.141 v16.5.0 specification
    • 5G new radio (NR)
      • Added support for user defined downlink multi-user configuration
      • Added support for PUSCH and PDSCH DMRS Release 16 as per 3GPP TS 38.211 v16.1.0 specification
      • Added support for user defined filter coefficients for PI/2 BPSK Spectral Shaping
      • Added support for Downlink NR Test Model 2a and 3.1a for Frequency Range 2
      • Added support for 1024 QAM modulation in PDSCH and PUSCH
      • Added Batch Waveform Creation Utility for NR
    • RFmx Waveform Creator for WLAN
      • Support for 320MHz in 802.11ax SU PPDU for early testing of the 802.11be 320MHz channels
      • Unformatted data packet support for RF blocker test
    RFmx Waveform Creator 19.1 includes the following new features:
    • Support for V2X (sidelink) in LTE FDD modulation scheme as per 3GPP Release 14 specification
      • Added PSSCH and PSCCH channels
      • Added PSSCH DMRS and PSCCH DMRS signals
      • Support for retransmission
    • 5G new radio (NR) modulation scheme
      • Support for 3GPP NR Release 15 Specification v15.6.0 (June 2019)
      • Support for auto increment cell id for carrier aggregation
      • Support for channel coding in PUSCH, PDSCH, and PDCCH
      • Support for predefined strings for PUSCH RB allocation as per 3GPP TS 38.521-1/2 specification
    • Added option to enable or disable phase continuity in LTE and NR multi-carrier
    • Support for PXIe-5841, PXIe-5831, and PXIe-5830
    • Support for antenna switching with per slot amplitude and phase configuration in LE 5.1 in RFmx Waveform Creator for Bluetooth
      • Support for configuring waveform duration for OFDM standards
      • Support for 4096 QAM in 802.11ax
    RFmx Waveform Creator 19.0 includes the following new features:
    • Support for PXIe-5830 and PXIe-5831
    • Support for Cat-M2 Uplink (Release 14) and Cat-NB2 Uplink in LTE modulation scheme
      • Added support for Uplink Pi/2 BPSK Spectral Shaping
      • Support for downlink test models as defined in 3GPP TS 38.141-1 and 3GPP TS 38.141-2 (Change requests R4-1905121, R4-1905122 endorsed in April 2019, to be updated in v15.2.0 when it releases in June 2019)
    • Support to resume generated waveforms in Download and Play window
    Vector Signal Generators
    • PXIe-5673
    • PXIe-5673E
    Device-specific information about these modules is included in the NI RF Vector Signal Generators Help.
    Vector Signal Transceivers
    • PXIe-5644
    • PXIe-5645
    • PXIe-5646
    • PXIe-5840
    • PXIe-5841
    • PXIe-5820
    • PXIe-5830
    • PXIe-5831
    • PXIe-5841 with PXIe-5655
    RFmx Waveform Creator has the following requirements:
    RFmx Waveform Creator 20.0 supports the following 64-bit operating systems:
    • Windows 10/8.1 1 /7 SP1 2
    • Windows Server 2012 R2 1
    Note   In 2019, RFmx Waveform Creator dropped support for all 32-bit Windows operating systems. RFmx Waveform Creator will not install or run on an unsupported OS. Refer to RFmx Waveform Creator Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021 for information about future OS support.
    Note   In 2016, RFmx Waveform Creator dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. You cannot deploy or distribute applications that use RFmx Waveform Creator 20.0 to an unsupported OS. Additionally, after installing RFmx Waveform Creator 20.0, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    RFmx Waveform Creator supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx Waveform Creator. To add support for application software installed after installing RFmx Waveform Creator modify your RFmx Waveform Creator installation or launch the RFmx Waveform Creator installer again. If you are not using NI application software, refer to  Microsoft Visual Studio Support.
    Application SoftwareVersions Supported by RFmx Waveform Creator
    LabVIEW2017, 2018 SP1 f4 patch, 2019 SP1, 2020
    If you are using the RFmx Waveform Creator .NET Class Library, .NET Framework 4.0 (minimum) is required. The RFmx Waveform Creator .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5.
    NI installs RFmx Waveform Creator using NI Package Manager. If you do not already have NI software installed, RFmx Waveform Creator installs NI Package Manager to handle the installation of your NI software. Visit ni.com/info and enter the Info Code NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • Use the serial number that is included with your software to activate RFmx Waveform Creator. For more information on RFmx Waveform Creator activation, refer to National Instruments Software Activation .
    Select Start » All Programs » National Instruments» RFmx Waveform Creator to launch the RFmx Waveform Creator.
    Documentation for RFmx Waveform Creator is located at Start » All Programs » National Instruments » RFmx Waveform Creator » RFmx Waveform Creator Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    RFmx Waveform Creator HelpHTML/Windows HelpContains primary help content for RFmx Waveform Creator. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to RFmx Waveform Creator
    • A complete reference for all RFmx Waveform Creator programming functions and VIs
    RFmx Waveform Creator 20.0 ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    You can access all the installed RFmx Waveform Creator examples at Start » All Programs » National Instruments » RFmx Waveform Creator » RFmx Waveform Creator Examples.
    The following items are the behavior changes in RFmx Waveform Creator 20.0 from RFmx Waveform Creator 19.1.
    • Changed the data content of downlink NR test models from all-zero to PN23 sequence with respect to the changes in 3GPP TS 38.141v specification
    • Changed modulation scheme for downlink NR test model 3.3 to QPSK with respect to the changes in 3GPP TS 38.141-1 v16.3.0 specification
    • Changed the NR grid size for 100 MHz channel bandwidth and 240 kHz subcarrier spacing to 33.
    • Changed the NR SS/PBCH block parameters CRB Offset and Subcarrier Offset to be 3GPP specification compliant.
    • Changed the NR grid alignment for SS/PBCH block.
    The following items are the behavior changes in RFmx Waveform Creator 19.1 from RFmx Waveform Creator 19.0.
    • Following configurations require recreation of waveforms in 5G new radio (NR) modulation scheme
      • Carrier aggregation due to 3GPP NR specification updates to nominal spacing
      • Downlink test models due to 3GPP NR specification updates to definitions of downlink test models
      • ACP optimized filter bandwidth is updated to avoid corrupting edge sub-carriers
    The following items are the behavior changes in RFmx Waveform Creator 19.0 from RFmx Waveform Creator 3.0.
      • Deprecated support for slot Offset control
      • Default value of downlink Channel Configuration Mode control has changed to Test Model from User defined .
      • Default value of BWP Number of RBs control has changed to -1 from maximum number of resource blocks.
      • Added SSB Active Blocks control and deprecated SSB Transmitted Pattern control under SS/PBCH Block configurations window.
    • Saving of waveforms in evaluation mode is not allowed in WLAN and Bluetooth
    You can access the RFmx Waveform Creator known issues list online at RFmx Waveform Creator 20.0 Known Issues.
    You can access the RFmx Waveform Creator bug fix list online at RFmx Waveform Creator 20.0 Bug Fixes. This list describes a subset of issues fixed in the RFmx Waveform Creator. If you have a Bug ID, you can search this list to validate that the issue has been fixed.
    RFmx Waveform Creator will drop support for Windows 7 (64-bit) and Windows Server 2008 R2 starting in 2021. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    © 2017–2020 National Instruments. All rights reserved.
    377066H-01
    GMT+8, 2025-12-8 20:15
