查看: 1910|回复: 0
[NI软件产品] NI RFmx W-CDMA/HSPA+ 2.4 Full Win32/64ENG RFmx W-CDMA/HSPA/HSPA+蜂窝测试2.4完整版
    昨天 08:40
  • 签到天数: 3765 天
    连续签到: 16 天
    发表于 2022-4-12 11:24:51 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx W-CDMA/HSPA+
    RFmx W-CDMA/HSPA+为W-CDMA、HSPA和HSPA+蜂窝测试应用提供信号生成和分析功能。
    RFmx W-CDMA/HSPA+是一款测量专用软件,旨在扩展NI RF仪器生成和分析W-CDMA、HSPA和HSPA+蜂窝信号的能力。该软件可以通过误差矢量幅度(EVM)、码域误差(CDE)、相邻信道泄漏比(ACLR)、频谱发射屏蔽(SEM)等符合标准的物理层测量,对W-CDMA、HSUPA和HSUPA+上行链路信号进行分析。借助RFmx,您可通过交互式软面板快速轻松地执行和调试测量,使用RFmx Waveform Creator创建和回放开放的未锁定波形,并结合更高性能的API加快自动化测试的速度。
    发布日期:
    2017/12/6
    包含的版本:
    2.4完整版
    Windows 8.1
    Windows 7 (SP1) 64-bit
    Windows 7 (SP1) 32-bit
    Windows 10
    语言:
    英文
    应用程序位数:
    32/64位
    文件大小: 654954456 字节 (624.61 MB)
    修改日期: 2017-12-11 13:41
    MD5: 0d69884ae3689a9177c12a877a6f4abd
    SHA1: 3ffd37baea654dc36e0e4c7fe658d972d3eaf3bf
    SHA256: bf26ebddfb8f9567281ee2c5f283ad9c641792ab1b1bddd908dada5311fb67ba
    CRC32: 7d1d4e79
    注册登录视觉论坛用户,购买附件查看下载地址
    NI RFmx W-CDMA~HSPA 2.4.txt (501 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-RFmx WCDMA 2.4 Readme
    November 2017
    This file contains important information about NI-RFmx WCDMA and is organized into the following sections:
    Accessing VIs and Functions
    Uninstalling/Modifying NI-RFmx WCDMA
    NI-RFmx WCDMA 2.3 includes the following new features:
    • Addition of Code Domain Analysis (CDA) measurement
    • Addition of Slot Power measurement
    • Support for multi-carrier in ModAcc measurement
    • Support for frequency-dependent amplitude correction on measured power spectrum data
    NI-RFmx WCDMA 2.2 includes the following new features:
    • Addition of QEVM measurement
    • Addition of Slot Phase measurement
    • Addition of 21 additional standard defined UL test models in ModAcc measurement
    • Support for I/Q gain imbalance in ModAcc measurement
    • Support for quadrature skew in ModAcc measurement
    • Support for Limited Configuration Change when sweeping frequency and reference level in test applications
    • Support for LO leakage avoidance on VST devices
    • Support for reading the measurement configuration internally used by NI-RFmx in spectral measurements
    NI-RFmx WCDMA 2.1 f4 includes the following bug fixes and updates:
    • Fixed an issue where NI-RFmx was crashing when the memory usage in a process increased beyond 2 GB.
    • Recommended IQ Pre Trigger Time property now returns a positive number instead of a negative number. This property is applicable when NI-RFmx is used in the Analysis-Only mode.
    • For the Analysis-Only mode, user needs to adjust the t0 value of the I/Q waveforms according to pre-trigger samples present in the waveform before passing the waveform to the Analyze (IQ) function.
    Caution  Before you install NI-RFmx WCDMA 2.4, ensure that you have uninstalled all related NI-RFmx 1.0 products.
    • NI PXIe-5663
    • NI PXIe-5663E
    • NI PXIe-5665
    • NI PXIe-5668R
    Vector Signal Transceivers
    • NI PXIe-5644R
    • NI PXIe-5645R
    • NI PXIe-5646R
    • NI PXIe-5840
    NI-RFmx WCDMA 2.4 supports the following operating systems:
    Note  NI-RFmx WCDMA 2.4 does not support Windows Server non-R2 editions.
    Minimum Requirements
    • RAM—2 GB*
    Recommended System
    • RAM—4 GB*
    Note  You should install ADEs, such as NI LabVIEW or Microsoft Visual Studio®, before installing NI-RFmx WCDMA. To add support for ADEs installed after installing NI-RFmx WCDMA, modify your NI-RFmx WCDMA installation or launch the NI-RFmx WCDMA installer again.
    • NI LabVIEW 2014 SP1 f5 (32-bit) patch, 2014 SP1 f6 (64-bit) patch, 2015 SP1 f5 patch, 2016, or 2017
    Note  NI-RFmx WCDMA will not operate correctly without the service packs and patches previously mentioned.
    Other Required Software
      • (32-bit) windows\system32
    ItemInstalled Location
    Import Library files (32-bit)\Shared\ExternalCompilerSupport\C\include
    Import Library files (64-bit)
    C, .NET
    Examples\NI-RFmx\WCDMA\Examples
    Examples\LabVIEW \examples\RFmx\WCDMA
    Assemblies\DotNET\Assemblies\Current\NationalInstruments.RFmx.WcdmaMX.Fx40.dll
    Select Start»All Programs»National Instruments»NI-RFmx WCDMA»NI-RFmx WCDMA Measurement Interactive Panel to launch the NI-RFmx WCDMA Measurement Interactive Panel.
    Documentation for NI-RFmx WCDMA is located at Start»All Programs»National Instruments»NI-RFmx WCDMA»NI-RFmx WCDMA Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    NI-RFmx WCDMA HelpHTML/Windows HelpInformation about NI-RFmx WCDMA. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to NI-RFmx WCDMA
    • A complete reference for all NI-RFmx WCDMA programming functions and VIs
    NI-RFmx WCDMA 2.4 ReadmeHTML (this document)Information about supported hardware, supported operating systems, new features, fixed issues, and legal notices.
    NI-RFmx WCDMA palette VIs are available from the Functions»Measurement I/O»NI-RFmx»WCDMA palette.
    You can access all the installed NI-RFmx WCDMA examples at Start»All Programs»National Instruments»NI-RFmx WCDMA»NI-RFmx WCDMA Examples.
    NI-RFmx WCDMA 2.4 Drops Support for Microsoft Windows 7 RTM, Windows Vista, Windows XP, and Windows Server 2003
    With this release, NI-RFmx WCDMA drops support for Microsoft Windows 7 RTM (with no service pack), Windows Vista, Windows XP, and Windows Server 2003. NI-RFmx WCDMA 2.4 and later will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-RFmx WCDMA 2.4 to an unsupported OS. Additionally, after installing NI-RFmx WCDMA 2.4, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    For more information about the changes to our OS support for 2017, refer to KB 79UC78LS, Why Does my LabVIEW, LabWindows/CVI, Measurement Studio, or TestStand Built Installer Fail on Windows XP/Vista and Server 2003?.
    • Select NI-RFmx WCDMA 2.4 from the dialog box that appears.
    • Select Control Panel.
    • Click the Uninstall button.
    As part of the NI-RFmx WCDMA 2.4 installation, the following software is installed. To completely remove the NI-RFmx WCDMA 2.4 installation from your system, you must also remove the following package:
    • NI-RFmx WCDMA Runtime 2.4
    • NI-RFmx WCDMA Runtime 2.4 (64-bit)
    The following items are the behavior changes in NI-RFmx WCDMA 2.3.1 from NI-RFmx WCDMA 2.3.
    • Changed the default value of the IQ Power Edge Source property to ""(empty string).
    • The alias 'default@WCDMA' for the default signal name is accepted as a valid signal name in a selector string parameter.
    • LabVIEW built binaries using RFmx versions older than 2.2 are no longer supported.
    You can access the software and documentation known issues list online. Refer to the NI-RFmx WCDMA 2.4 Known Issues at ni.com for an up-to-date list of known issues in NI-RFmx WCDMA 2.4.
    The following items are the IDs and titles of a subset of issues fixed in NI-RFmx WCDMA. This is not an exhaustive list of issues fixed in the current version of the NI-RFmx WCDMA. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    The following item is the change in NI-RFmx WCDMA 2.4 from NI-RFmx WCDMA 2.3.1
    640495Fixed an issue where switching between measurements from an NI-RFmx cellular personality to Demod resulted in higher EVM on 5668R.
    The following items are changes in NI-RFmx WCDMA 2.3.1 from NI-RFmx WCDMA 2.3.
    650095Fixed an issue where the RFmxInstr Close API did not abort a measurement in progress, but instead waited for the measurement to finish before closing.
    650083Fixed an issue with RFmxInstr Save All Configurations API to save the attribute configurations depending on the corresponding number of channels configured by user.
    648703Fixed an issue where passing NULL as selector string in a few C functions, caused the function to crash.
    The following items are changes in NI-RFmx WCDMA 2.3 from NI-RFmx WCDMA 2.2.
    641152Fixed an issue with configuring User Defined Channel properties in ModAcc and SlotPhase measurements with a named signal.
    © 2015–2017 National Instruments. All rights reserved.
    375559F-01
    GMT+8, 2026-1-8 05:58
