查看: 1809|回复: 0
[NI软件产品] NI RFmx W-CDMA/HSPA+ 2.0 Full Win32/64ENG RFmx W-CDMA/HSPA/HSPA+蜂窝测试2.0完整版
    昨天 08:40
  • 签到天数: 3765 天
    连续签到: 16 天
    发表于 2022-4-12 11:01:02 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx W-CDMA/HSPA+
    RFmx W-CDMA/HSPA+为W-CDMA、HSPA和HSPA+蜂窝测试应用提供信号生成和分析功能。
    RFmx W-CDMA/HSPA+是一款测量专用软件,旨在扩展NI RF仪器生成和分析W-CDMA、HSPA和HSPA+蜂窝信号的能力。该软件可以通过误差矢量幅度(EVM)、码域误差(CDE)、相邻信道泄漏比(ACLR)、频谱发射屏蔽(SEM)等符合标准的物理层测量,对W-CDMA、HSUPA和HSUPA+上行链路信号进行分析。借助RFmx,您可通过交互式软面板快速轻松地执行和调试测量,使用RFmx Waveform Creator创建和回放开放的未锁定波形,并结合更高性能的API加快自动化测试的速度。
    发布日期:
    2015/10/17
    包含的版本:
    2.0完整版
    Windows 10
    Windows 8.1
    Windows 7
    Windows Server 2008 R2 64-bit
    语言:
    英文
    应用程序位数:
    32/64位
    文件大小: 680518432 字节 (648.99 MB)
    修改日期: 2015-10-17 06:15
    MD5: a122f34fff71256dcfd7c2bc1d387867
    SHA1: 052a0491cd6f9a6827cce6fbfe0a88c6227b1017
    SHA256: 5de3fb2d1dc0049f2d32ff21798ba57f98149e0af042660dead5bc7130eeef5b
    CRC32: 159a2cd5
    注册登录视觉论坛用户,购买附件查看下载地址
    NI RFmx W-CDMA~HSPA 2.0.txt (501 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-RFmx WCDMA 2.0 Readme
    October 2015
    Thank you for using NI-RFmx WCDMA. This file contains important information about NI-RFmx WCDMA and is organized into the following sections:
    Accessing VIs and Functions
    Uninstalling/Modifying NI-RFmx WCDMA
    Using NI Software with Microsoft Windows 8.x
    Installation InstructionsCaution  Before you install NI-RFmx WCDMA 2.0, ensure that you have uninstalled all related NI-RFmx 1.0 products.
    NI-RFmx drivers require that all the installed drivers have the same version for proper functionality. This requirement is because the NI-RFmx drivers share components. If driver incompatibilities exist, they are reported through a dialog box after installation. You can also use the Version Compatibility Checker utility to manually check for version incompatibilities. Refer to the Installed Software, Documentation, and Examples section for more information about the installed location of the Version Compatibility Checker utility.
    • NI PXIe-5663
    • NI PXIe-5663E
    • NI PXIe-5665
    • NI PXIe-5668R
    Vector Signal Transceivers
    • NI PXIe-5644R
    • NI PXIe-5645R
    • NI PXIe-5646R
    NI-RFmx WCDMA 2.0 supports the following operating systems:
    • Windows 8.0 (32-bit and 64-bit)
    Note  NI-RFmx WCDMA 2.0 does not support Windows Server non-R2 editions.
    Minimum System Requirements
    • RAM—2 GB*
    • A screen resolution of 1,300 x 700 with 256 colors
    • Windows 10/8.1/8.0/7, with all available critical updates and service packs
    Recommended System
    • RAM—4 GB*
    • NI LabVIEW 2013 SP1 (32-bit and 64-bit) f6 patch, 2014 SP1 (32-bit and 64-bit) f3 patch, 2015 (32-bit and 64-bit) f1 patch
    Note  NI-RFmx WCDMA does not operate correctly without the NI LabVIEW service packs and patches in the preceding list.
    Note  Install NI LabVIEW before you install NI-RFmx WCDMA. To add support for ADEs that are installed after you install NI-RFmx WCDMA, modify your NI-RFmx WCDMA installation or relaunch the NI-RFmx WCDMA installer.
    Other Required Software
      • Windows 10 (32-bit)/8.1 (32-bit)/8.0 (32-bit)/7 (32-bit): Program Files\National Instruments
      • Windows 10 (64-bit)/8.1 (64-bit)/8.0 (64-bit) /7 (64-bit): Program Files (x86)\National Instruments
      • Windows 10 (32-bit)/8.1 (32-bit)/8.0 (32-bit)/7 (32-bit): windows\system32
        • 32-bit DLL: windows\SysWow64
        • 64-bit DLL: windows\system32
    ItemInstalled Location on Windows 10/8.1/8.0/7
    LabVIEW Examples\LabVIEW \examples\RFmx\WCDMA
    Select Start»All Programs»National Instruments»NI-RFmx WCDMA»NI-RFmx WCDMA Measurement Interactive Panel to launch the NI-RFmx WCDMA Measurement Interactive Panel.
    Documentation for NI-RFmx WCDMA is located at Start»All Programs»National Instruments»NI-RFmx WCDMA»RFmx WCDMA Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    NI-RFmx WCDMA HelpHTML/Windows HelpInformation about NI-RFmx WCDMA. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to NI-RFmx WCDMA
    • A complete reference for all NI-RFmx WCDMA programming VIs
    NI-RFmx WCDMA 2.0 ReadmeHTML (this document)Information about supported hardware, operating systems, and legal notices.
    NI-RFmx WCDMA palette VIs are available from the Functions»Measurement I/O»NI-RFmx»WCDMA palette.
    You can access all the installed NI-RFmx WCDMA examples at Start»All Programs»National Instruments»NI-RFmx WCDMA»RFmx WCDMA Examples.
    • Select NI-RFmx WCDMA 2.0 from the dialog box that appears.
    For Windows 10/8.1/8.0, complete the following steps:
    • Click the Uninstall button.
    As part of the NI-RFmx WCDMA 2.0 installation, the following software is installed. To completely remove the NI-RFmx WCDMA 2.0 installation from your system, you must also remove the following package:
    • NI-RFmx WCDMA Runtime 2.0 for LabVIEW
    You can access the software and documentation known issues list online. Refer to the NI-RFmx WCDMA 2.0 Known Issues at ni.com for an up-to-date list of known issues in NI-RFmx WCDMA 2.0.
    When developing memory intensive applications, you may encounter memory limits because 32-bit Windows applications utilize only 2 GB of memory by default. To expand the amount of memory an application can utilize, you can configure the executable to be large address aware to gain access to up to 3 GB of memory on a 32-bit Windows operating system and up to 4 GB of memory on a 64-bit Windows operating system.
    Note  LabVIEW 8.5 and later are large address aware. For more information, refer to KB 2HDEH9DT How Much Memory can LabVIEW 32-bit or 64-bit Use?.
    In TestStand 2013 and later, the Large Address Aware flag is enabled by default for the TestStand Sequence Editor and TestStand User Interfaces. For more information, refer to KB 5ZREUK2G Using the Large Address Aware Flag With TestStand Applications.
    Using NI Launcher
    For convenience, you can pin your most-used NI applications, such as MAX, to either the Start screen or the Taskbar on the desktop, as necessary.
    Finding All Programs
    © 2015 National Instruments. All rights reserved.
    375559A-01
    GMT+8, 2026-1-8 05:58
